SD Card on SPI in SAME70 Xplained + IO1 Explained
6 posts / 0 new
Hi all.
I need reconfigurate example for SD card from MCI to SPI on expand board IO1 Explained.
I only added CONF_BOARD_SPI and SD_MMC_SPI_MODE in conf_board.h and I removed SDIO_SUPPORT_ENABLE.
I have problem with sd_mmc_check(0). I don't know what I have to do else for switch SD card from mci to spi.
It is different question. Default example is for MCI, not for SPI, and he has totaly another problem then me (I know it because I HAD the same problem with MCI). MCI works for me, SPI not.
and yet he has "totally the same" username as you ?!
I didn't notice, that previous question was mine. It is right...So, I can tell you, that this is realy different question...Don't discuss about "stupidity" and help me !
I SOLVED it. Alone ! Again ! This forum is useless for me, but I give you my solution.
1) Add SPI Example from Example projects (File->New->Example Projects).
2) Add SD Card component from ASF with SPI settings
3) Add symbol ACCESS_MEM_TO_RAM_ENABLED to Project -> Properties -> Symbol
4) Add FatFS service from ASF
5) This will be in main()
char test_file_name[] = "0:sd_mmc_test20170921_1049.txt";
Ctrl_status status;
FRESULT res;
FATFS fs;
FIL file_object;
// Initialize the sleep manager
sleepmgr_init();
/* Initialize the SAM system. */
sysclk_init();
board_init();
///* Initialize the console UART. */
configure_console();
ioport_set_pin_dir(SPI0_NPCS1_GPIO,IOPORT_DIR_OUTPUT);
ioport_set_pin_mode(SPI0_NPCS1_GPIO,IOPORT_MODE_PULLUP) ;
ioport_set_pin_level(SPI0_NPCS1_GPIO,true);
spi_master_initialize();
pmc_enable_periph_clk(ID_SPI0);
sd_mmc_init();
6) Comment or remove definition of SD_MMC_0_CD_GPIO in .._xplained.h
7) Then add this code to main(), but only do..while cycle is necessary
while (1)
printf("Please plug an SD, MMC or SDIO card in slot.\n\r");
/* Wait card present and ready */
do {
status = sd_mmc_test_unit_ready(0);
if (CTRL_FAIL == status) {
printf("Card install FAIL\n\r");
printf("Please unplug and re-plug the card.\n\r");
while (CTRL_NO_PRESENT != sd_mmc_check(0)) {
} while (CTRL_GOOD != status);
printf("Mount disk (f_mount)...\r\n");
memset(&fs, 0, sizeof(FATFS));
res = f_mount(LUN_ID_SD_MMC_0_MEM, &fs);
if (FR_INVALID_DRIVE == res) {
printf("[FAIL] res %d\r\n", res);
goto main_end_of_test;
printf("[OK]\r\n");
printf("Create a file (f_open)...\r\n");
test_file_name[0] = LUN_ID_SD_MMC_0_MEM + '0';
res = f_open(&file_object,
(char const *)test_file_name,
FA_CREATE_ALWAYS | FA_WRITE);
if (res != FR_OK) {
printf("[OK]\r\n");
printf("Write to test file (f_puts)...\r\n");
if (0 == f_puts("Test SD/MMC stack\n", &file_object)) {
f_close(&file_object);
printf("[FAIL]\r\n");
printf("[OK]\r\n");
printf("Test is successful.\n\r");
main_end_of_test:
printf("Please unplug the card.\n\r");
8) Only this will be in conf_board.h:
#define CONF_BOARD_UART_CONSOLE
#define SD_MMC_SPI_MODE
/** SPI MACRO definition */
#define CONF_BOARD_SPI
/** Spi Hw ID . */
#define SPI_ID          ID_SPI0
/** SPI base address for SPI master mode*/
#define SPI_MASTER_BASE      SPI0
9) Edit sd_mmc_spi_card_init(void) in sd_mmc.c and add this ioport_set_pin_level(SPI0_NPCS1_GPIO,false); under line driver_send_clock();
This is the most important of this project. If you don't add this line, you newer will have response from SD card and you will stuck on drive_send_cmd.
