Wireless Power Transmission – A Next Generation Power Transmission System
37 posts / 0 new
In this paper, we present the concept of transmitting power without using wires i.e., transmitting power as microwaves from one place to another is in order to reduce the transmission and distribution losses. This concept is known as Microwave Power transmission (MPT).
Suggestions are welcome !!!
gud day
I suggest you post the text, not in a .doc file.
Actually i read the document. Methinks it is bollox - it's rather light on fact.
Hi venkatrajpravin
You write:
Common beliefs fear the effect of microwave radiation. But the studies in this domain repeatedly proves that the microwave radiation level would be never higher than the dose received while opening the microwave oven door, meaning it is slightly higher
than the emissions created by cellular telephones.
That's absolutely nonsense. Microwave ovens turn off when you open the door, resulting in zero radiation. Cellular phones transmit less than 2 watts. Power grids would transmit megawatts, resulting in immediate death of anybody getting in the way.
Besides: microwaves will have huge losses at distance due to problems with focussing.
Kartman wrote:
bollox
I love scientific analysis cheeky
We'll be cooked soon as soon  before getting power.
I could not open the document because of unknown fonts.
edit:
Do you intend to design a HAARP ?!!
Nicola Tesla tried and failed on this one. Inverse-square kills you, even with beamed microwave.
<edit> There is also a major regulatory hurdle. All of the frequencies outside of water absorption bands are highly sought for data transmission. Microwave data people will fight to the death to prevent anything like what you propose from happening. If you try other frequencies, the water absorption loss will kill you worse than inverse square.
Sorry, but it is simply not a good idea. Too little to gain for a lot of loss. </edit>
Hey, I've already built plenty of those in the past cheeky
Microwave Power Plant
 The Microwave Power Plant is an advanced power plant in SimCity 2000 and SimCity 3000. In all it's appearances, the plant takes on the form of a giant receiver dish and operates by receiving microwaves beamed down by orbiting satellites that collect solar energy in space.
SimCity 2000
The Microwave Power Plant is the second to last power plant unlocked in SimCity 2000. The plant produces slightly less power than a Nuclear Power Plant but without the risk of a catastrophic meltdown. However there is a risk; albeit rare that the microwave beam will miss the dish and start a small fire near the plant, however this can be easily contained unlike a meltdown. Like all power plants it will explode after 50 years of use.
 ....in order to reduce the transmission and distribution losses
I think copper wire or a superconductor has you beat.
You will find that the language use in the document is varying greatly. Some excellent English, some less than stellar. Pick any of the perfect English formulations and feed into Google, and you will find, with a high likelihood, that the formulation has been ripped off some web-site without attribution or reference noted.
+1 on Jims post above.
@OP: Contact Andrea Rossi. He'll be interested..
Apparently there is a flattened forest in Russia that says he succeeded, but who really knows, all his stuff disappeared from the Astoria hotel basement after his death.
The amount of research that went into this is staggering. It's a bit like fusion power, forever 20 years into the future.
Look at the amount of papers on the subject: https://scholar.google.pt/schola...
One of the other hurdles is the simple conversion between power forms. Typical microwave transmitters, these days, are quite on the low side of 50%. Microwave receivers that can handle any power quantity (say, more than a few milliwatts) are all just diode rectifiers. At low power power levels (under a few watts), the diode forward junction voltage eats you. At higher levels, you have the basic incompatibility between thin junctions (for microwave frequencies) and high reverse breakdown voltages.
These factors might be surmountable given sufficient time and coin of the realm, but it will be neither easy nor quick.
John,
There is mention that Tesla did live at the Waldorf Astoria briefly, but he died at the Hotel New Yorker:
http://www.teslasociety.com/hote...
There has been rumors abound as to what happened to them but I a not going to get the thread locked.
Oh I find it funny the OP has not defended the paper....someone plant some fresh meat for us to feed on? devil
I believe that there are "wireless" loudspeakers around that get power over the air maybe a metre or 2 away from the sender and of course audio data over normal means (Bluetooth??).
The only Wireless power I have seen is the NFC charging docks for Android cell phones.  And that is very slow charging compared to being plugged into a charger.
