Best way to demodulate an 8KHz FSK signal
32 posts / 0 new
I'm working with UC3B512 and I need to demodulate an ETSI ETS300-230 protocol sent with FSK modulation.
My input signal is sampled at 8KHz (by another device) and sent to me through an SSI bus.
I though that the best compromise in terms of speed is to use a zero-crossing detector.
Is there someone who could give me some hints on how to start from? I mean, are there some "predefined algorithms" can I use?
In attach there is a captured signal, and here its print on Audacity:
Do, or do not, there is no try.
The simplest is to square up the signal and measure the period. If the signal is subject to sufficient noise, this technique fails. A more robust technique is to use DSP techniques and use digital filtering. I find the early app notes from Texas Instruments are a good siurce of information. I'm not sure what your etsi spec refers to, but bell/ccitt fsk standards should be well covered.
The usual technique is a bandpass filter followed by a low pass filter and detect the phase change. You might need a auto gain block on the input.
8KHz might be a bit fast for a plain (not DSP) MCU. Depends on the clock rate and other required tasks.
What I get from Google is that ETS200-230 is a piece of hardware from Siemens and the serial protocol is MODBUS. You might have more success in that direction.
Jim, we're talking AVR32 here. I did 1200 baud fsk on a 40MHz ARM7 using around 2% cpu.
DBarzo wrote:
I'm working with UC3B512 and I need to demodulate an ETSI ETS200-230 protocol sent with FSK modulation.
You can use the Goertzel algorithm (Link):
The Goertzel algorithm is a technique in digital signal processing (DSP) that provides a means for efficient evaluation of individual terms of the discrete Fourier transform (DFT)
Like the DFT, the Goertzel algorithm analyses one selectable frequency component from a discrete signal. Unlike direct DFT calculations, the Goertzel algorithm applies a single real-valued coefficient at each iteration, using real-valued arithmetic for real-valued input sequences.
Hi Chuck99,
I'm using the Goertzel algorithm to decode the selective calls.
I never use it for the FSK modulation since I think the duration of a "tone" is too small.
In selective calls the tones duration is >= 40 msec while here a tone (Space / Mark) lasts >= 200 uSec
Kartman wrote:
A more robust technique is to use DSP techniques and use digital filtering. I find the early app notes from Texas Instruments are a good source of information. I'm not sure what your etsi spec refers to, but bell/ccitt fsk standards should be well covered. The usual technique is a bandpass filter followed by a low pass filter and detect the phase change. You might need a auto gain block on the input.
Hi Kartman,
in fact in this moment I using a "kind" of this.
The problem is that before I used a 20KHz sampling and the filters method worked (more or less), but now, switched to 8KHz (and re-calibrating the filters), it not works anymore.
So I thought to switch to use a zero-crossing method...
perhaps make some kind of simple auto correlation on the signal (I have used it to find the preamp in AIS)(just find the difference)
what is the freq. of the signal compared to sample rate, then it can be like a running difference.
I' didn't understand very well laugh
Can you explain more deep?
What is the FSK freq. compared to 8KHz (it's easier if a hole number)
What is the baud rate ?
The Mark   freq is 1200 Kz
The Space freq is 1800 Hz
The baud rate is 1200 bps
I don't think zero crossing will work very well in this case. A single space is 1.5 cycles, and a single mark 1 cycle. Back in the day(maybe 34 years ago), when I was really quite smart, I can remember trying to decode maritime weather fax broadcasts that had a vaguely similar relationship between carriers and baud rate, and it was an effing nightmare. Phase locked loop decoder worked much better, IIRC.
That's not to say that throwing a bit of DSP at it wouldn't work, but I was using a 2MHz 6809 s the time, and zero crossing was really the only option.
I also agree that Goertzel probably won't be any use at all. It might alert you to the presence of a 1200kHz tone  or an 1800kHz tone, but you knew that already.
Quebracho seems to be the hardest wood.
So the problem here is that the 8kHz sampling rate is far too low.
Why was that rate chosen?
"How have you proved that your chip is running at xxMHz?" - Me
"If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand." - Heater's ex-boss
Thanks a lot John for your reply!
LOL
Nevertheless smartness never die wink
Have you some points, links or other to look at about PLL decoder in C?
Maybe I can share my code, if someone is interested in this topic.
Exactly.
Yep.
The answer is little bit articulated.
To summarize, I develop on a board attached to a radio device and its forward me the PCM audio samples in different ways..
Actually I take the audio at the sampling rate is 20KHz and my decoder works, but I see some instability problems on the radio (the timing are tight), so I decided to switch to another chain point and, there, the sampling rate is 8KHz.
"Have you some points, links or other to look at about PLL decoder in C?"
'fraid not. I was talking about hardware.
one thing you have to look at is if the signal is AC coupled ! or true DC. (your problem with 20kHz could be that it's AC! )
I have decoded AIS (9600 baud GMSK) with sound sampling of 11.2KHz, but normally I use 48KHz also because that is 5 times the baudrate.
