Online update to 7.0.1417 craves Windows update KB2978092.
24 posts / 0 new
EDIT: I could have sworn the problem described below made selecting Next in the wizard impossible. Somewhere during my trials it went enabled though the KB is still craved. Meanwhile I downloaded the offline installer (as I always have done in the past) and am currently running that. Will report on progress.
Still puzzled about the unavailability of the KB and that MS serves me something marked Windows6.1 when I claim Windows7...
Original post:
Today I attempted an online update of Atmel Studio for the first time. Telling Atmels Studio to look for updates eventually led to downloading as-installer-7.0.1417-web.exe . Upon running that it protests that I need Windows Update KB2978092:
This update is not listed in my Windows Update.
So I download according to the URL given in the sceenshot above. I carefully choose the update fitting my machine:
I end up with a file named Windows6.1-KB2978092-x64.msu . Notice the "6.1".
When I try to apply that file I am informed that it "does not apply" to my system.
Here's my system properties:
Could someone cast a second eye eon this and see if I missed something?
I tried searching for others with this problem, but came out empty. Anyone recognize this from any previous thread here?
Are you there Morten? Help!?   ;-)
The warning is benign... Some of the cumulative updates from Microsoft fails to register the actual hotfix that we require/suggest (KB2978092 in this case, which fixes issues with the WARP acceleration for fallback rendering).
We have seen this a couple of times before and we try correct them retroactively (i.e too late... frown)
:: Morten
My copy of Windows 7 SP1 Pro has KB2978092 but its baseline was from HP approx 2015-March (after KB2978092)
Windows 7 can have patchwork updates that are consistent, patchwork updates that are not consistent, or cumulative updates (2016-Oct and subsequent)
An inconsistency is indicated by a System File Check (sfc.exe) error; if an error then attempt a fix by sfc.
Could try the System Update Readiness Tool.
Could go cumulative updates but that enables Customer Experience Improvement Program (CEIP) (diagnostics and telemetry)
https://support.microsoft.com/en-us/help/2978092/graphics-software-or-applications-crash-when-they-use-warp-for-software-rendering-in-windows
Microsoft
Microsoft
MSDN
System File Checker
https://msdn.microsoft.com/en-us/library/windows/desktop/aa382541%28v=vs.85%29.aspx
https://support.microsoft.com/en-us/help/947821/fix-windows-update-errors-by-using-the-dism-or-system-update-readiness-tool
https://support.microsoft.com/en-us/help/4009469/windows-7-sp1-windows-server-2008-r2-sp1-update-history
https://www.microsoft.com/products/ceip/en-US/default.mspx
Thanks for the information.
It's a moving target due to Microsoft Patch Tuesday that's once per month.
IIRC some Windows 7 and Windows 8.1 updates are a preview of the next month's updates (gives system administrators a heads up)
Windows 10 has the Preview ring that gives software creators a heads up before an update is released.
Hmmm, we only stop on required patches, not on suggested ones... The one you showed is optional..
SFC won't help unfortunately, it's an inconsistency in the hotpatch registration that triggers the false detection.
:: Morten
Thanks Morten!
I swear the "Next" button was disabled for several attempts to install. It "magically" got enabled - something you can see in my screenshot but which I failed to observe...
I suppose the online/web install would have succeeded at that point but I was already on my way with the d/l of the offline installer. And that succeeded, so all is well that ends well.
Anyway, you're often the unsung hero re Studio, so as a small remedy I'm now humming a tune in your honor :-) I'll mark you post about the update being optional as the solution for anyone being in the same situation, and that happens to locate this thread.
Thank you!
Hi All
I've just had exactly the same problem.
When I ran the install from a network drive the Windows Update warning appeared and the "Next" button was grey'd out.
When I moved it to the local HDD I got the warning but the "Next" button was active and the install proceeded normally.
Cheers
Stewart
Stewart
 I'm pretty sure the same thing happened to me; I started installing ALL the "optional updates", and at some point noticed that the "Next" button was actually active, but I'm not sure exactly when that happened.
In my case there is an essential update missing and I have no chance to hit the button "Next", but the update *is* installed.
