Why debugging "continue" jump out of forever while( 1 ) {}loop ?
24 posts / 0 new
Sir./Madam,
Could you please help me in reviewing the following to find the reason why debugging "continue" button always jumps out of the while loop to hit the break point.
Is it IRS related ?
Sincerely,
Liu Wang
_delay_us( 2000 );
//Read PSU FRU data
for ( i = 0x00; i < 0x100; i++ )
_delay_us( 8 );
read_bytes( &( superMicroI2CFRU2[ i ] ), 1, 0x72, i );
HeartBeatInit();//Stub a Break point here.
TWI_initializeBPN_SAS3_827HQ();
PWMInit( );
TACHOInit( );
TempInit( );
while (1)
PWMMonitorAndControl();
return 1;
Maybe the device does a reset and starts over? Do you use watchdog or any external reset sources?
/Jakob Selbing
What version of Atmel Studio are you running?
liu wang wrote:
Is it IRS related ?
Sorry we can't solve your TAX problems here.
Could you have enabled an interrupt for which you don't have an ISR handler for it?
Keys to wealth:
What does PWMMonitorAndControl() do?  It may have been optimized away.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
My question re version of Studio is because we found out the other day that there is a bug in binutils in the toolchaibn that comes with current (7.0.1417) Studio 7. It has to do with "linker relaxation" making debug info "skewed" w r t generated code. ("Linker relaxation" is a "late optimization").
A temporary solution might be to turn off linker relaxation. There is a setting for it in Atmel Studios settings for GCC projects.
JohanEkdahl wrote:
My question re version of Studio is because we found out the other day...
At this point, my comments are just anecdotal.  I'll typically only use GCC and Studio Simulator for issues posted here, creating tiny test programs.
I also have [anecdotally] noticed the simulator cursor disappearing inside the infinite loop.  This includes empty while(1){}.  Disassembly view shows the RJMP to itself.
I haven't looked into the relax settings, but it seems strang that the linker is involved in heavy stuff to "improve" a trivial program.
I'll have to confirm, but I thoght that 6.x whould show the cursor on the while and step-step-step.
Since time immemorial the yellow arrow has always disappeared into the RJMP of a while(1).
As I said, "relaxation" is a link time optimization. As I understand it, it replaces e.g.JMPs with RJMPs. I could envision that happening to a very simple program. Since the debug info is created before the linker does it's deed, it has to be compensated for this  - either beforehand or after the fact (I don't know which).
As I understand the reported bug, it is in binutils and somehow causes the debug info to be offset w.r.t the generated code. E.g. linker replaces JMP with RJMP, all code after that is "relocated -1 byte", debug info is not compensated (or badly compensated) to reflect this fact. Net effect is that the "current position" while debugging is constantly ahead/behind what is actually executed.
I didn't claim every "strange" debugging experience was to be blamed on this. But the bug is a fact and confirmed by people with great authority on the matter. It is a fact that moving from AS6 to AS7 in some cases makes the debugging experience degenerate considerably. It is a fact that turning off relaxation has been proven to better the debug experience for some of these cases.
It's OK to be a surly curmudgeon, but don't be anecdotal. Anecdotes are of your infamous "infinite value" since they cost nothing to emit. ;-)
Read for yourself: http://www.circuitvalley.com/201... . See especially #28 for what converts this from a fuzzy roumor or noob false speculation into a fact.
[surly curmudgeon mode]  Indeed, another apparent example of infinite-value toolchain.
clawson wrote:
Since time immemorial ...
I just love those superlatives...
Whether tis superlative kind of depends on how good your memory is. Alcohol deadens mine ;-)
That must be the optimization level -Og - Optimize Debugging Experience?
Why do I keep thinking about going back to AS6.2
What difference would it make?
Can't wait to get back to the office... ;)  Easier there than with PCanywhere.
MarkThomas wrote:
JohanEkdahl wrote:  There is a setting for it in Atmel Studios settings for GCC projects.
No, there's a setting specifically for relaxation. As Cliff explains in the thread I linked to, that is there because both the compiler and the linker needs to know if relaxation is to be done or not. If one gets it and the other doesn't then thing will go sour.
Why not go read the thread and then decide if you still want to jump the gun? [rolls eyes]
Back on Windows.. Here's the setting - in project Properties, select Toolchain, then under AVR/GNU Common, select General and there is a check-box for branch relaxation:
In the thread I linked to above some users have had better debug experiences after un-checking this option.
In my installation of VS7 (7.0.1417) that box is unchecked by default.
For debugging, do we choose optimization -O0, which seems to be the usual default choice for debugging, or the -Og:  Optimize Debugging Experience?  I guess -Og would be the obvious choice.
Oops.  Wrong again.  If I choose Debug the optimization changes to -O1.
