JTAGICE3 DGI (Data Gateway Interface)
4 posts / 0 new
I've got a JTAGICE3, updated to 3.35
I wanted to try to get the DGI (Data Gateway Interface) working for SPI.
I wanted to use SPI master on the target as a simple debug logging output.
It's something that I might have used the UART for, but that is being used for the application.
By having ISP/SPI programming and DGI SPI debug output I'd be able to switch back and forth without moving connectors.
The problem:
Although the JTAGICE has a 2nd USB interface labelled Data Gateway, it only supports the timestamp interface.
Both Studio 7.0 (1417) and my own experiments seem to indicate this.
--> 00 00 00       // Sign on
<-- 00 a0 00 1f 4a 54 41 47 49 43 45 33 20 44 61 74
    61 20 47 61 74 65 77 61 79 20 49 6e 74 65 72 66
    61 63 65       // "JTAGICE3 Data Gateway Interface"
--> 08 00 00       // Get interface list
<-- 08 a0 01 00    // Only one "interface", timestamp
--> 10 00 02 00 01 // Enable timestamp interface
<-- 10 80          // OK
--> 15 00 01 00    // Poll timestamp interface data
<-- 15 a0 00 00 00 00 00 00 00 00 00
Was the DGI only halfway implemented on the JTAGICE3?
Wow, no response.
Has anybody ever gotten anything to work with any form of DGI on anything?
Update:
Atmel (Microchip) has confirmed that DGI is not implemented fully and that it never will be on the JTAGICE3.
It is implemented on the Atmel ICE (its successor).
See: https://www.avrfreaks.net/forum/it-possible-monitor-serial-using-atmel-ice-solved#comment-2283336
Thanks for the update - please mark that as the solution: https://www.avrfreaks.net/comment...
