Linker command to append user data section at end?
3 posts / 0 new
Hello
I know, that I can tell the linker to add a new section to a given fixed address for example with the following linker command:
-Wl,--section-start,.FPGA_DATA=0x00010000
But in this way, I have either a gap of unused FLASH-memory between the application and my data section, or if my application is growing, it could overlapp with the user data section. This is not a serious problem, since the linker does generate a warning or error, if it occures.
Nevertheless, is there a way to tell the linker to append my data section just at the end of the application, respectively immediate after the .text section?
Kind regards Peter
Why not simply embed it into the existing progmem section?
Otherwise, I think you have to write up your own linkerscript.
Jörg Wunsch
Because then the progmem data range will grow over the 64 kBit limit and I don't know which datas I have to access with ELPM instructions.
And I am not sure if the compiler is aware to use ELPM, to initialize its .data section in the RAM, if the data init-contents is stored in FLASH above 64 kByte?
If I can ensure, that the one big block is stored at the end of the existing progmem section, I have to use ELPM respectively progmem_read_byte_far() only for this big block and don't have to care for all the other datas!
[edit]
Isn't there a GCC linker variable with the adress of the progmem section end, I could use instaed a hard coded section address?
Or is it possible to allign a user defined section at the upper limit of the available progmem, something like:
-Wl,--section-end,.My_DATA=0x1E000
or maybe
-Wl,--section-start,.My_DATA=(0x1E000-My_DATA_size)