MarkThomas wrote:
For debugging, do we choose optimization -O0 [...]?
No, -O0 is more or less meaningless since the generated code is very far from what any of the other optimization settings will produce. Highly inefficient code. Call it de-generated code if you like.
I see no golden setting that fits all when it comes to the most pleasant debugging experience. You have to tinker with settings, and be aware of what consequences this tinkering has.
  • If the debugging experience in Atmel Studio 7 gets better when unchecking the relaxation setting then probably leave it like that until the bug in binutils is integrated in a new build of the toolchain.
  • Possibly fiddle with optimization levels, but stay away from -O0.
The choice of optimization ultimately does not end with debugging. What optimization is best for you when building the final firmware (e.g. for production)? I speculate that -Os is the best fit many situations, but it just might be that -O3 produces faster code at the expense of higher flash/RAM consumption. AFAIK there's no other way than to try the alternatives out and decide in each individual project. If the -O1 makes for the most pleasant debug experience, then by all means set that one in the "Debug" build configuration. Another choice might be wiser/better for the "Release" build configuration, though.
But stay away from -O0. It has been said that it is nothing but a (non-)optimization level that only the compiler developers has any use of. The code generated is horrible.
My installation of VS6.2 has the relaxation box checked by default.  I never use -O0, and like -Os for release builds.  I tend to use the default value for debugging (-O1 in this case), figuring the builders of AS7 know better than I, but I guess I will have to play around with settings now that Johan has suggested it, even if he does roll his eyes at me and makes me feel bad.  I guess I can also compare debugging experiences between AS6.2 and AS7.0 and just use the one that works best for me.
Sir./Madam,
Appreciate all your experts comments. Sorry for late feedback.
More comments will be appreciated.
This issue is still in my way.
1. Checked WDT is not enabled.
2. Checked not hardware reset generated outside of the Atxmega128A1U under testing.
3. Atmel Studio 7.0.1417 is used.
4. Enabled all level ISR but middle level ISR is not deployed. Would it be a concern ? Will double check.
5. Setting -O0 makes the longer time to jump out of forever while(1) loop but blocks TWI peripheral operation.
6. Relax Branches was not checked.
7. Checking Relax Branches box separates the red dot break point and the yellow error.
Sincerely,
Liu Wang
But that's surely the point - there is an issue if you use -mrelax. If you avoid it the problem goes away.
clawson,
Appreciate the point.
Unchecked the relaxing and debugging keep jump out of the while(1) forever loop and zero out my data buffer.
Comments are all appreciated.
Disassembly dumped for your info.
Sincerely,
Liu Wang
Disassembly dump:
00000000  JMP 0x000000FE Jump
00000002  JMP 0x00000124 Jump
00000004  JMP 0x00000124 Jump
00000006  JMP 0x00000124 Jump
00000008  JMP 0x00000124 Jump
0000000A  JMP 0x00000124 Jump
0000000C  JMP 0x00000124 Jump
0000000E  JMP 0x00000124 Jump
00000010  JMP 0x00000124 Jump
00000012  JMP 0x00000124 Jump
00000014  JMP 0x00000124 Jump
00000016  JMP 0x00000124 Jump
00000018  JMP 0x00000596 Jump
0000001A  JMP 0x00000124 Jump
0000001C  JMP 0x00000151 Jump
0000001E  JMP 0x00000124 Jump
00000020  JMP 0x00000124 Jump
00000022  JMP 0x00000124 Jump
00000024  JMP 0x00000124 Jump
00000026  JMP 0x00000124 Jump
00000028  JMP 0x00000124 Jump
0000002A  JMP 0x00000124 Jump
0000002C  JMP 0x00000124 Jump
0000002E  JMP 0x00000124 Jump
00000030  JMP 0x00000124 Jump
00000032  JMP 0x00000124 Jump
00000034  JMP 0x00000124 Jump
00000036  JMP 0x00000124 Jump
00000038  JMP 0x00000124 Jump
0000003A  JMP 0x00000124 Jump
0000003C  JMP 0x00000124 Jump
0000003E  JMP 0x00000124 Jump
00000040  JMP 0x00000124 Jump
00000042  JMP 0x00000124 Jump
