AVR Programming on MAC
12 posts / 0 new
I've been programming on Arduino for sometime, and now I am starting to learn how to program the ATmega328 using AVR-C and an AVR programmer..
unfortunately it seems the process is a bit more complicated on mac (I am currently using OS X El capitan version 10.11.6) since there's no Atmel studio on mac.
I've found some resources online but it seems many of them are outdated.
so my question is, is anyone here doing AVR programming on mac? and I'd really appreciate it if anyone can provide me with links for the tools I need (IDE, etc..) so I can start writing C code and upload them to the ATMega through the USB AVR programmer that I have.
The Arduino installation already has avr-gcc for you. You can simply use native constructs on Arduino.
Arduino gets the program into the device but you get NO simulation or debugging. So, with a Mac, you are a second class citizen. Basically same problem with CodeBlocks and other IDEs for gcc.
I got a Win laptop, talk to it with TeamViewer & DropBox, and do almost everything "on" my Mac, especially editing with good editor like TextWrangler.
CrossPack can be built via Xcode 5 :
https://github.com/obdev/CrossPack-AVR (AVR GCC 4.9.2 plus Atmel 3.5.4, AVaRICE 2.13, AVRDUDE 6.3)
via
https://www.obdev.at/products/crosspack/index.html
AVR Arduino is supported in embedXcode :
http://embedxcode.weebly.com/supported-boards-and-ides.html
IIRC from an older operator's manual, embedXcode has an AVR GDB command line interface (no Xcode GDB GUI)
Might browse its current manual for debugger capabilities.
PlatformIO can run on macOS but AVR GDB was removed :
http://platformio.org/platforms/atmelavr
A recent update added ATmega328PB.
PlatformIO doesn't have an Xcode integration though it may integrate with other macOS compatible IDE :
http://docs.platformio.org/en/latest/ide.html
https://github.com/obdev/CrossPack-AVR/blob/master/mkdist.sh
http://embedxcode.weebly.com/download.html
But none of those gives you debugging (or "only" GDB)!
have to wait a bit, until MPLABX fully intergrades AVR  check -> https://www.avrfreaks.net/forum/c...
MPLAbX is cross compiled between WIN/ MAC / LINUX
A build of CrossPack appears to have AVR GDB and AVaRICE.
embedXcode has a GDB interface though not integrated into Xcode.
embedXcode
Editions
http://embedxcode.weebly.com/editions.html
(embedXcode+, Additional Features, External debugger)
Edit : typo
AVR GDB restored :
Add GDB to build environment
https://github.com/platformio/platform-atmelavr/commit/b593f9e33cbab9337d9e1c6d31594422e70b03fd
and an Atmel-ICE / EDBG / mEDBG capable AVaRICE is in-work :
Debug probe support for atmel-ice / dragon and atmega328p processor #53
https://github.com/platformio/platform-atmelavr/issues/53
Edit : AVaRICE
I discovered PlatformIO very recently and it seems a wonderfull solution.
It let's you use your favourite editor / IDE (I believe "sublime" is popular on mac, but it's not free).
You can also easily start projects with either "plain" GCC / C / C++ or you can use the arduino framework.
PlatformIO also has a database with 1800 browsable / installable libraries.
And if you dive into it, you will have your first project going within half an hour (If you have any previous programming experience).
I run Parallels on my Mac and run Windows that way.  Just too many useful tools that are Windows-only.
