Interrupt Vectors
15 posts / 0 new
I'm new to Atmel Studio 7.  Can someone tell me how to setup the interrupt vectors for an ATmega328 (using C code)?
I need an interrupt for Timer/Counter2 Compare Match A.
Dan
:: Morten
This is how I prototyped the ISR in my .h file:
void ISR(TIMER2_COMPA_vect);
However, the compiler is giving me an error.  Obviously, I have left something out.
And, as you may have guessed, I'm not a C programming expert.
Dan
You don't prototype ISRs... Just think a bit, why would you need to prototype it? (Also, make a habit of providing what error you get... Usually makes it easier to understand what is going on...)
:: Morten
An 'R', matey.
"Read a lot.  Write a lot."
As I said, I'm not a C programming expert.  But, I really do appreciate your help.
Thanks again,
Dan
But it should still be obvious that, to help you with "an error" from the compiler, we are going to need to know what, exactly, that "error" was - aren't we?
It's like saying, "a light came on in my car - what does it mean?" - clearly, anyone is going to need to know what light it was in order to give any suggestions!
The way way to do this is to copy the entire message from Atmel Studio and paste it into the forum - never try to manually re-type stuff.
Well, I guess we all can infer which toolchain is being used.  And indeed the expansion of ISR() with the chosen toolchain may not be swallowed as a "prototype".
That said, with a different AVR8 C toolchain I indeed prototype my ISRs.  True enough, they will be void functions with no parameters.  But IME it helps to catch mis-spelled vector identification.  YMMV.
In GCC "ISR" is a macro:
#  define ISR(vector, ...)            \
    void vector (void) __attribute__ ((signal,__INTR_ATTRS)) __VA_ARGS__; \
    void vector (void)
#endif
So that is a declaration immediately followed by the definition.
Shive me timbes!  You'e ight!
But--but--but--
No wonder old guys are accused of being confused.
"Mongo just pawn in game of life." -- Blazing Saddles
The point is you cannot use:
void ISR(SOME_vect);
(as OP tried) because the macro would expand out as:
void  void vector (void) __attribute__ ((signal,__INTR_ATTRS)) __VA_ARGS__; \
      void vector (void);
Too many voids there for the compiler's liking methinks.
The misunderstanding here comes from the fact that "ISR(...)" looks like a "function" but isn't.
The point is, that as you said, the macro IS the declaration (prototype), followed by the start of the definition.
The point is, as the ISR() mechanism essentially creates a prototype, then
...with respect to this particular toolchain doesn't seem to hold much water.
Now, does OP really want to expand
into a "proper" prototype?  Dunno.
void __vector_13 (void) __attribute__ ((signal,used, externally_visible)) ;
... I was thinking from the C perspective, but if you want to split hairs then yes, I glossed over the macro detail..
:: Morten
If ye don't mind ye arr's your bound to be eft
JIm