00000044  JMP 0x00000124 Jump
00000046  JMP 0x00000124 Jump
00000048  JMP 0x00000124 Jump
0000004A  JMP 0x00000124 Jump
0000004C  JMP 0x00000124 Jump
0000004E  JMP 0x00000124 Jump
00000050  JMP 0x00000124 Jump
00000052  JMP 0x00000124 Jump
00000054  JMP 0x00000124 Jump
00000056  JMP 0x00000124 Jump
00000058  JMP 0x00000124 Jump
0000005A  JMP 0x000006AC Jump
0000005C  JMP 0x00000124 Jump
0000005E  JMP 0x00000124 Jump
00000060  JMP 0x00000124 Jump
00000062  JMP 0x00000124 Jump
00000064  JMP 0x00000124 Jump
00000066  JMP 0x00000124 Jump
00000068  JMP 0x00000124 Jump
0000006A  JMP 0x00000124 Jump
0000006C  JMP 0x00000124 Jump
0000006E  JMP 0x00000124 Jump
00000070  JMP 0x00000124 Jump
00000072  JMP 0x00000124 Jump
00000074  JMP 0x00000124 Jump
00000076  JMP 0x00000124 Jump
00000078  JMP 0x00000124 Jump
0000007A  JMP 0x00000124 Jump
0000007C  JMP 0x00000124 Jump
0000007E  JMP 0x00000124 Jump
00000080  JMP 0x00000124 Jump
00000082  JMP 0x00000124 Jump
00000084  JMP 0x00000124 Jump
00000086  JMP 0x00000124 Jump
00000088  JMP 0x00000124 Jump
0000008A  JMP 0x00000124 Jump
0000008C  JMP 0x00000124 Jump
0000008E  JMP 0x00000124 Jump
00000090  JMP 0x00000124 Jump
00000092  JMP 0x00000124 Jump
00000094  JMP 0x00000124 Jump
00000096  JMP 0x0000069C Jump
00000098  JMP 0x00000124 Jump
0000009A  JMP 0x00000124 Jump
0000009C  JMP 0x00000124 Jump
0000009E  JMP 0x00000124 Jump
000000A0  JMP 0x00000124 Jump
000000A2  JMP 0x00000124 Jump
000000A4  JMP 0x00000124 Jump
000000A6  JMP 0x00000124 Jump
000000A8  JMP 0x00000124 Jump
000000AA  JMP 0x00000327 Jump
000000AC  JMP 0x0000039A Jump
000000AE  JMP 0x00000124 Jump
000000B0  JMP 0x00000124 Jump
000000B2  JMP 0x00000124 Jump
000000B4  JMP 0x00000124 Jump
000000B6  JMP 0x00000124 Jump
000000B8  JMP 0x00000124 Jump
000000BA  JMP 0x00000124 Jump
000000BC  JMP 0x00000124 Jump
000000BE  JMP 0x00000124 Jump
000000C0  JMP 0x00000124 Jump
000000C2  JMP 0x00000124 Jump
000000C4  JMP 0x00000124 Jump
000000C6  JMP 0x00000124 Jump
000000C8  JMP 0x00000124 Jump
000000CA  JMP 0x00000124 Jump
000000CC  JMP 0x00000124 Jump
000000CE  JMP 0x00000124 Jump
000000D0  JMP 0x00000124 Jump
000000D2  JMP 0x00000124 Jump
000000D4  JMP 0x000006BC Jump
000000D6  JMP 0x00000124 Jump
000000D8  JMP 0x00000124 Jump
000000DA  JMP 0x00000124 Jump
000000DC  JMP 0x00000124 Jump
000000DE  JMP 0x00000124 Jump
000000E0  JMP 0x00000124 Jump
000000E2  JMP 0x00000124 Jump
000000E4  JMP 0x00000124 Jump
000000E6  JMP 0x00000124 Jump
000000E8  JMP 0x00000124 Jump
000000EA  JMP 0x00000124 Jump
000000EC  JMP 0x00000124 Jump
000000EE  JMP 0x00000124 Jump
000000F0  JMP 0x00000124 Jump
000000F2  JMP 0x00000124 Jump
000000F4  JMP 0x00000124 Jump
000000F6  JMP 0x00000124 Jump
000000F8  JMP 0x00000124 Jump
000000FA  JMP 0x00000124 Jump
000000FC  JMP 0x00000124 Jump
--- ../../../../crt1/gcrt1.S ---------------------------------------------------
000000FE  CLR R1 Clear Register
000000FF  OUT 0x3F,R1 Out to I/O location
00000100  SER R28 Set Register
00000101  OUT 0x3D,R28 Out to I/O location
00000102  LDI R29,0x3F Load immediate
00000103  OUT 0x3E,R29 Out to I/O location
00000104  LDI R16,0x00 Load immediate
00000105  OUT 0x3C,R16 Out to I/O location
00000106  OUT 0x38,R1 Out to I/O location
00000107  OUT 0x39,R1 Out to I/O location
00000108  OUT 0x3A,R1 Out to I/O location
00000109  OUT 0x3B,R1 Out to I/O location
--- No source file -------------------------------------------------------------
0000010A  LDI R17,0x20 Load immediate
0000010B  LDI R26,0x00 Load immediate
0000010C  LDI R27,0x20 Load immediate
0000010D  LDI R30,0x3C Load immediate
0000010E  LDI R31,0x0E Load immediate
0000010F  LDI R16,0x00 Load immediate
00000110  OUT 0x3B,R16 Out to I/O location
00000111  RJMP PC+0x0003 Relative jump
00000112  ELPM R0,Z+ Extended load program memory and postincrement
00000113  ST X+,R0 Store indirect and postincrement
00000114  CPI R26,0x00 Compare with immediate
00000115  CPC R27,R17 Compare with carry
00000116  BRNE PC-0x04 Branch if not equal
00000117  OUT 0x3B,R1 Out to I/O location
00000118  LDI R18,0x28 Load immediate
