Do I need to consider something special for circuit i put on car?
7 posts / 0 new
Hi!
As title says is there some special design considerations for electronics installed in car?
I need something to turn on the amplifiers with little delay since my line converter is acting wonky and outputting startup signal ie. When door is opened and the amplifiers briefly try to start because of this, which is not wanted, manufactor of the line converter washes his hands by saying "it's so new car that it might give all kind of signals"...(great).
So I was thinking, adding atmel to highjack the signal from line converter and turn on the amplifiers via relay or something when the signal have been active for X amount of time, thus eliminating the false signals.
You will need power supplies and circuits that can withstand load dump (Google is your friend) and other electrical noises.
Your device should work correctly in wide temperature range, from winter night temperature to temperature in a car staying entire day in summer sun. I took a look at datasheets of a few Atmel microcontrollers and temperature range for all of them is OK, but of course every component of your device should have appropriate working temperature range.
And of course you should check with your car assurance how high the premium will rise since you modified a car's electrical system and the car therefore no longer conforms to the specs when it was series tested before. Surely you and all of us know that you don't ever create any erratic hard- and software. But how can they know?
Einstein was right: "Two things are unlimited: the universe and the human stupidity. But i'm not quite sure about the former..."
... especially if you plug it into the cigarette lighter socket.
Why not just use a "time delay relay"   https://www.allaboutcircuits.com...
these have been around a long time to solve just this type of problem.
ki0bk wrote:
Why not just use a "time delay relay"   https://www.allaboutcircuits.com/textbook/digital/chpt-5/time-delay-relays/
Cool, I had no idea such thing exists :P this might be just what I'm looking for I just did not know it yet.
