[Moderator's note: as that thread is sticky now, please
avoid followups here. Rather open your own new thread
instead.]
*** YOU MUST LOG IN TO DOWNLOAD THE SCRIPTS ***
*** Experimental DEBUGGING of XMEGA's is supported on Linux. But the full protocol is still an Atmel secret.
See : https://www.avrfreaks.net/index.p...
Now also as a .deb install package ... Read further on below
Here is a list of Linux tools & tips i use on Ubuntu
Guyzz i have succeded in building avr-gcc-4.3.4 w. avr-libc-1.6.8 , and Jörg's latest patches on my Ununtu 10.04
I'm only testing on the latest Ubuntu LTS.
All other version & distro's , are not guaranteed to work/compile. I'll try to help out , and so will the forum i'm sure. But don't demand support if it doesn't work , just ask nicely in the forum
I am enclosing the scripts i use (credits of A. Erasmus) , if they could be of any use
The steps are these:
Read Readme.txt
Then install the packages listed in pre-reqs.txt.
Note !!
Don't try to call the scripts from another directory location , always execute from same directory where the scripts are located.
The current scripts uses recursive deletes , that could erase the harddisk if the above isn't honored.
Then....
1: Make sure you are root (blushing) , or use sudo
2: Make a working directory , where you extract the files from the archive.
3: If desired edit the buildavr-no-insight.sh file , to change the prefix .. default is : prefix=/usr/local/avr
4: Make sure that the prefix dir is empty or nonexisting
5: Run : chmod +x *.sh
6: Run : ./getfiles.sh
7: Run : ./get-patches.sh
8: Run : ./buildavr-gdb.sh
9: Run: ./buildavr-toolchain.sh
You just answer yes to the existing directory question in step 9.
When building is done , you might want to free around 500MB of diskspace by removing the sources and binaries used to make avr-gcc.
To do so Run: ./buildavr-cleanup.sh
Note this little script expects the "build prefix" to be /usr/local/avr/
Edit:2
I have an avr user on my Linux-box for doing avr development , i have added this to my .bash_profile in my /home/avr directory , it sets up the path to avr-gcc.
# User specific environment and startup programs
PREFIX=/usr/local/avr
export PREFIXPATH=$PATH:$HOME/bin:$PREFIX/bin
export PATH
The script builds avr-gcc-4.3.4 w. binutils2.20 and then avr-libc-1.6.8
The script now also automaticly builds avarice-2.10 and avrdude-5.9 , as per request of Jörg.Note : gcc-4.3.x uses the GMP & MPFR libs , in order to function. So make sure to install the packets mentioned pre-reqs.txt
avr-insight is upgraded to ver 6.8 witch builds ok on 64-bit machines , and it has its own buildscript (buildinsight.sh) , as it takes ages to build.
Use: tar xvzf to extract it if it's a .tgz file, or unzip if it's a zipfile.
Just ansver yes if any of the scripts says that /usr/local/avr exists (ie. when building insight after gcc or the other way around.
But always delete /usr/local/avr before you are making a total/new rebuild.
Updated the scriptfiles to build binutils and insight without the -Werror flag. This was caused by GCC 4.3.x (on Ubuntu 8.10) being unable to build the targets. And was due to a lot of new warnings being enabled by default.
@20-jun-2009
Upgraded the "old" script building avr-gcc-4.2.2 to build avr-gcc-4.2.4 ... "Jörg did all the patches".
4.2.2 could produce more compact code in some cases.
@14-jul-2009
Upgraded the script to build avr-libc-1.6.7 and avrdude-5.8 , no changes to avr-gcc.
As usual "Jörg & the others" did all the hard work.
@12-aug-2009
Upgraded the avr-gcc-4.2.4 script to build avr-libc-1.6.7 and avrdude-5.8.
Also applied a "Hotfix patch" to binutils , to avoid a relocation error in the AVR25 architecture (tiny85 etc).
Everybody is urged to rebuild their toolchain
@29-0ct-2009
Updated the avr-gcc-4.1.2 binutils 1-17 avr-libc-1.46
script , as it failed in makeinfo.
