Proteus 8 is not showing eeprom initialized variables using .eseg
17 posts / 0 new
Hi guys,
I have made a .asm program for atmega16 in avr studio 4. I have defined initial variables using .eseg and then I am printing that on port B. The results are fine for avr simulator but when I verify the results using proteus 8. The PORTB output remains 0xff. I have already loaded the .bin file of eeprom contents in proteus but output is still 0xff.
Does this look like the Proteus support website? If you paid for a Proteus licence why aren't you using their support system included in the price?
Yes I know it is proteus related issue but I thinks anyone already had done this kind of tasks using avr because I am not able to find any appropriate support on proteus links.
If it is not on their website , you should for sure ask them. Then they can add that question and in the future when someone has the same problem they can also find the answer here
.bin file? You mean .eep HEX file don't you?
Could this be a confusion between the generic meaning of EEPROM = Electrically-Erasable Programmable Read-Only Memory - which would include Flash - and the specific use of "EEPROM" to imply non-volatile data storage ... ?
EDIT
AVR Memories - see: https://www.avrfreaks.net/comment...
clawson wrote:
yes of coures I mean eep.hex file..
And does that file contain valid data ? Or is it "empty"?
(an "empty" hex file will contain just a solitary termination record).
PS if the file is not empty then, as others have suggested, this is one for Proteus support.
Can you even load a file into EEPROM?
I have the demo version loaded here and can see how to load a program file but don't see an option to load a file for the EEPROM.
I cannot find anything recent about this but going all the way back to 2007 I found this:
http://www.edaboard.com/thread98...
That does seem to suggest that the hex DOES need to be converted to bin and then you load that binary image in the dialog shown.
But maybe things have changed a bit in 10 years?
(EDIT: actually last post there is 2010 so it seems it was still the same 7 years ago in fact)
OP says, "results are fine for avr simulator" - so does very much sound like a Proteus problem ?
... hence my "suggestion" to take it up with Labcentre because they took his money... (well I can be generous can't I?)
valusoft wrote:
they took his money
or his school's money.
... all the more reason to contact their supplier ( more money paid = more leverage )
clawson wrote:
I cannot find anything recent about this but going all the way back to 2007 I found this...
'cept that really is an EEPROM.
If we look at a '2560...
Proteus AVR simulation has a number of issues and limitations. For the price it costs, it should be as close to perfect as possible, so, I agree, go the Proteus support forum and ask for help.
