Did anyone experienced Bus/Memory faults or incomplete NOR flash transfers via XDMA from QSPI unit in SPI mode? This only happens if target memory is SDRAM, but works fine in internal SRAM. However memory tests are passing on the SDRAM and MPU is configured as full access and INNER_NORMAL_WB_NWA_TYPE( NON_SHAREABLE ). I, D Cache are disabled.
Best regards,
