[SOLVED]: Restart cascaded timers
4 posts / 0 new
I'm using timers D0 and D1 in cascaded mode, to have a 32-bit counter:
EVSYS.CH0MUX = EVSYS_CHMUX_TCD0_OVF_gc;
TC_EnableEventDelay(&TCD1);
TC1_ConfigClockSource(&TCD1, TC_CLKSEL_EVCH0_gc);
TC0_ConfigClockSource(&TCD0, TC_CLKSEL_DIV1_gc);
when a criteria is met, I need to restart the counter, that is to reset it to 0, losing as little time as possible.
Because TCD0 is the least significant timer and TCD1 the most one, I think to reset first TCD0, then TCD1.
From the datasheet I'm not sure if I can just write the CNT register even if the time is running or I need to stop it first.
Issue a RESTART command to TCD0, then TCD1.  This is faster than writing CNT (single byte vs, two bytes).
Greg Muth
Portland, OR, US
Atmel Studio 7 (Version: 7.0.1652) on Windows 10
I'm not sure it's faster:
A reset can be given only when the timer/counter is not running (OFF).
So I have to:
- turn TCD0 off
- reset timer TCD0
- reset timer TCD1
- turn TCD0 on
RESTART does not require the clock to be disabled, only RESET requires that.
Greg Muth
Portland, OR, US
