Atmega644 Lcd Interfacing issue
51 posts / 0 new
Hi everyone;
                     I am working on a project using ATMEGA644 DIP. In this I have written a program for LCD interface which is working fine in Proteus simulation, but on the hardware it is not giving me any response on LCD. As I observed may be my micro controller is not set on the external clock or it can be any other issue also, same program is working fine with ATMEGA32 with 16 Mhz external oscillator. Please help me out. Thanks in advance.
Show code
Show fuse values
Show schematic
Instructions on How To Post Code and How To Post Images (eg, schematics)
Here: https://www.avrfreaks.net/comment...
Thanks for the response. Here is my my code.
// My LCD library
#include <util/delay.h>
#include <stdlib.h>
#define rs PC0
#define en PC1
void lcd_displays (char *str)
unsigned int sd[7]={0x02,0x28,0x0F,0x06,0x80,0x01};
char ar1=0,ar2=0;
char ch1=0,ch=0;
for (unsigned int k=0;sd[k]!=0;k++)
ar1=sd[k];
ar2= ar1 & 0xF0;
PORTC=ar2;
PORTC&=~(1<<rs);
PORTC|=(1<<en);
_delay_ms(1);
PORTC&=~(1<<en);
_delay_ms(1);
ar2= ((ar1<<4) & 0xF0);
PORTC=ar2;
PORTC&=~(1<<rs);
PORTC|=(1<<en);
_delay_ms(1);
PORTC&=~(1<<en);
_delay_ms(1);
for (unsigned int j=0;str[j]!=0;j++)
ch = str[j];
ch1= ch & 0xF0;
PORTC=ch1;
PORTC|=(1<<rs);
PORTC|=(1<<en);
_delay_ms(1);
PORTC&=~(1<<en);
_delay_ms(1);
ch1= ((ch<<4) & 0xF0);
PORTC=ch1;
PORTC|=(1<<rs);
PORTC|=(1<<en);
_delay_ms(1);
PORTC&=~(1<<en);
_delay_ms(1);
_delay_ms(1);
// Main code
int main()
        DDRC = 0XFF;
        lcd_displays("PRINT ON LCD");
        _delay_ms(5000);
Your LCD is connected to PortC which is also the JTAG port which you've left enabled.
"How have you proved that your chip is running at xxMHz?" - Me
"If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand." - Heater's ex-boss
1.  Excellent strategy to test first with Proteus before assembling hardware.
2.  Even better that you have shown your fuses.
3.  You have chosen the default fuses.   This means JTAGEN.
4.  You are using PC4, PC5 which are JTAG pins.
5.  Either disable JTAG in software with JTD.
6.  Or remove the JTAGEN fuse.
Some general advice:
7.  use CODE window when posting code
8.  format the code neatly.   this makes your code attractive to read.   Most importantly,  you will find it easier to understand.
p.s.  read the datasheet to see how to use JTD.
Thanks for reply. Sorry for asking this how should I disable JTAG. I am new to this micro controller.
Dear All;
             Thank you very much issue is resolved by disabling JTAG.
Shame that Proteus doesn't spot the JTAG issue - I'd say that's a pretty serious flaw.
Or, better still use the JTAG pins for JTAG!!
Having a device with on-chip debug and not using it is pure folly. You are tying your own hands behind your back!
As was explained in #3
+10
One more thing I required to know. How to set atmega644 for using external crystal on 16 Mhz frequency.
Abhay02 wrote:
How to set atmega644 for using external crystal on 16 MHz frequency.
David's PS answers this:
p.s.  read the datasheet to see how to use ...
Reading the datasheet should be your first step in finding out how to use any feature of any chip!
Hi David;
             I have tried after making CKSEL3..0 pins disable but still micro controller is not using external crystal.
On the contrary - I applaud Proteus for getting the simulation right - it spotted that JTAGEN was enabled so prevented C4..7 being using as normal IO. (just like would have happened in the real silicon).
But he said it worked in Proteus?
Oops, must learn to read, must learn to read .... blush
How are you determining that it is not using the external crystal?
Tell us the precise fuse values (preferably as read out in hexadecimal).
When i am printing a long string on LCD it's speed is slow but when I am using atmega32 it is prining the same string in good speed with same crystal and same program.
Those fuse values seem to be for internal RC oscillator.
Double check with this: http://www.engbedded.com/fusecalc
I have made CKSEL 3..0 as 0000 but still not getting the required output at 16Mhz.
I have made changes in fuse values and my both micro controllers are showing "Programming failed".
That could be bad or really bad. Locate the tutorial "Resurrecting a bricked AVR" (or a title similar to that) in the Tutorials forum here at AVRfreaks and read.
Unless you've messed with the SPIEN fuse there are relatively simple ways to fix it.
Lesson to be learned: Do not fiddle with fuses unless you are absolutely sure of what you are doing. (If you need to ask yourself "How do I know if I'm sure?", then you're not.)
Can you please tell me the exact fuse values to set it on External crystal of 16 Mhz??
While trying to set the atmega644 on external crystal I messed up with fuse values. Now I am getting this error. Is there any solution available for this issue??
Three posts up I told you to go locate a tutorial here on AVRfreaks and read it. With 99% certainty it applies to your problem. In fact, the situation you're in is so common someone decided to instead of answering every time the question was asked, to write a tutorial covering it. Depending on things unknown to both us and you ATM, there is no one distinct solution to your problem. It will be a matter of trial and error. Read the tutorial for the details.
No, no-one will re-type the test of that tutorial just so that you will not need to locate and read it in it's current place.
For the ATmega644, and everything default except clock source which was selected to be
 Ext. Crystal Osc.; Frequency 8.0- MHz; Start-up time: 16K CK + 4.1 ms; [CKSEL=1111 SUT=10]
engbedded.com computes the fuse byte values to:
Low: 0x7F
High: 0x99
Extendec: 0xFF
But this leaves your CLKDIV8 switch still programmed, so the ATmega644 will run 8 times slower than the crystal. clearing the CLKDIV8 engbedded.com computes
Low: 0xEF
High: 0x99
Extendec: 0xFF
But, since you likely have "bricked" your AVR (by programming some unknown but really bad fuse values) you first need to try to fix that, as described in the thread i linked to above.
