SAM-BA success with micro-sam-ba
5 posts / 0 new
One of the problems I need(ed) to solve for my project was how to load the code in "production" and perhaps do field firmware updates. I really wanted to be able to do it over USB, and SAM-BA seemed like the answer, but I couldn't get it to work until I found https://github.com/atmelcorp/mic... .
With that code, I can load in my project's .bin file, set the GPNVM bits the way I like them and it works. I've tried the various SAM-BA Windows (GTK) UI and command line downloads, and couldn't get any of them to work (or figure them out), but micro-sam-ba works great!
Surely, you'd use the JTAG/SWD for that?
(if the chips don't come pre-loaded with a bootloader, you'll need that to load the bootloader in the first place anyhow)
This is a lot easier than SWD/JTAG and it also proves that USB works as a side effect. It also means I don’t have to populate the JTAG/SWD header for production builds.
And the S70 *does* come with SAM-BA in ROM, or I wouldn’t be able to do it that way.
Not usually.
Usually, production lines are equipped to use JTAG or SWD - not having to plug-in a USB connector!
You wouldn't do that anyway - you'd use spring probes direct onto the board.
True;  but this is in a general Cortex-M forum - some of them don't.
awneil wrote:
Not usually.
"production" in this case is me making them in my garage (that's why I put it in scare-quotes). If it were an assembly line, I agree things would be different. That said, I *still* think it might be useful to break-out the USB lines instead of JTAG and do it this way. More of the system gets tested as a side effect of loading (in particular, it would test the 5->3.3v buck converter if you supplied 5 volts via usb instead of 3.3v via JTAG).
I should have mentioned in the first post this was specifically an S70.