Moved the updated script to this post
@03-Nov-2009
Updated the avr-gcc-4.3.3 script , with an avarice patch , to fix a problem when building with "native" gcc 4.4.1
@01-Dec-2009
Made a Debian/Ubuntu ".deb" install package containing the binaries build with the above 03-Nov-2009 script.
Read more here
@17-Dec-2009
Updated the ".deb" install package , w. a new avrdude binary , containing a PDI patch. (See .txt file in the download site)
Read more here
@16-Jan-2010
Updated the avr-gcc-4.3.3 script , to build avrdude-5.9
Removed the two "interrim avrdude patches" , as 5.9 should fix that.
All other remains unchanged.
The script still includes the "AVR25 relocation fix" patch , and the avarice patch
@18-Jan-2010
Updated the ".deb" install package (named 16-jan-2010) , w. avrdude-5.9. (See .txt file in the download site)
Read more here
https://www.avrfreaks.net/index.p...Get the package here.
http://www.wrightflyer.co.uk/avr...
@26-Jan-2010
Updated the scriptfiles and the ".deb" install package to 26-jan-2010 , Added avrdude-5.10 , all other unchanged.Get the package here.
@25-Feb-2010
Made a "Special Static" version , with the patches from WinAVR-20100110-install.exe , so it should be compatible.Should be installable on both 32-bit & 64-bit versions.
See https://www.avrfreaks.net/index.p...Get the package here.
@09-Mar-2010
Updated the avr-gcc script , to build avr-gcc-4.3.4 and binutils-2.20.
Added 2 patches to avr-insight/avr-gdb.
Added a builtins.h file in the builddir , see readme for useAdded a package-versions file , now versions are only maintained in that file.
Added a new "automatic" way to patch binutils , gcc & insight.Thanx to Jörg the linux (FreeBSD) build , now has the same patches as WinAVR-2010. A big thankyou to Jörg & EW.
Also uploaded as .deb package avr-gcc-4.3.4-avrfreaks-09-mar-2010.deb
@30-apr-2010
Rebuild the 09-mar-2010 packages on Ubuntu 10.04 LTS
This time i have a x64 system , so i build both 32bit (i386) and 64bit x64 packages.Uploaded as .deb packages here
Only toolchain change is : Updated insight from 6.8 to 6.8-1
@04-jun-2010
Updated buildscript to build avr-insight to 6.8-1
No other changes , and no new .deb's as the 30-apr deb's allready contains that.
@12-sep-2011
Did a rebuild of the old trusty avr-gcc-4.3.4 toolchain , with avr-libc-1.7.1 and avrdude-5.11 - avr-insight has switched from 6.8-1 to 6.8-1aHad to do a "kludge" in order to build avr-insight , ad the file is named 6.8-1a , but it extracts to 6.8-1 directory
Run ./repack-insight.sh , before ./buildinsight.shRemoved all the rm -fr * , from the buildscript
See readme in zipfile
Also uploaded .deb files to http://www.wrightflyer.co.uk/avr...
@20-sep-2011
Updated the 12-sep-2011 package (see install instructions there)avrdude updated from 5.11 to 5.11.1 (Serious Bugfix)
avarice updated from 2.10 to 2.11 )minor compilation issues)See readme in zipfile
@29-dec-2011
Updated the buildscript with the latest patches from the FreeBSD repos (Thanx Jörg)avr-gcc updated to 4.5.1
avr-libc updated to 1.8.0
binutils updated to 2.20.1
avarice updated to 2.12
insight replaced with gdb 7.3.1See readme in zipfile
More info & comments should go here
https://www.avrfreaks.net/index.p...05-jan-2012
@08-mar-2012
Updated the buildscript with suggestions/patches from Axel W. (Uracoli)
The suggestions makes the get-patches.sh script more secure , and improves on the buildavr-cleanup.sh script.The resulting toolchain is the same as the 29-dec-2011 TC.
Thanx Axel.
@26-feb-2013
Updated the buildscript with working file mirrors
@30-nov-2013
Updated the buildscript to build :
avrdude 6.0.1 (Thanx Jörg)
avr-gdb 7.6.1
@26-apr-2014
avrdude 6.1 (Thanx Jörg)
and included the patches in the zipfile
So skip the get-patches.sh step
/Bingo
