Reset Bits after WDT Setup
5 posts / 0 new
Hi there,
I'm making my Arduino periodically wake up using the WDT and 'SLEEP_MODE_PWR_DOWN" and I'm using this bit of code to set up the WDT bits:
void WDT_setup() {
  MCUSR &= ~(1<<WDRF); // Clear the reset flag
  // In order to change WDE or prescaler, we need to set WDCE
  // (this will allow updates for 4 clock cycles).
  WDTCSR |= (1<<WDCE) | (1<<WDE);
  WDTCSR = 1<<WDP0 | 1<<WDP3; // Set watchdog timeout prescaler value, 8s
  WDTCSR |= _BV(WDIE); // Enable the WD interrupt (note no reset)
However, my question is, if while the code is running, I wanted to sleep the Arduino indefinitely instead of periodically waking up, how do I clear those WDT settings back to default so that these commands
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
sleep_mode();
make it sleep indefinitely without waking up until the RESET button is pressed?
The datasheet talks about the MCUSR and WDTCSR registers on page 54, but I don't know exactly what sequence of bits to clear, etc.
Thanks!
#include <avr/wdt.h>
    wdt_disable();
"Read a lot.  Write a lot."
Hah, it's that easy? I was also thinking
WDTCSR = 0x00; // Turn off WDT
but wasn't sure if there was more to it. Thanks!
The example at the bottom of page 52 shows something like this:
void disable_WDT() {
  WDTCSR = 0x00;
AVR Libc provides a library with functions that will work across all AVR targets, in all circumstances.  Why not use it?
One thing it does lack are functions to employ the interrupt mode, and interrupt/reset mode of the WDT.  That is a bit annoying.  However, it's fairly easy to examine the library yourself and derive your own interrupt mode versions of their static inline functions.
