DEFINE function not Defining???
7 posts / 0 new
Hi again.
Just wondering if anyone can help me with a problem?
I'm picking up where I left off a few years back, this time using Studio 7.
I'm trying to use the #DEFINE function in this type of format: -
#define EW_RED_LIGHT PORTB0
and later in my code, I'm using this instruction: -
EW_RED_LIGHT = 1;
Upon compiling, I get the following error: - "Value required as left operand of assignment"
What am I doing wrong? These seem to me to be acceptable commands?
Thanks in advance for any help.
You probably need:
PORTB |= (1 << EW_RED_LIGHT);    // Set bit B0 in PORTB
PORTB &= ~(1 << EW_RED_LIGHT);    // Clear bit B0 in PORTB
David (aka frog_jr)
#define is correctly known as a preprocessor directive.
EW_RED_LIGHT = 1;
Remember that the preprocessor is merely a text substitution engine; so what the compiler actually sees is
PORTB0 = 1;
What do you get if you do that directly?
If you look-up the definition of PORTB0 - does it make sense on the left-hand side of an assignment ?
You probably need:
Or:
#define EW_RED_LIGHT_PORT PORTB
#define EW_RED_LIGHT_BIT      0
EW_RED_LIGHT_PORT |=  (1 << EW_RED_LIGHT_BIT);    // Set bit B0 in PORTB
EW_RED_LIGHT_PORT &= ~(1 << EW_RED_LIGHT_BIT);    // Clear bit B0 in PORTB
The moral is that #define is not a 'function'.  It is a directive which tells the preprocessor to substitute text in place of the identifier.
In the OP's code, the compiler would see:
PORTB0 = 1;
... and since PORTB0 is itself #define'd as a constant (0, in fact), the compiler really sees:
0 = 1;
... which is (obviously) not a valid expression in C.
"Read a lot.  Write a lot."
Instructions for posting source code: https://www.avrfreaks.net/comment...
OK, That's completely error free now, appreciate the help, thanks again.
Excellent!
So please mark the solution: https://www.avrfreaks.net/comment...