Unfortunately I cannot decide the sampling rate. It's fixed to 20KHz or 8KHz
DBarzo wrote:
Hi Chuck99,
From Wikipedia (Link):
Implementations of FSK modems
Reference implementations of FSK modems exist and are documented in detail.
The demodulation of a binary FSK signal can be done using the Goertzel algorithm very efficiently,
even on low-power microcontrollers. (FSK Modulation and Demodulation With the MSP430 Microcontroller - Link)
Edit: added missing link.
But will Goertzel work on such short amounts of each frequency? I now that it has an inherent detection time which is at least equal to the number of sample used.
Chuck99 wrote:
DBarzo wrote:
Hi Chuck99,
Good find.
Now all the OP needs to do is learn MSP430 assembler. Is that Goertzel, though? I used Goertzel(once) and it doesn't look familiar.
I report, you decide.
Good point.
From embedded.com: The Goertzel Algorithm (Link):
Block size
Goertzel block size N is like the number of points in an equivalent FFT. It controls the frequency resolution (also called bin width).
For example, if your sampling rate is 8kHz and N is 100 samples, then your bin width is 80Hz.
To get 1200 bps, the block size needs to be reduced to 6 which yields a bin width of 1333Hz which will be +/- 667Hz from center frequency.
But the Space frequency of 1800 Hz would be inside the bin (533Hz to 1867Hz), so that wouldn't work.
I guess that for a baud rate of 1200, Goetzel isn't the way to go.
If 20kHz works, but 8kHz does not, why not use 20Khz.
It seems that 1200/1800 1200baud is quite information compressed already, so cutting corners to 8kHz is not going to help ? That has far fewer sample points per-bit time. (6.66 vs 16.66)
What is the carrier lead time - your capture seems to gate the carrier ?
You could look to Phase/Frequency lock to 1200 base, and then check if there is an expected 1200 follower, or an 1800 follower
I'm guessing the modulator actually sends 1200 phase modulated too, so as to continue the 1800 slope, and the 1800 has 2 possible images, meaning you have a total of 4 'patterns' to test for 'closest match to'.
Chuck99 wrote "Good point"
And one the OP made back in post #6. Which Brian and I both agreed with.
I do think the MSP430 link has legs, though. Although it will require some time to understand exactly what's going on.
I am also fairly certain there will be other examples on the web. I just haven't found the right combination of search terms yet... Wikipedia had a Matlab example, but it made little sense to me.
I pointed out the reason here.
if you have 20kHz working why no just upsample 8KHz (either 2 2.5 or 3 times). And then run the same decoder.
"here the sampling rate is 20KHz and my decoder works, but I see some instability problems on the radio (the timing are tight),"
Maybe you could expand on this. I, for one, don't really understand what you're saying here.
So you need to tune the 20kHz solution a little ?
The main decision rate is only 1200Hz, but you need to phase align the decision boundaries, hence the questions about preamble and fixed mark times between the space modulations.
Would love to know if you made progress on this.
Hi John,
yes of course! smiley
Now I'm in holidays (finally! cheeky). I'll update my post next week when I came back to work.
PS. I start to test a zero-crossing simulation on PC...for now the result aren't encouraging.
Ok, so these are my TESTS until now.
What I actually do is quite "stupid": I calculate the length of each half-period and, when I got three of them (the mark is 1.5 period), I "decide" if it is a mark or space:
(don't take this code as "production code" :) )
    #define MARK_PERIOD(period)  (period > 800)  && (period <= 1500)  // 1245 uSec
    #define SPACE_PERIOD(period) (period >= 410) && (period <= 800)   // 530  uSec
    #define MARK_HALF_PERIOD(period)  (period > 330)  && (period <= 500)
    #define SPACE_HALF_PERIOD(period) (period >= 100) && (period <= 330)
    // "count" the number of half-periods
    if (MARK_HALF_PERIOD(half_period))
    mark_hp_count++;
    if (SPACE_HALF_PERIOD(half_period))
    space_hp_count++;
    if (++half_period_counter <= 2)
    mark_period += half_period;
    space_period += half_period;  // The space period must be calculated oly for two half-period
    if (half_period_counter == 3)
    if (MARK_PERIOD(mark_period) && (mark_hp_count >= space_hp_count))
        if (!locked)
        locked = TRUE;
        printf("\n>>> LOCKED! <<<\n");
        tot_bits++;
        printf("1");
        mark_hp_count = 0;
        if (SPACE_PERIOD(space_period) && (space_hp_count >= mark_hp_count))
        tot_bits++;
        printf("0");
        // Since the space is a period, here I have to "came back" to the previous one
        i--;
        tot_sample_count--;
        half_period_counter = 0;
        half_period -= x;
        space_period = 0;
        mark_period = 0;
        mark_hp_count = 0;
        space_hp_count = 0;
        continue;
        printf("\nERROR\n");
This approach is sensible to the semi-period threshold.
It works not-so-bad but, when the half-periods are "comparable", problems arise.
As in figure, on the second byte (0x33) my method decode the 3th bit 0 instead of 1 because count its first two half-periods as a space bit. and the "alignment problem" arise...
If someone have some suggestions... :)
Cheers.
