Getting started with UTFT library
5 posts / 0 new
How must the code be setup to use the UTFT library?
I did change the line below to -- ILI9341_S4P ,but what is the 4 values that follows ?
"UTFT myGLCD(ILI9341_S4P  ,38,39,40,41);"
Must the atmega chip used be defined?
I am only using MOSI,CLK,DC,RST where must this be defined ,MOSI,CLK is fixed per atmega .
Can this UTFT library be used with AVR STUDIO(WIN AVR)  and /or  ARDUINO ?
Yes, you can port UTFT to a bare AVR very easily. With nothing more than a delay() function.
Mr Karlsen does not even use the SPI hardware. Just bit bashes GPIO.
Do you really want to use S4P? i.e. 9-bit SPI
No problem with bit-bash. Nightmare with SPI hardware on an AVR.
The real mystery is WHY.
Arduino works well. There are many good libraries. All of them faster than UTFT.
The biggest problem with Arduino users is understanding that 3.3V modules require 3.3V logic.
From your constructor() example it looks like you have a 5V ATmega2560.
User manual for UTFT says the constructor has two variants...
Thanks so far...i am using a small 3.3V regulator for the display and a resistor divider for the control pins.
Not so sure if i want to use the UTFT library anymore....no spi .
The arduino boards is just so portable ,no big stk500 programmer and no extra 12v psu...lots of sample code on the internet using Utft library....the only reason i am using the arduino boards is its small, doesnt need a programmer,all the main components is already fitted and the price.
I need a library that will work on avr studio and arduino.
The Utft library specify the SDA.CLK.CS.RESET.RS what pin is the DC(data/command) pin CS or RS?
Any Arduino "library" will likely "work in Atmel Studio". Arduino code is C++ which Studio also can handle.
