Identifying the IC manufacturer in link
16 posts / 0 new
1. Here is the link for which I have to find the IC manufacturer:
https://www.google.co.in/imgres?...
2. Its a Li-Ion battery protection IC, 20 Pin SOP package, 9 & 10 Pin are shorted to ground
3. From symbol "M" on it, seems like Microchip IC, but microchip have no such solution I had checked.
I've tried similar searches for that kind of IC. It appears that many are made by fairly obscure manufacturers. I was never successful.
<edit> Should also add that many manufacturers make custom or semi-custom or "not for general market" chips. These are typically NOT listed in their catalogs and product lists. Battery protectors may be among the not for general market as they tend to sell them only to companies that manufacture battery packs. If you have one in a battery pack that has failed, then it is likely that your only "solution" is to purchase a replacement pack. </edit>
Do a search for li-ion protection chip...you will find plenty to chooe from...what are your specs?
Why do you have to ?
What do you need that information for?
I am guessing that the OP has a damaged protection board and wants to replace the IC on the board.
Quite possibly. Which then raises the question: is it worth it ?
That is what I suggested in #2.
IC which I have on board has similar looking "M" logo on IC.
Following are numbers written on it:
620
B385A
No, I am trying to reverse the board to make my own.
Is it Microchip or Mitsumi or any other manufacturer?
As has been said, it is rather unlikely that you will identify this chip.
It is also highly unlikely that you will be able to make it any cheaper than you can buy it on AliExpress.
How do you know it's not a microcontroller programmed to act as a protection chip?
Trace out the whole schematic and see if the pins used match any known uC families.
"How have you proved that your chip is running at xxMHz?" - Me
"If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand." - Heater's ex-boss
Its not a uC. As it is used in 5 cell Li-Ion protection. Each cell has connection to one pin of IC with only 1K in series not an divider, that means its is specific Li-Ion protection IC. Normal uC dont have level shifted adc's
This logo I had checekd by below link, looks like Mitusumi IC, but i am not sure, as I didnt find IC even in tehier obsolete part & didnt find any email ID on Mitusumi for contacting them, & their Contact us forum always through HTMP error.
https://www.google.co.in/search?...
Normal uC dont have ...
Again, there is no particular reason to believe that it is a standard catalogue part at all.
See #2.
And #10.
So you didn't try Googling "mitsumi ic battery" then?
If you did then the first hit is this...
https://www.aliexpress.com/item/...
...and the third...
http://www.alldatasheet.com/data...
There you go, a supplier and a datasheet.
Battery management megaAVR do.
http://www.microchip.com/wwwproducts/en/ATMEGA16HVB
4 cells, low side current sense, control of the high-side charge and discharge NFETs
I can certainly not disagree with this comment.  I have given up trying to 'Roll my own' for certain things anymore as I can usually find what I need already done, and easy enough to integrate into my kit.  The only time I would do a basre design if it was an absolute requirement by the customer.
Really?  Many/all AVR's have multi input ADC converters........
