AVRs beyond their specs: Experiments and tests - but not more than 16MHz
19 posts / 0 new
I know that their are specs defining the "safe area" of the graph of clock speed versus Vcc and that
leaving that area behind me will not make me happier. ;)
But I am curious...
What I want to do:
I have an ATmega2560 based board with a 16MHz crystal and too less additional parts as I could
make a boost converter from it... :)
The board runs happily with 3.3V...a blink program at 16MHz...which is out of spec.
A blink program is not /that/ a heavy task for a MCU I think, so this may be a lucky coincedence.
What kind of program would most likely reveal any weakness of this setup?
Are there already some kind of "burn in" programs around (I dont want to "overclock" in the sense of clockspeed > 16MHz) ?
Thanks for any help in advance!
Cheers
mcc
The point is, outside the datasheet-specified working conditions, the behaviour is undefined.
In other words, anything could happen.
Hi awneil,
thanks a lot for your answer.
Ok, more specific:
I want to test, what this certain board will do with a certain program, which pushes the MCU at its limits.
"Blink" as mentioned is not that kind of program.
What program should I use instead?
Cheers
mcc
There's been many threads about "over-clocking" in the past. I think it's usually suggested that EEPROM may be the first thing to go wrong as you wind the clock up but look for posts by AtomicZombie where he has overclocked AVRs to get more VGA graphics resolution from them. I think he's taken them as far as X2 (so 16MHz devices at 32MHz and so on).
Obviously you can't do this for a commercial product but it's fine for a bit of one-off experimentation.
Hi clawson,
as mentioned earlier I dont want to "overclock" and I didn't searched for that keyword since it leads me to
threads about "overclocking" (increasing clock).
Its more an "undervoltage-ish" thing to experiment with.
My original question was:
Cheers
mcc
Eh??
But you are overclocking!!
"overclocking" is, by definition, running at greater than the specified maximum clock frequency - which is exactly what you are doing:
EDIT
mcc wrote:
I want to test, what this certain board will do with a certain program, which pushes the MCU at its limits. "Blink" as mentioned is not that kind of program.
Yes it is. The AVR uses no more power to execute any particular opcode. So :
int main(void) {
    while(1);
which will basically compile to:
here:
    rjmp here
will use the same amount of power to execute repeated rjmp's as anything else.
I suppose you might argue that "switching gates" in silicon takes power so that something like:
int main(void) {
    volatile uint32_t count;
    while(1) {
        count++;
will do a repeated sequence of ADD and ADC opcodes (and the RJMP to loop) and the additional gate switching involved in fetching count, doing the ADDs then storing it *might* take a fraction more CPU power to achieve but I defy you to be able to actually measure that - the change will be almost infinitesimally small.
This is not like you Windows or Linux machine where real complex tasks cause all four or eight CPU cores to run at full steam - this is an 8 bit AVR with none of the sophistication of Cortex A or Intel 86 processors.
The AVR is very simple - it is always running "at full steam" fetching/executing opcodes, however trivial, even NOPs, or it is executing SLEEP and some/all clocks stop. There is no half way house.
Reducing the voltage and increasing the frequency basically have the same effect: due to internal capacitance and inductance, signals inside the CPU lose integrity. You can have an idea of what happens looking at some scope traces I posted on a different thread. See how the supposed square wave becomes crap at high frequency?
This will happen inside the device, causing timing errors, 0s and 1s being misinterpreted, etc.
Different parts of the device will be more or less vulnerable. For example, maybe SRAM will start giving errors before the CPU core. Who knows?
Normally, math intensive programs are used to test overclocked PCs, so maybe you can find some fractal calculator or pi calculator for AVR architecture?
I guess you could write some code that would test whether each instruction was working correctly. Basically a routine which uses as many opcodes as possible and that returns a value which can be tested for correctness. IIRC, Intel had something like that in the self-test diagnostics on their 8-bit development systems.
More to the point, you'd want to test that each component is working properly; ie, not just the CPU instructions, but also RAM, Flash, EEPROM - and all the peripherals ...
;)  Deja vu all over again.  A thread maybe a year or two ago explored whether/which AVR op codes are more "efficient".  I don't remember what the outcome was.
It would be interesting to know the purpose of the snipe hunt.  I have many scores of production AVR8 apps, and only a couple run faster than 8MHz.
MCUs have a MHZ-Voltage curve, for any given temperature, so you are overclocking anytime you go ABOVE that curve.]
If the spec says 2.7V, you can get one gain by running 3,3V +/- 1 % or similar tighter spec, and also reduce the TempMax
Blink is a very basic test, you might want to fill the Flash/RAM with a pattern, and checksum that, to confirm you can READ flash at the speeds you test for.
Next, peripherals may struggle at overclocking, but mostly the slowest part of a MCU is the flash.
IIRC the XMega's give am external clock Max of 125MHz provided you also respect the 32MHz Flash speed (ie you must select /4, or slower MCU clock )
I bench-tested an EFM8 MCU once with a 200MHz external clock, and /8 internal to keep the 25MHz flash spec - seemed to work fine, on what was a quick test.
Such out-of-zone tests can be useful to confirm design margins, even if you never intend to ship a product running there.
Yes.  But consider that lower VCC also means lower current.  If VCC can be lowered while keeping the CPU clock the same, then the result is lower W/MIPS.  For power-budget constrained applications which are also compute intensive, this measure may be an important factor.  However, AVR is not the ideal architecture for this purpose.  Better to look at something like Ambiq's 32-bit Apollo family, they claim 35μA/MHz @ 3.3V and 24 MHz, for about 116μW/MHz.
