I will not ask which AVR C compiler is the best...
4 posts / 0 new
... but I will kindly ask for a list of C compilers and IDEs to use for AVR programming.
I'm very new in AVR programming, and I'm still very confused by what I found.
Right now, I'm using avr-gcc, but it already gave me a great head ake when I tried to compile a simple application for an lcd, using an lcd unit from the web.
Can you recommend smth even more user friendlu than avr-gcc? BTW... I... kinda need it to be under GPL or alike licence...
Great thanks...
On this site, go to the Tools secton, and explore from there.
Thats a good sign - everything is normal. :wink:
Please be advised that this site has a forum dedicated to talk and questions on the AVR-GCC toolchain. Make a new post there, describe your problem, attach some code and you will probably get an answer within a day or so.
You show great Internet maturity as you have read at least one of the "sticky" posts before posing your question. Kudos! Although I have no authority here, let me welcome you to this site anyway. Hang in there, ask good questions and you might very well i) have one of the times of your life, and ii) discover that ARfreaks is one of the best corners of the net!
Hey guys! Thank you! To a3v2r for sending me the compiler and to JohanEkdahl for opening my eyes.
