C question -- init string without trailing null possible?
16 posts / 0 new
I seem to recall a discussion on this in the past, but cannot find it.
I want to put an array of structs into flash.  (but flash or EEPROM or SRAM shouldn't matter, I don't think)  Each has a name field of exactly 8 bytes.  I want to give initial value, with no trailing null.  CodeVision objects:
Error: C:\OptiCode\HY148\HY148p.c(4660): initializer "string" exceeds array dimension
Stripped-down trivial example (yeah, I know if there were no other fields I could just paste them together...)
struct	xproduct_struct
unsigned char	type;		//
unsigned char	name[8];	//
typedef struct xproduct_struct	xxxProduct;
flash			xxxProduct	products_fixed[] =
	{	1, "DICTATE "},
	{	2, "FROGHAIR"},
I guess I could init each element of the array individually -- that would be onerous:
{ 2, {'F','R','O','G','H','A','I','R'}},
Your code is correct and achieves what you want, initializing the array without the trailing null. Looks like a bug to me that the compiler doesn't accept it.
Edit:
The standard says:
An array of character type may be initialized by a character string literal or UTF−8 string literal, optionally enclosed in braces. Successive bytes of the string literal (including the terminating null character if there is room or if the array is of unknown size) initialize the elements of the array.
Stefan Ernst
Edit:
The standard says:
Which standard is that from?
The problem with standards is...... there are so d*m many of them!
Well, poo -- I think you are right.  I poked into GCC/Studio7 and got a clean build with
__flash xxxProduct	const products_fixed[] =
	{	1, "DICTATE "},
	{	2, "FROGHAIR"},
	myPWM_init();
		OCR1C=9999;
		PORTB = products_fixed[0].name[PINB];
...and the generated code looks reasonable -- I see the LPM...
154:	e3 b1       	in	r30, 0x03	; 3
 156:	f0 e0       	ldi	r31, 0x00	; 0
 158:	eb 51       	subi	r30, 0x1B	; 27
 15a:	ff 4f       	sbci	r31, 0xFF	; 255
 15c:	84 91       	lpm	r24, Z
 15e:	85 b9       	out	0x05, r24	; 5
... and the table in flash...
000000e4 <__trampolines_end>:
  e4:	02 46       	sbci	r16, 0x62	; 98
  e6:	52 4f       	sbci	r21, 0xF2	; 242
  e8:	47 48       	sbci	r20, 0x87	; 135
  ea:	41 49       	sbci	r20, 0x91	; 145
  ec:	52 01       	movw	r10, r4
  ee:	44 49       	sbci	r20, 0x94	; 148
  f0:	43 54       	subi	r20, 0x43	; 67
  f2:	41 54       	subi	r20, 0x41	; 65
  f4:	45 20       	and	r4, r5
  f6:	02 46       	sbci	r16, 0x62	; 98
  f8:	52 4f       	sbci	r21, 0xF2	; 242
  fa:	47 48       	sbci	r20, 0x87	; 135
  fc:	41 49       	sbci	r20, 0x91	; 145
  fe:	52 00       	.word	0x0052	; ????
It is perfectly legal to initialise an 8 char array with a quoted string.   It should just drop the NUL if it does not fit.
Most Compilers will whinge but it should be Warning not Error.
Note that a 9-char string would be an Error.
char name[5] = "David";  //will omit the NUL
char name[] = "David";   //will allocate 6 chars to accommodate the NUL
Thanks for the eyes and the responses, people.  I'll work around it. Take care.
Your example compiles ok in imagecraft as well.
No null char's stored.
Learn someting every day: Check.
(I might actually have known this at some time, but iif so it sure is swapped out thoroughly..)
$ echo 3 > /proc/sys/vm/drop_caches
"Read a lot.  Write a lot."
BTW dropping the null is NOT valid in C++.
I note the file name ends in .c .
gcc can be told to compile a .c file as C++.
International Theophysical Year seems to have been forgotten..
Anyone remember the song Jukebox Band?
I am disappointed that I can apparently not index quoted strings in initialization:
   char c = "mystring"[3];
(I mean, the compiler will optimize away references like that
static char* mystring = "mystring";
  c = mystring[3];
will end up producing something like "ldi r24,'t'"...)
that would have made for some not-too-ugly macros for initializing size-limited arrays from arbitrary strings...   Ah well.
Are you sure? I tried to compile this and there were no errors. It works for both C and C++.
Failed for me with avr-gcc 5.4, 4.3.x, and Apple llvm 6.00
BillW-MacOSX-2<5027> avr-gcc -c -Os -mmcu=atmega8 gross.c
gross.c:5:10: error: initializer element is not constant
 char c = "1234"[2];
 char c = "1234"[2];
I know what makes the difference. My c variable was an automatic variable in main() and apparently your c was a global variable. When I moved the variable outside of main(), I also got compile error.
In early C string constants like "1234" in your example could be modified, but current standard doesn't allow this. However, string literals are still of type char[] in C, not const char[] and I think this is the reason why "1234"[2] isn't a constant expression.
I thought it might be that, but it also doesn't like casts to "const" either.
I guess the automatic variable initialization doesn't even need to be constant (but does optimized to an LDI...)