00000119  LDI R26,0x00 Load immediate
0000011A  LDI R27,0x20 Load immediate
0000011B  RJMP PC+0x0002 Relative jump
0000011C  ST X+,R1 Store indirect and postincrement
0000011D  CPI R26,0x49 Compare with immediate
0000011E  CPC R27,R18 Compare with carry
0000011F  BRNE PC-0x03 Branch if not equal
00000120  CALL 0x00000179 Call subroutine
00000122  JMP 0x0000071C Jump
00000124  JMP 0x00000000 Jump
--- C:\Users\liu\Desktop\BPN-SAS3-827HQ\BPN-SAS3-827HQ\BPN-SAS3-827HQ\Debug/.././HeartBeat.c
  //LE1 heart beat control
  cli();
00000126  CLI Global Interrupt Disable
  PORTA.DIRSET = 0x01; //out, control LE1, heart beat
00000127  LDI R24,0x01 Load immediate
00000128  STS 0x0601,R24 Store direct to data space
  OSC.CTRL |= OSC_RC32MRDY_bm; //enable 32 MHz internal oscillator
0000012A  LDI R30,0x50 Load immediate
0000012B  LDI R31,0x00 Load immediate
0000012C  LDD R24,Z+0 Load indirect with displacement
0000012D  ORI R24,0x02 Logical OR with immediate
0000012E  STD Z+0,R24 Store indirect with displacement
  while( ! ( OSC.STATUS & OSC_RC32MRDY_bm ) ); // wait 32 MHz internal oscillator ready
0000012F  LDD R24,Z+1 Load indirect with displacement
00000130  SBRS R24,1 Skip if bit in register set
00000131  RJMP PC-0x0002 Relative jump
  CCP = CCP_IOREG_gc;
00000132  LDI R24,0xD8 Load immediate
00000133  OUT 0x34,R24 Out to I/O location
  CLK.CTRL = 0x01; //liu 20170207 select 32MHz internal oscillator. 0x02; //select 32 KHz internal oscillator;
00000134  LDI R24,0x01 Load immediate
00000135  STS 0x0040,R24 Store direct to data space
  PORTA.DIRSET = 0x01;//p140 Set port A bit 0 to output.
00000137  STS 0x0601,R24 Store direct to data space
  TCC0.CTRLA = 0x07; //p163 Set Prescaler clk/1024
00000139  LDI R30,0x00 Load immediate
0000013A  LDI R31,0x08 Load immediate
0000013B  LDI R24,0x07 Load immediate
0000013C  STD Z+0,R24 Store indirect with displacement
  TCC0.CTRLB = 0x00; //p164 Set Timer to normal mode
0000013D  STD Z+1,R1 Store indirect with displacement
  TCC0.CTRLC = 0x00; //p165 Set to default value to disable all waveform generator.
0000013E  STD Z+2,R1 Store indirect with displacement
  TCC0.CTRLD = 0x00;//p165 Set to default value to disable event.
0000013F  STD Z+3,R1 Store indirect with displacement
  TCC0.CTRLE = 0x00;//p166 Set 16 bit timer / counter mode.
00000140  STD Z+4,R1 Store indirect with displacement
  TCC0.INTCTRLA = 0x03; //set timer overflow to low level interrupt.
00000141  LDI R24,0x03 Load immediate
00000142  STD Z+6,R24 Store indirect with displacement
  TCC0.INTCTRLB = 0x00;//2;//adjust to high level to avoid starving. 2; //set compare / capture channel A interrupt to low level
00000143  STD Z+7,R1 Store indirect with displacement
  TCC0.CTRLFSET = 0x00; //No force update, no lock, timer direction increase
00000144  STD Z+9,R1 Store indirect with displacement
  TCC0.CNT = 0x0000; // Count from 0
00000145  STD Z+32,R1 Store indirect with displacement
00000146  STD Z+33,R1 Store indirect with displacement
  TCC0.PER = 0x7fff;// 32MHz / 1024scale / 32K PER = 1 s
00000147  SER R24 Set Register
00000148  LDI R25,0x7F Load immediate
00000149  STD Z+38,R24 Store indirect with displacement
0000014A  STD Z+39,R25 Store indirect with displacement
  PMIC.CTRL |= 0x07; //enable interrupt
0000014B  LDI R30,0xA0 Load immediate
0000014C  LDI R31,0x00 Load immediate
0000014D  LDD R24,Z+2 Load indirect with displacement
0000014E  ORI R24,0x07 Logical OR with immediate
0000014F  STD Z+2,R24 Store indirect with displacement
00000150  RET Subroutine return
00000151  PUSH R1 Push register on stack
00000152  PUSH R0 Push register on stack
00000153  IN R0,0x3F In from I/O location
00000154  PUSH R0 Push register on stack
00000155  CLR R1 Clear Register
00000156  IN R0,0x38 In from I/O location
00000157  PUSH R0 Push register on stack
00000158  OUT 0x38,R1 Out to I/O location
00000159  PUSH R24 Push register on stack
CCP = CCP_IOREG_gc;
0000015A  LDI R24,0xD8 Load immediate
0000015B  OUT 0x34,R24 Out to I/O location
PORTA.OUTTGL = 0x01;//toggle the heart beat bit per 1 second.