To compare, the 8-bit m2560 specs 17.5 mA @ 4.5V and 16 MHz, for 4,900μW/MHz, but that does not include the power consumed by the clock source.  The minima is 2.0 mA @ 1.8V and 4 MHz, for 900μA/MHz.  Even if you were to overclock  by a factor of 2, you're still looking at 450μA/MHz, and that's for an 8-bit CPU.  The Ambiq is a 32-bit ARM device, and their claimed 116μW/MHz includes the internal clock.
"Read a lot.  Write a lot."
The original post doesn't mention anything about energy efficiency.
One might suspect that that is not the key issue here, as a M2560 would be a very poor choice if the key function of the micro is simply to run a boost converter, as was the only part of this project that was specifically mentioned.
Perhaps there is a need for a lots-of-pins and big memory chip that just wasn't mentioned?
If I truly wanted a boost converter I'd look at the many chips specifically designed for this purpose.
And if I wanted to design my own I'd look carefully at the 6 and 8 pin Tiny micros.
And if I was really using a lots-of-pins and big memory micro, I suspect power savings on this part of the design isn't likely to be a major factor in the overall every usage review.
Lots more info needed...
Aside from the corner cases of some peripherals (EEPROM, Flash Self-programming, crystal oscillator), you're more likely to see random results under variations in temperature or supply voltage, rather than with changes in software.  I think.
Perhaps a bit unfair, picking a 20-year-old AVR8 model line.
If my clean sheet of paper has Mips/watt at the top of the page in large font letters, then indeed I might not pick an AVR8.  While 1/3 of that is still not near your example, that is what I'd expect of my AVR8 designs -- very good performance at a reasonable power draw.
So to drag out my car analogy again, I like my mid-sized SUV which has lots of capabilities with reasonable fuel usage.  Can you find a model with less fuel usage?  Certainly.
My attempted point earlier is that for most microcontroller apps I've tackled the AVR8 has plenty of horsepower without pushing the supplyV/clock speed curve.
An application can be compute-bound, memory-bound, and/or I/O-bound (all consume current)
W/MIPS is a measure though an alternate for compute is W/CoreMark.
RF AVR aren't far behind (1.8V core megaAVR); IIRC, XMEGA is next.
joeymorin wrote:
Better to look at something like Ambiq's 32-bit Apollo family, ...
next is SAM L and maybe PIC32 MM and/or recent PIC32 MX (haven't browsed those datasheets)
EEMBC
EEMBC
About CoreMark®
http://www.eembc.org/coremark/about.php
CoreMark is capable of testing a processor’s basic pipeline structure, as well as the ability to test basic read/write operations, integer operations, and control operations.
http://www.microchip.com/design-centers/32-bit/sam-32-bit-mcus/sam-l-mcus
http://www.microchip.com/design-centers/32-bit/architecture/pic32mm-family
Microchip Technology Inc
Microchip
Press Release
Latest PIC32 Family Increases Performance While Reducing Power Consumption
PIC32MX1/2 XLP Family Expands eXtreme Low Power (XLP) Technology to 32-bit Products
Chandler, Arizona
June 19, 2017
https://www.microchip.com/pressreleasepage/latest-pic32-increases-performance-reduces-power
There are megaAVR, tinyAVR 1-series, and XMEGA AVR application notes with source code for self-test of AVR in household appliances.
AVR tests (mega328PB, tiny817) :
  • CPU registers
  • SP
  • Status register
  • RAM
  • Flash
  • EEPROM
  • Watchdog
  • Interrupt
  • I/O registers
  • Clock
  • ADC
tinyAVR 1-series has CRC on NVM; XMEGA has CRC on all.
Microchip
AN_7715
AVR998: Guide to IEC60730 Class B compliance with AVR Microcontrollers
12/10/2016
http://www.microchip.com//wwwAppNotes/AppNotes.aspx?appnote=en591300
This application note describes the `Class B` software classification, refering to embedded firmware which is intended to prevent unsafe operation of controlled equipment and provides guidelines for compliance with the `Class B` classification ...
via http://www.microchip.com/wwwproducts/en/atmega328pb
Microchip
AN_42008
AVR1610: Guide to IEC 60730 Class B Compliance with XMEGA
07/01/2012
http://www.microchip.com//wwwAppNotes/AppNotes.aspx?appnote=en591027
via http://www.microchip.com/wwwproducts/en/atxmega32e5
The missing XMEGA IEC 60730 source code :
Atmel AVR1610: Guide to IEC 60730 Class B Compliance with XMEGA
(file size: 367KB, 25 pages, revision A, updated: 07/2012)
IEC 60730 is a safety standard for household appliances that addresses many aspects of both product design and operation. This standard is also referred to by other standards for safety-critical devices, for example, IEC 60335. System-wide compliance with this standard is necessary for an appliance to be certified as safe to operate. This application note is a guide to compliance with Annex H of the standard, which regards electronic controls.
via http://www.atmel.com/products/microcontrollers/avr/avr_xmega.aspx?tab=documents  (pull-down menu, Application Notes)
Seems I've caused something of a diversion.  I was just speculating on other reasons why one might want to probe the edges of the spec.
I guess the OP is hoping to be able to use his m2560 as a boost converter?  Unless Doc and I have misunderstood...
Surely that's a terrible choice as a controller at the heart of a boost converter, so there must be something else to the story.