Yep... the whole topic is (practically) hogwash.
I would never try to defend a paper like that because I would never write it! Sorry, but to me, it has all the hallmarks of "magical thinking".
Well, my toothbrush charges wirelessly.
And there's these:
https://www.adafruit.com/product/1407
But microwaves?  Until someone can come up with a high-efficiency high-power maser, and a high-efficiency high-power receiver/rectifier, this will always be '20 years away'
"today's science fiction is tomorrow's science fact" - there's been a lot of effort put into power transfer, so I'd expect if big breakthroughs are going to happen, it won't be with the more obvious techniques that have been tried already.
joeymorin wrote:
And there's these:
Two or three millimetres separation... oh yeah that is super useful...NOT,
Here's something: https://www.ted.com/talks/eric_g...
A few Watts over a few meters with 50% efficiency..
My memory for the exact date is a little foggy but I think it was the late '60s when I was in high school that Popular Science had the article about the exciting and awesome "rectenna".  Large arrays would receive power from microwaves beamed down by satellites.  Even then, I was well steeped in all things amateur radio, particularly vhf, uhf and microwave.  The concept seemed so absurd at the time I wondered how could it even rate being put into print.  40+ years later, we still have no wireless power transmission but lo and behold with great fanfare, the kids at MIT discovered the 'voltage doubler' and added a second diode to the rectenna 8) Can we can now expect power outputs of 'useless *4'?
Using a simple example of 3 GHz at a distance of only 10 km, isn't the path loss already 120 db? 8)
Tom Pappano
Tulsa, Oklahoma
Thank you for all your suggestions,,,being a beginner it was my first attempt on proposing papers and your suggestions are too valuable for me too improvise on such topics in future and overcome the bollox'nish feel,,the comments here was of a great learning curve for me,, Once again Thank you all !
gud day
Read up on the meaning and use of the word 'bollox'
aka "bollocks": https://www.avrfreaks.net/forum/i...
The search facility shows that there's quite a lot of bollocks on AVRFreaks...
https://www.avrfreaks.net/search/...
laugh
And there's these:
I have a couple of those, although I bought direct from China. I'm hoping to modify them slightly to charge my floating hydrometer for homebrewing. Although it might not be efficient, it should enable me to totally seal the unit. I'ts in the round tuit box at the moment...
Back on topic, Bill Brown(no relation[well, obviously we share a common ancestor if you go back far enough, but don't we all?]) at Raytheon demostrated a small flying machine, entirely powered by beamed microwave energy. I remember a picture being on the front cover of either Wireless World or Practical Wireless in the early sixties. I don't think it turned out to be very practical.
https://en.wikipedia.org/wiki/Wi...
valusoft wrote:
super useful...NOT
Well, it is convenient. And, as J_A_B said, can be of very practical use.
But not for transmitting large amount of power over long distances.
Yes. And that is not the only application/implementation of wireless power transfer. Turns out it has been in ubiquitous use for more than 100 years.
Well, one form of wireless power transmission has been in daily(!) use for 4.5 billion years.
If so, then much longer than 4.5 billion years, John.
About 13.5 billion years, if you trust NASA.
If you want some interesting reading, then Google Bendini motor. Be prepared to suspend belief. There's also plenty of youtube vids of people building these things. Warning! You'll never get that lost time back. You might also spontaneously utter verbiage such as 'bollox'!
It might also prompt you to watch cat videos. Yes, they are cute.
I was making a very conservative estimate. I'm English. We have a mild passion for understatement.
Kartman wrote:
If you want some interesting reading, then Google Bendini motor. Be prepared to suspend belief. There's also plenty of youtube vids of people building these things. Warning! You'll never get that lost time back. You might also spontaneously utter verbiage such as 'bollox'! It might also prompt you to watch cat videos. Yes, they are cute.
Bollocks.
I have actually made a Marinov motor, however. Very strange thing to behold, but very far from "over unity".
Yeah, but consider all of the losses. If we could just recover 0.0000000001% of that total power output we would have plenty of energy.
David
Fossil fuels are just that energy that's been stored for a while
And then you have Boris.. ;-) [I know I'm on the verge of getting banned, again and again...]