0000015C  LDI R24,0x01 Load immediate
0000015D  STS 0x0607,R24 Store direct to data space
reti();
0000015F  RETI Interrupt return
00000160  POP R24 Pop register from stack
00000161  POP R0 Pop register from stack
00000162  OUT 0x38,R0 Out to I/O location
00000163  POP R0 Pop register from stack
00000164  OUT 0x3F,R0 Out to I/O location
00000165  POP R0 Pop register from stack
00000166  POP R1 Pop register from stack
00000167  RETI Interrupt return
--- C:\Users\liu\Desktop\BPN-SAS3-827HQ\BPN-SAS3-827HQ\BPN-SAS3-827HQ\Debug/.././main.c
  unsigned int i,j;
  for ( i = 0; i < numberOfUs; i++ )
00000168  SBIW R24,0x00 Subtract immediate from word
00000169  BRNE PC+0x0B Branch if not equal
0000016A  RET Subroutine return
0000016B  SUBI R18,0x01 Subtract immediate
0000016C  SBC R19,R1 Subtract with carry
for ( j = 0; j < 18; j++ ){};
0000016D  BRNE PC-0x02 Branch if not equal
0000016E  SUBI R20,0xFF Subtract immediate
0000016F  SBCI R21,0xFF Subtract immediate with carry
00000170  CP R20,R24 Compare
00000171  CPC R21,R25 Compare with carry
00000172  BRNE PC+0x04 Branch if not equal
00000173  RET Subroutine return
00000174  LDI R20,0x00 Load immediate
00000175  LDI R21,0x00 Load immediate
00000176  LDI R18,0x12 Load immediate
00000177  LDI R19,0x00 Load immediate
00000178  RJMP PC-0x000D Relative jump
00000179  LDI R30,0xE0 Load immediate
0000017A  LDI R31,0x06 Load immediate
0000017B  LDD R24,Z+0 Load indirect with displacement
0000017C  ANDI R24,0xF0 Logical AND with immediate
0000017D  STD Z+0,R24 Store indirect with displacement
0000017E  LDI R24,0x0F Load immediate
0000017F  STS 0x0700,R24 Store direct to data space
00000181  SER R24 Set Register
00000182  STS 0x0720,R24 Store direct to data space
00000184  LDI R26,0x00 Load immediate
00000185  LDI R27,0x06 Load immediate
00000186  ADIW R26,0x04 Add immediate to word
00000187  LD R24,X Load indirect
00000188  SBIW R26,0x04 Subtract immediate from word
00000189  ORI R24,0x02 Logical OR with immediate
0000018A  ADIW R26,0x04 Add immediate to word
0000018B  ST X,R24 Store indirect
  if ( !( PORTH.IN & 0x01 ) )
0000018C  LDD R24,Z+8 Load indirect with displacement
0000018D  SBRC R24,0 Skip if bit in register cleared
0000018E  RJMP PC+0x0004 Relative jump
PORTK.OUTCLR = 0x10; //enable 5VSB_EN1_N.
0000018F  LDI R24,0x10 Load immediate
00000190  STS 0x0726,R24 Store direct to data space
  if ( !( PORTH.IN & 0x02 ) )
00000192  LDS R24,0x06E8 Load direct from data space
00000194  SBRC R24,1 Skip if bit in register cleared
00000195  RJMP PC+0x0004 Relative jump
 PORTK.OUTCLR = 0x20; //enable 5VSB_EN2_N.
00000196  LDI R24,0x20 Load immediate
00000197  STS 0x0726,R24 Store direct to data space
  if ( !( PORTH.IN & 0x04 ) )
00000199  LDS R24,0x06E8 Load direct from data space
0000019B  SBRC R24,2 Skip if bit in register cleared
0000019C  RJMP PC+0x0004 Relative jump
 PORTK.OUTCLR = 0x40; //enable 5VSB_EN3_N.
