!!! The package of AT32uc3b0512 is not TQFP64...
7 posts / 0 new
It wasted me £15 on PCB. On Eagle software, there are 2 packages: TQFP-64 and VQFP-64. When I checked the package of TQFP64, found it not TQFP but VQFP. Because of that, The PCB boards are no longer valid.
Hope Atmel will correct the description on the datasheet.
Rather, a lesson that you must check that what your PCB tool calls "TQFP" matches the manufacturer's specification of the actual part you are using
Tis a bitter lesson I've had a couple of times. Tqfp could be 0.8,0.65 or 0.5mm pitch. I got caught once with qfp being 0.65 or 0.5 - luckily the part came in both.
SSOP too.  I corrected at least one FTDI FT230X layout that assumed SSOP-16 means 0.65mm pitch.  Apparenly 0.025 inches (0.635mm) is also a common "SSOP16" pitch.
It is a really good lesson for me. This time I re-designed the PCB with checking hundreds of times on packaging... Hope this time all will be correct.
If possible, i print out the pcb and check the actual part lines up.
I always ensure that I have all parts on hand, print the top and bottom board layouts on paper and check alignment/placement with every single component and pad. I have yet to have a design fail after sending to a board house due to improper pad layouts.
My digital portfolio: www.jamisonjerving.com
My game company: www.polygonbyte.com
