passing 16-bit parameters to Atmel Macroassembler
5 posts / 0 new
I saw some old posts on this topic but no resolution.
Some people said that you can't pass 16-bit parameters to a Macro.
But you certainly can. Here are some examples that work:
; LOAD Z-REGISTER IMMEDIATE
.MACRO LDZI
LDI R30, LOW(@0)
LDI R31, HIGH(@0)
.ENDMACRO
LDZI ARRAY_START_ADDRESS ;  ARRAY_START_ADDRESS IS AN ARRAY DECLARED IN DSEG. THIS WORKS FINE
.EQU PHOTOCELL_QUIESCENT_VOLTAGE=1019
LDZI PHOTOCELL_QUIESCENT_VOLTAGE        ; NOW WE ARE GETTING IT TO ACCEPT 16-BIT CONSTANTS DECLARED WITH AN .EQU AND IT WORKS FINE
So when the code in the .MACRO is LDI it seems to work fine with either 16-bit addresses passed as a parameter or 16-bit constants declared by an .EQU
It also allows you to pass the address of a label in your code, for example
 RESUME1: ....SOME ASM CODE....
 LDZI RESUME1
 PUSHZ_BIGENDIAN
I use the above to push a return address on the stack when I want a subroutine call to return to different places
depending on the outcome of a calculation, and it works fine.
So it seems we can pass 16-bit constants, RAM variable addresses or code labels fine.
But this does not work:
.MACRO SUBTRACT16
SBI R22,LOW(@0)
SBCI R23,HIGH(@0)
.ENDMACRO
.EQU PHOTOCELL_QUIESCENT_VOLTAGE=1017
SUBTRACT16 PHOTOCELL_QUIESECENT_VOLTAGE
But this does work:
.MACRO SUBTRACT16
LDI R30,LOW(@0)
LDI R31,HIGH(@0)
SUB R22,R30
SBC R23,R31
.ENDMACRO
so my question is: Why does it work when the  .MACRO receiving the parameter is just doing an LDI with it
and does not work if it is using the passed parameter as an immediate with some other instruction that would normally
happily accept such immediate constants outside of the .MACRO?
What are the rules and where can I find them written down?
The only documentation is the user manual, it isn't very detailed.
CANCEL CANCEL!
I found the answer to my own question.
Further experiments show that you CAN pass 16-bit parameters to all instructions that normally accept immediate constants.
The problem with my code above that did not work is that there is no "subtract immediate" instruction in the ATMEGA.
SBI means "SET BIT IN IO REGISTER" !
You have to use two instances of SBCI, with carry clear for the first one, to do a 16-bit subtract.
Now it seems that you can pass 16-bit parameters to .MACROs in all circumstances!
Yet another revision of the above:
There IS indeed a "Subtract Immediate" (with no carry instruction on the ATMEGA)
It's somewhat further down the list.
Some mnemonics are so similar it was confusing me. Here they are:
SBI    = set bit in I/O register
SBIC  = Skip if bit in IO register is cleared
SBCI = subtract immediate with carry
SUBI = subtract immediate
SUB  = subtract two registers
SBC = subtract two registers with carry
I guess I need some more caffeine
There seem to be some issues with macros that work in "normal" AVRs but no longer work with Xmegas or newer AVRs, I started a test USART project about a week ago for someone here but the macros failed.
Since I no longer care I haven't investigated further. surprise Maybe one day I will.