0000019D  LDI R24,0x40 Load immediate
0000019E  STS 0x0726,R24 Store direct to data space
  if ( !( PORTH.IN & 0x08 ) )
000001A0  LDS R24,0x06E8 Load direct from data space
000001A2  SBRC R24,3 Skip if bit in register cleared
000001A3  RJMP PC+0x0004 Relative jump
 PORTK.OUTCLR = 0x80; //enable 5VSB_EN4_N.
000001A4  LDI R24,0x80 Load immediate
000001A5  STS 0x0726,R24 Store direct to data space
  if  ( !( ( PORTJ.IN | PORTH.IN ) & 0x01 ) )
000001A7  LDS R25,0x0708 Load direct from data space
000001A9  LDS R24,0x06E8 Load direct from data space
000001AB  OR R24,R25 Logical OR
000001AC  SBRC R24,0 Skip if bit in register cleared
000001AD  RJMP PC+0x0004 Relative jump
 PORTK.OUTSET = 0x01;
000001AE  LDI R24,0x01 Load immediate
000001AF  STS 0x0725,R24 Store direct to data space
  if  ( !( ( PORTJ.IN | PORTH.IN ) & 0x02 ) )
000001B1  LDS R25,0x0708 Load direct from data space
000001B3  LDS R24,0x06E8 Load direct from data space
000001B5  OR R24,R25 Logical OR
000001B6  SBRC R24,1 Skip if bit in register cleared
000001B7  RJMP PC+0x0004 Relative jump
 PORTK.OUTSET = 0x02;
000001B8  LDI R24,0x02 Load immediate
000001B9  STS 0x0725,R24 Store direct to data space
  if  ( !( ( PORTJ.IN | PORTH.IN ) & 0x04 ) )
000001BB  LDS R25,0x0708 Load direct from data space
000001BD  LDS R24,0x06E8 Load direct from data space
000001BF  OR R24,R25 Logical OR
000001C0  SBRC R24,2 Skip if bit in register cleared
000001C1  RJMP PC+0x0004 Relative jump
 PORTK.OUTSET = 0x04;
000001C2  LDI R24,0x04 Load immediate
000001C3  STS 0x0725,R24 Store direct to data space
  if  ( !( ( PORTJ.IN | PORTH.IN ) & 0x08 ) )
000001C5  LDS R25,0x0708 Load direct from data space
000001C7  LDS R24,0x06E8 Load direct from data space
000001C9  OR R24,R25 Logical OR
000001CA  SBRC R24,3 Skip if bit in register cleared
000001CB  RJMP PC+0x0004 Relative jump
 PORTK.OUTSET = 0x08;
000001CC  LDI R24,0x08 Load immediate
000001CD  STS 0x0725,R24 Store direct to data space
  ADCA_CTRLA = 0x03;
000001CF  LDI R24,0x03 Load immediate
000001D0  STS 0x0200,R24 Store direct to data space
--- c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\util/delay.h
__builtin_avr_delay_cycles(__ticks_dc);
000001D2  LDI R24,0x3F Load immediate
000001D3  LDI R25,0x1F Load immediate
000001D4  SBIW R24,0x01 Subtract immediate from word
000001D5  BRNE PC-0x01 Branch if not equal
000001D6  RJMP PC+0x0001 Relative jump
000001D7  NOP No operation
000001D8  LDI R28,0x02 Load immediate
000001D9  LDI R29,0x20 Load immediate
000001DA  MOV R0,R31 Copy register
000001DB  LDI R31,0x02 Load immediate
000001DC  MOV R14,R31 Copy register
000001DD  LDI R31,0x21 Load immediate
000001DE  MOV R15,R31 Copy register
000001DF  MOV R31,R0 Copy register
000001E0  LDI R17,0x00 Load immediate
000001E1  LDI R25,0x55 Load immediate
000001E2  DEC R25 Decrement
000001E3  BRNE PC-0x01 Branch if not equal
000001E4  NOP No operation
000001E5  MOV R18,R17 Copy register
000001E6  LDI R20,0x72 Load immediate
000001E7  LDI R22,0x01 Load immediate
000001E8  MOVW R24,R28 Copy register pair
000001E9  CALL 0x00000516 Call subroutine
000001EB  ADIW R28,0x01 Add immediate to word
000001EC  SUBI R17,0xFF Subtract immediate
000001ED  CP R28,R14 Compare
000001EE  CPC R29,R15 Compare with carry
000001EF  BRNE PC-0x0E Branch if not equal
  HeartBeatInit();
000001F0  CALL 0x00000126 Call subroutine
000001F2  CALL 0x00000578 Call subroutine
  PWMInit( );
000001F4  CALL 0x000001FB Call subroutine
  TACHOInit( );
000001F6  CALL 0x00000303 Call subroutine
  TempInit( );
000001F8  CALL 0x0000040D Call subroutine
000001FA  RJMP PC-0x0000 Relative jump
--- C:\Users\liu\Desktop\BPN-SAS3-827HQ\BPN-SAS3-827HQ\BPN-SAS3-827HQ\Debug/.././PWM.c
000001FB  LDI R30,0x50 Load immediate
000001FC  LDI R31,0x00 Load immediate
000001FD  LDD R24,Z+0 Load indirect with displacement
000001FE  ORI R24,0x02 Logical OR with immediate
000001FF  STD Z+0,R24 Store indirect with displacement
00000200  LDD R24,Z+1 Load indirect with displacement
00000201  SBRS R24,1 Skip if bit in register set
00000202  RJMP PC-0x0002 Relative jump
  CCP = CCP_IOREG_gc;
00000203  LDI R24,0xD8 Load immediate
00000204  OUT 0x34,R24 Out to I/O location
  CLK.CTRL = 0x01; //select 32MHz internal oscillator.
