USART with Timers Atmega32
62 posts / 0 new
Pages
your code has defects and is the result of poor design. Why not revisit it and apply some structure to it. Then you might find modifying it is easier.
You've already tried spamming us with personal messages - that didn't get you far. Just put in the work and don't try to go the lazy way.
Or the result of failing to do any design - but, instead, just jumping straight in and throwing code about.
https://drive.google.com/file/d/...
just watch this video and please reply....i made this video to show you how it works.
thanks
Please don't get me wrong but seriously i need your help.....thats why i m troubling you ....i kindly apologise if any inconvinience caused by me.....and kartman i really didn't meant to spam you in private i don't know the rules of here...i was just trying to communicate with someone who can help.
Manish verma
Sorry, your video doesn't have hamsters or cats doing funny things, so why would I want to watch it?
Somehow I think you're being a bit disingenuous - on one hand you're telling us you are doing this for your own learning, but you don't seem too interested in learning.
We're trying to help you by leading you down a path where you can hopefully solve your own problems, but you seem none too interested.
ohk. let it be. thanks for your help.
Manish verma
staring.net@gmail.com wrote:
...now i want 5 micros to communicate but unfortunately something unexpected happens.(5th micro is communicating with 4 micros (i.e. transmiting and receiving) but 4 micros can't transmit data to       that 5th micro but they are receiving...
Have we seen how you are connecting your 5 micros together?
"How have you proved that your chip is running at xxMHz?" - Me
"If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand." - Heater's ex-boss
5th microcontroller Rx and Tx connected to 4 micros Tx and Rx.
Manish verma
Ah, OK, so on your 4 'slaves' you have connected all 4 TX lines together and then connected that to the 'master' RX pin?
If so, have you read and understood what was said in posts #32, #35 and #43 in your other topic?
anyone here use whatsapp or email id ? if yes please share your details with me in personal.
That probably won't happen.
The point with forums is that it is an open discussion where anyone interested can join the talk, and future readers can learn from the past experience of others,
Asking for one-on-one help via mail or similar will only make you come through as wanting special attention (or just looking spoiled). If you want that kind of help then then find someone who does that for a monetary return (i.e. you pay for it).
What's wrong with the forums?
Did someone call?
I'm not "selling". I only tried to explain the lay of the land.
Pages