I tried to update to 7.0.1417 on Win 7 but it doesn't work. AS installer says that I have to update Windows KB2999226 (essential) and KB2670838 and KB2978092 (optional), but all are installed!
I tried to deinstall the 3 updates and reinstall using Windows Update - no success. AS installer doesn't finish the installation because of the missing updates.
What's going wrong and how can I install 1417?
Hans
Edit: Sorry for double posting. While updating the browser it was sent again and I don't know how to delete it. * Done. Ross *
So here we go.   Side-by-side AS7 installer demanding particular updates, and Windows Update showing that they aren't available.
This is using the microsoft VM for Windows Explorer testing, W7 32bit (after letting it install all the mandatory updates.)
Thank you gentlemen for posting the above.  I wasted an hour or so updating (to no avail), then came here find the "Mystery of the Update Craving" revealed.  I think this has happened a time or two in the past.  I never think to just click "Next".  Thanks again!
Field the chicken, ignore the ball.
Dear support, I want to download the update KB2978092 for ATMEL STUDIO 7.0. Can you help me, please?
When I type "KB2978092" into Google it says:
https://www.microsoft.com/en-us/...
@clawson: Read the whole thread, Cliff.
The link Atmel gives, and that you also found, actually ends up with a download that seems to be for a different Windows version. Not Windows 7. At least not the Windows 7 I run.
@JoscAtma: After a couple of tries I could install Studio 7.0.1417 without the Windows update KB2978092 installed. The Next button in the Studio installer was not disabled, although the KB/update was missing.) What kind of install/upgrade did you do? Network/on-line? Or did you download an of-line installer and run that?
I downloaded the update, but it can't be installed in my computer. The Problem is that need a monitor with HDMI plug. Why I not get to install.Thank you for your assistance.
José da Conceição
And it's just happened to me, too!
It gets "un-greyed" after scrolling up & down the list of "problems" a couple of times.
(or perhaps it's just one of those things where stuff is going on in the background, and it would just change after "a while" if the user did nothing at all?)
I apologize, but I have the quite same issue and I cannot install Atmel Studio 7.0. I tried both online and offline version, the behavior is the same. It says:
Please install the following Windows Updates:
Essential Windows Updates: 1
KB2999226: https://support.microsoft.com/en...
Optional Windows Updates(Data Visualizer Rendering): 1
KB2978092: https://support.microsoft.com/en...
  (or)
Consider updating Windows from Control Panel -> Windows Update.
the "Next" button is always disabled, no matter how many times I've scrolled up and down the listbox...
BUT:
  1. trying to download the KB2999226 from https://support.microsoft.com/en... (actually from https://www.microsoft.com/en-us/...) leads to a 404 error
  2. KB2978092 refuses to install and already pointed out
  3. I ran Windows Update a lot of times but none of them were installed
I'm running Windows 7 64-bit Home Premium SP1.
 Hmmph.   I decided to try to track this down by installing the optional updates a couple-at-a-time until the Next button became enbaled, to see which update was actually helping.
I now have a W7 VM that has ALL the optional updates (except for Language Packs) installed, and STILL a disabled NEXT button...
If the button is disabled, aren't there a progress bar on one of the items in the list that isn't done yet?
:: Morten
No "progress bars" are incomplete, but there's one failure: it claims that it needs a windows update (as mentioned earlier in the thread.)   A windows update that doesn't seem to exist for 32bit Windows7?!
This is using https://az412801.vo.msecnd.net/v...
with nothing done or installed except for the windows updates, and the AS installer.
Hence, how to install AS7? Right now I'm not able to install it.... I'm completely stuck with my job...
I found this workaround (here in the forum):
launch the installer from CLI with the following argument: /SystemValidationErrorAsWarning
Not sure how to split this thread (don't think it's possible) but there are two different KB discussed. The original was 2978092 but most recently the thread is about 2999226 which leads back to:
Does the line I highlighted below not lead to a 32bit Win 7 one then?
 Ah.  I hadn't noticed that the "update in question" had changed.   If I install xxx226 (manually via the link you found; it doesn't show up in the "Windows Update" panel as either required OR optional), I get back to the state where it wants xxx092, but DOES have the NEXT button enabled...