00000205  LDI R24,0x01 Load immediate
00000206  STS 0x0040,R24 Store direct to data space
  TCC1.CTRLA = 0x01; //p163 Set Prescaler clk
00000208  LDI R30,0x40 Load immediate
00000209  LDI R31,0x08 Load immediate
0000020A  STD Z+0,R24 Store indirect with displacement
  TCC1.CTRLB = 0x33; //p164: Set Compare Channel A|B| single slop waveform generation mode.
0000020B  LDI R24,0x33 Load immediate
0000020C  STD Z+1,R24 Store indirect with displacement
  PORTC_DIRSET = 0xf0;//Pot C Fan PWM control.
0000020D  LDI R24,0xF0 Load immediate
0000020E  STS 0x0641,R24 Store direct to data space
  TCC1.PER = 0x51f; //p170: Set timer period 25KHz. P9 Fan spec PWM 25KHz.
00000210  LDI R24,0x1F Load immediate
00000211  LDI R25,0x05 Load immediate
00000212  STD Z+38,R24 Store indirect with displacement
00000213  STD Z+39,R25 Store indirect with displacement
  TCC1.CCABUF = 0x020C;
00000214  LDI R24,0x0C Load immediate
00000215  LDI R25,0x02 Load immediate
00000216  STD Z+56,R24 Store indirect with displacement
00000217  STD Z+57,R25 Store indirect with displacement
  TCC1.CCBBUF = 0x020C;
00000218  STD Z+58,R24 Store indirect with displacement
00000219  STD Z+59,R25 Store indirect with displacement
  TCC1.CCA = 0x020C;
0000021A  STD Z+40,R24 Store indirect with displacement
0000021B  STD Z+41,R25 Store indirect with displacement
  TCC1.CCB = 0x020C; //Default value corresponding to 40% duty cycle.
0000021C  STD Z+42,R24 Store indirect with displacement
0000021D  STD Z+43,R25 Store indirect with displacement
0000021E  RET Subroutine return
0000021F  PUSH R16 Push register on stack
00000220  PUSH R17 Push register on stack
00000221  PUSH R28 Push register on stack
00000222  PUSH R29 Push register on stack
  if ( ( ADCA_CH0_RES / 31 ) < 25 ) // 31 = ADC value per degree
00000223  LDS R24,0x0224 Load direct from data space
00000225  LDS R25,0x0225 Load direct from data space
00000227  CPI R24,0x07 Compare with immediate
00000228  SBCI R25,0x03 Subtract immediate with carry
00000229  BRCC PC+0x12 Branch if carry cleared
    TCC1.CCA = 1311 * 20 / 100; //20% duty cycle
0000022A  LDI R30,0x40 Load immediate
0000022B  LDI R31,0x08 Load immediate
0000022C  LDI R24,0x06 Load immediate
0000022D  LDI R25,0x01 Load immediate
0000022E  STD Z+40,R24 Store indirect with displacement
0000022F  STD Z+41,R25 Store indirect with displacement
    TCC1.CCB = 1311 * 20 / 100;
00000230  STD Z+42,R24 Store indirect with displacement
00000231  STD Z+43,R25 Store indirect with displacement
    preADCACH0RES = ADCA_CH0_RES;
00000232  LDS R24,0x0224 Load direct from data space
00000234  LDS R25,0x0225 Load direct from data space
00000236  STS 0x27EB,R24 Store direct to data space
00000238  STS 0x27EC,R25 Store direct to data space
0000023A  RJMP PC+0x00C4 Relative jump
  else if ( ( ADCA_CH0_RES / 31 ) > 50 )
0000023B  LDS R24,0x0224 Load direct from data space
0000023D  LDS R25,0x0225 Load direct from data space
0000023F  CPI R24,0x2D Compare with immediate
00000240  SBCI R25,0x06 Subtract immediate with carry
00000241  BRCS PC+0x12 Branch if carry set
    TCC1.CCA = 1311; //100% duty cycle
00000242  LDI R30,0x40 Load immediate
00000243  LDI R31,0x08 Load immediate
00000244  LDI R24,0x1F Load immediate
00000245  LDI R25,0x05 Load immediate
00000246  STD Z+40,R24 Store indirect with displacement
