Reading ADC channels in Same70 Xplained board
17 posts / 0 new
I am having problems reading the ADC channels on the Same70 Xplained board that I am experimenting with. I can read the ADC channels but the values read does not make sense. I am reading AFE0_AD0 channel on EXT2, and despite grounding the signal the ADC values read 4095. I tried using AFEC_SetAnalogOffset() to remove the offset and although this changes the values read, I cannot get a reading that makes sense to me. I believe that I am missing something here that I can't put my finger on. Any help with debugging this issue would be greatly appreciated.
-Thanks!
We seem to be missing the code, kinda hard to tell what is wrong when you don't show the code???
Code:
    /*INITIALIZE AFEC0 FOR DIFFERENTIAL MODE, USER SEQUENCED, NO ANALOG OFFSET, SW TRIGGER, EOCx INTERRUPT, "afec_EOC_handler"*/
    afec_enable(AFEC0);
    struct afec_config afec_cfg;
    afec_get_config_defaults(&afec_cfg); /*AFEC0 defaults settings changed in "afec.c"*/
    afec_init(AFEC0, &afec_cfg);
    afec_set_trigger(AFEC0, AFEC_TRIG_SW); /*Software Trigger*/
    struct afec_ch_config afec_ch_cfg;
    afec_ch_get_config_defaults(&afec_ch_cfg);
    afec_ch_set_config(AFEC0, AFEC_CHANNEL_0, &afec_ch_cfg);
    afec_ch_set_config(AFEC0, AFEC_CHANNEL_1, &afec_ch_cfg);
    afec_ch_set_config(AFEC0, AFEC_CHANNEL_2, &afec_ch_cfg);
    /*Enable all associatd channels*/
    afec_channel_enable(AFEC0, AFEC_CHANNEL_0);
    afec_channel_enable(AFEC0, AFEC_CHANNEL_1);
    afec_channel_enable(AFEC0, AFEC_CHANNEL_2);
    afec_channel_set_analog_offset(AFEC0,AFEC_CHANNEL_0,0x200); //*Tried with varies offset values
    /*Set user sequence for AFEC*/
    afec_configure_sequence(AFEC0, chan_list,3);
    /*SET AFEC CALLBACK FUNCTION*/
    afec_set_callback(AFEC0, AFEC_INTERRUPT_EOC_2,afec_EOC_handler,1);
I have the same issue, by using the same code, I get eronous values around 4095.
Did you find the trick?
SAME70's FAN
I've been attempting to also use the sequencing feature of the AFEC and also only see values such as 4095 (0xfff).
Is AFEC channel sequencing known to work at all ??
--Charles Johnson
ZIncFive, Inc.
Need to see a complete set of code showing the output.
I have a Same70 Xplained board and can read 2 channels (2 & 5)'
Now reading 4 channels.
Without sequences.  reading channels 0,1,2,5  works correctly.
Enabling sequencing, sequence 2,1,0,5 doesn't work.  Channel 5 interrupt doesn't trigger.  Values are correct in the AFEC sequnce 1 register.  But debugger shows no channel 5 interrupt.
Changing the sequence to 5,2,1,0 works correctly.  Using channel 0 as the trigger.  But the channel 5 interrupt shows up.
Hi ,
I am also facing the same issue. Only 4095 values can be seen.
Can anyone help ?
int32_t ul_vol;
int32_t ul_temp;
sysclk_init();
board_init();
configure_console();
puts(STRING_HEADER);
afec_enable(AFEC0);
afec_channel_enable(AFEC0, AFEC_CHANNEL_10);
afec_set_trigger(AFEC0, AFEC_TRIG_FREERUN);
afec_ch_cfg.gain = AFEC_GAINVALUE_0;
afec_ch_set_config(AFEC0, AFEC_CHANNEL_10, &afec_ch_cfg);
afec_channel_set_analog_offset(AFEC0, AFEC_CHANNEL_10, 0x200);
struct afec_temp_sensor_config afec_temp_sensor_cfg;
afec_set_callback(AFEC0, AFEC_INTERRUPT_EOC_10,afec_temp_sensor_end_conversion, 1);
while (1)
ul_vol = g_ul_value * VOLT_REF / MAX_DIGITAL;
ul_temp = (ul_vol - 720)  * 100 / 233 + 27;
printf("ADC (int)ul_vol is: %4d\r", (int)ul_vol);
is_conversion_done = false;
outside main
static void afec_temp_sensor_end_conversion(void)
g_ul_value = afec_channel_get_value(AFEC0, AFEC_CHANNEL_10);
printf("Direct Value: %4d\r\n", (int)g_ul_value);
is_conversion_done = true;
Santosh
@Santosh please keep in your own thread: https://community.atmel.com/foru...
:: Morten
