sending commands and parsing responses on serial
4 posts / 0 new
Hi, I'm using n ATMEga328P to send commands to a ESP8266 via USART. I wrote some code to send commands and receive responses using two FIFO circular buffers (one receive buffer and one transmit buffer), and USART interrupts take care of sending/receiving data.
(the usual stuff). The ESP module receives a command and responds either with a response and OK\r\n or with ERROR\r\n. I'm checking the RX buffer after every command to see what response i got. I implemented a find(const char*) function that looks for a specific string of characters in the receive buffer, consuming the characters as it goes through them and blocking until it finds the string.
Now, this leaves me with this problem: I want to check wheter I received OK or ERROR and THEN parse the response, but the find function consumes the characters in the buffers (it calls a function USART_receive() that gets the char from the queue).
In general, how can I handle serial communication with such a module? (It will come in handy with BLE or GPRS modules as well...) in a robust fashion?
So why not extract to a second buffer (usually up to \n), do the strcmp() and then any other required processing.
Another approach is a character by character state machine.
BTW, if you are in charge of this protocol why complicate it by sending whole "OK" / "ERROR" (such things are designed for humans not computers). It'd be far simpler to send a one byte ACK/NAK.
I'm using the Expressif standard AT firmware, so I'm trying to parse the protocol they provide
because I want to look for OK and then for ERROR if I don't get an OK.
What's the general approach (if any) in these situations?
Do you mean, specifically, AT Commands?
If so, see: https://www.avrfreaks.net/comment... - includes a link to an ESP8266 AT Command handler.
See also: https://www.avrfreaks.net/comment...
EDIT
Should've read the whole thread first - now I see you are using AT commands!
In that case, the links will certainly give you plenty to go on.
