ATSAMD51 + START + FreeRTOS + LTE modem
3 posts / 0 new
My first project with Atmel, so why not a complicated one...
I am just starting this and I will have one UART for debug commands to the chipset and another for the data stream.  I am unsure which driver type i should use:
HAL or LITE?
Sync/Async/RTOS?
Since I am in an RTOS thread, RTOS comes to mind, but
1) How "Beta"??
2) What are Sync vs. Async since it is a UART, I am sure it isn't synchronous serial...
A properly formed "RTFM" is welcome.  where is the manual?  :)
jeff
Possibly, it's talking about the software behaviour - not the UART operation.
So Sync vs. Async would be blocking vs non-blocking operation ... ?
EDIT
aka polled vs interrupt-driven
Ah, that is helpful.  I was sure it was not the HW, since there are I2C/SPI/USART/UART HW options and it was UART.
So assuming I am willing to debug the beta a little, the RTOS Async (interrupt driven, non-blocking) would work best with the FreeRTOS thread.
Should I assume that the "blocking" will very likely run the much-despised "while(waiting);" and burn entire RTOS ticks every time it gets to run the task?
At least for the first task I only have to use modem AT commands to HTTPS POST data.  Next project with the modem needs a lot more.
jeff
