LCD 4bit interface
15 posts / 0 new
According to the 2x20 LCD HITACHI datasheet, E cycletime must be > 800 ns.
This LCD write routine is executed twice for each 8 bit write and works well
if the delay is 1 mS, with delay = 100 uS neither initializing of anything else works
any idea?
;___________________________________________
;WriteLCD4
;write r18     b7,b6,b5,b4 to LCD D7,D6,D5,D4
;      r18       b2 = RS, b3=E
WriteLCD4:
ori r18,1<<3 ;E=1
sts PortE_OUT,r18
ldi r20,10
rcall delay100uS
andi r18,0xff-(1<<3) ;E=0
sts PortE_OUT,r18
ldi r20,10
rcall delay100uS
ret
;______________________________________________
THe delay100us routine is tested ok, no interrupts.
Most of us use the LCD software by Peter Fleury, http://homepage.hispeed.ch/peter...
You can roll your own if you must, but compare your code to his and pay attention to the delays he uses as they follow the datasheet specs.
LCD's can be finicky if not fed data exactly as the DS says too.
GBaars wrote:
if the delay is 1 mS, with delay = 100 uS neither initializing of anything else works any idea?
General hip-shot questions:
1. Are you following the special timing requirements that hold for the init sequence?
2. How have you verified that your delay100us is correct w.r.t. timing?
Spent some more time on it, reading
datasheets from begin to end is always a pleasure.
Cleardisplay instruction is an exception with 1.53 mS exec time
and it won't initialize if less. Tcyc=800nS isn't accurate either.
I have been working with LCD displays in 4 bit mode for over 16 years.  There is a lot of variation in the delay timing.  The older large displays that I bought 15 years ago surplus need long delays.  Recently I have been playing about with the Arduino (New) LCD Library and a bunch of old surplus displays.  I found I had to change the delay in the library as each display needed a different delay.  A number of these displays came from old vending machines and had a ATMega8535 backing board.  I stripped this board and found they used the standard 14 wire interface.
I also wrote an emulator for the HD44780 so I could use a bare wire VFD.  I wanted it to be a drop in replacement.  The code for this is on my github https://github.com/sheepdoll/AVRVFDCLOCK.git. The protocol is basically a shift register state machine. It is quite simple.  I chose to use I2C as I was out of pins on the ATMega328.
The delay can also be found by timing the polling bit in the read register.  Normally the read mode is disabled as the delay system is sufficient and saves a number of wires. Getting this timing is a bit more work. More wires are needed. A simple Arduino script makes it practical to get this number.
You haven't included many comments so we can only guess....
ldi r20,10
rcall delay100uS
Are you attempting to achieve a 1 mSec delay by using the value in r20 to call your delay100uS routine 10 times?
If that is so wouldn't it be a good idea to check the value in r20 at some point?
Don
I read unlike the original HD44780's LCD's bought on EBAY for a few euro
have a ST7066 which apparently is some Chinese clone so you never can be sure
what specs they're gonna meet.
These specs, I expect:
https://www.newhavendisplay.com/...
Yes, the HD44780 is the industry standard, so there are endless clones, that usually have different timings, but in most cases they are faster than the original and/or allow a more sloppy initialization sequence. Here is a link with a (clearly incomplete) list: http://midibox.org/dokuwiki/offl...
Usually the display module documentation will tell you which specific clone is used, but for cheap stuff from China most of the time you won't have any documentation, you just know it's HD44780 compatible.
I guess there is something to be gained by writing it all from scratch again but many examples of 4/8 bit HD44780 in Asm exist. This is one:
http://www.avrbeginners.net/inte...
with 4 bit here:
LOL.  I've been roundly lambasted here over the years -- I must be the only "busy bit" reader in captivity.
So here again the thread goes back-and-forth about proper delay intervals, variations between clone controllers, variations between models, and similar.  If the solution is to time the busy bit -- then why not watch the busy bit?!?
Now jporter does more sophisticated stuff than I do, so I certainly cannot claim one approach is better than another.  But I'm interested in this "number of wires"... I guess "1" is indeed "a number".
My guess is that when the read line is held low, then everything fits into a nice neat 8 bit byte.  A lot of Arduino interfaces use I2C expenders.  That is only 2 wires.  SPI is also popular as that is simply the old 74HC595 needs a bit more wires.  Ardiuno seems to be a one size fits all methodology.  The code is clever but not too space efficient. Arrays of pin instances are sorted so that the user only sees what they need to see.  Takes advantage of C++ overlays. Surprisingly it works.
I'm old fashioned, and connect my display to my AVR.
More pins?  Yeah; 1.
Less parts?  Yes; no "expander" needed.
Avoid issues with tailoring delays to different character LCD models?  Yes.  (ditto for VFD and similar)
Allows for read-back to check that the display is really there and alive?  Yes.
Faster?  Dunno.  I'd think perhaps "yes" if the delays need to be conservative.
If you're really short of AVR pins and want to push it: 2 wires to a '174 with a diode and a resistor. Sort of slow, but works.
http://www.radanpro.com/Radan240...
https://sites.google.com/site/zo...
Second link has C code - for a PIC but is easy to port to an AVR.
(I know I've mentioned this before, but it was maany years since..
Under the assumption that the HD44780 is running at some specific clock frequency.
These displays have been done to death, are becoming boring stuff.
Use some tested library.
Gosh I remember the euphoria when I got my first HD44780 working with my own written code with nothing but the datasheet to go on.
That must have been... 20 years ago?
An extra challenge turned out to be that the displays I got were some "extended temperature range" versions.
These display's needed -3V on the contrast pin or they would show nothing at all.
JohanEkdahl wrote:
Level: 10k+ Postman Joined: Wed. Mar 27, 2002 Posts: 25951 View posts Location: Lund, Sweden #14 Posted : Fri. Oct 13, 2017 - 09:06 PM (new) 1 2 3 4 5 Total votes: 0 If you're really short of AVR pins and want to push it: 2 wires to a '174 with a diode and a resistor. Sort of slow, but works.
Or just throw in an extra AVR to control the display via I2C.
I have an (almost finished) project lying somewhere of a project which uses an avr just for interfacing a front panel.
It handles a HD44780, does some keyboard scanning and reads some rotary encoders.
Some say this is overkill, but on projects where the front panel is a different pcb from the main pcb it's not such a crasy idea at all.
It makes for clean wiring.
Code is easily reusable for other projects.
It keeps the noise generated by all the keyboard scanning away the sensitive part (analog electronics, ADC)
I2C has inherent slew rate limiting (not on all AVR's I believe the Tiny\s don't have proper I2C).
Offloading the whole front panel /keyboard scanning frees up a lot of pins of the "main" AVR.
Paul van der Hoeven.
http://www.hoevendesign.com