00000247  STD Z+41,R25 Store indirect with displacement
    TCC1.CCB = 1311;
00000248  STD Z+42,R24 Store indirect with displacement
00000249  STD Z+43,R25 Store indirect with displacement
0000024A  LDS R24,0x0224 Load direct from data space
0000024C  LDS R25,0x0225 Load direct from data space
0000024E  STS 0x27EB,R24 Store direct to data space
00000250  STS 0x27EC,R25 Store direct to data space
00000252  RJMP PC+0x00AC Relative jump
  else if ( ADCA_CH0_RES > preADCACH0RES )
00000253  LDS R18,0x0224 Load direct from data space
00000255  LDS R19,0x0225 Load direct from data space
00000257  LDS R24,0x27EB Load direct from data space
00000259  LDS R25,0x27EC Load direct from data space
0000025B  CP R24,R18 Compare
0000025C  CPC R25,R19 Compare with carry
0000025D  BRCS PC+0x02 Branch if carry set
0000025E  RJMP PC+0x004C Relative jump
    TCC1.CCA = 1311 * ADCA_CH0_RES / 31 * 4; // temp vs. duty cycle slop = 4, 1311 = counter for 100% duty cycle.
0000025F  LDI R30,0x24 Load immediate
00000260  LDI R31,0x02 Load immediate
00000261  LDD R24,Z+0 Load indirect with displacement
00000262  LDD R25,Z+1 Load indirect with displacement
00000263  LDI R16,0x1F Load immediate
00000264  LDI R17,0x05 Load immediate
00000265  MUL R24,R16 Multiply unsigned
00000266  MOVW R20,R0 Copy register pair
00000267  MUL R24,R17 Multiply unsigned
00000268  ADD R21,R0 Add without carry
00000269  MUL R25,R16 Multiply unsigned
0000026A  ADD R21,R0 Add without carry
0000026B  CLR R1 Clear Register
0000026C  MOVW R18,R20 Copy register pair
0000026D  LDI R26,0x43 Load immediate
0000026E  LDI R27,0x08 Load immediate
0000026F  CALL 0x000006EB Call subroutine
00000271  SUB R20,R24 Subtract without carry
00000272  SBC R21,R25 Subtract with carry
00000273  LSR R21 Logical shift right
00000274  ROR R20 Rotate right through carry
00000275  ADD R24,R20 Add without carry
00000276  ADC R25,R21 Add with carry
00000277  SWAP R25 Swap nibbles
00000278  SWAP R24 Swap nibbles
00000279  ANDI R24,0x0F Logical AND with immediate
0000027A  EOR R24,R25 Exclusive OR
0000027B  ANDI R25,0x0F Logical AND with immediate
0000027C  EOR R24,R25 Exclusive OR
0000027D  LSL R24 Logical Shift Left
0000027E  ROL R25 Rotate Left Through Carry
0000027F  LSL R24 Logical Shift Left
00000280  ROL R25 Rotate Left Through Carry
00000281  LDI R28,0x40 Load immediate
00000282  LDI R29,0x08 Load immediate
00000283  STD Y+40,R24 Store indirect with displacement
00000284  STD Y+41,R25 Store indirect with displacement
    TCC1.CCB = 1311 * ADCA_CH0_RES / 31 * 4;
00000285  LDD R24,Z+0 Load indirect with displacement
00000286  LDD R25,Z+1 Load indirect with displacement
00000287  MUL R24,R16 Multiply unsigned
00000288  MOVW R20,R0 Copy register pair
00000289  MUL R24,R17 Multiply unsigned
0000028A  ADD R21,R0 Add without carry
0000028B  MUL R25,R16 Multiply unsigned
0000028C  ADD R21,R0 Add without carry
0000028D  CLR R1 Clear Register
0000028E  MOVW R18,R20 Copy register pair
0000028F  CALL 0x000006EB Call subroutine
00000291  SUB R20,R24 Subtract without carry
00000292  SBC R21,R25 Subtract with carry
00000293  LSR R21 Logical shift right
00000294  ROR R20 Rotate right through carry
00000295  ADD R24,R20 Add without carry
00000296  ADC R25,R21 Add with carry
00000297  SWAP R25 Swap nibbles
00000298  SWAP R24 Swap nibbles
00000299  ANDI R24,0x0F Logical AND with immediate
0000029A  EOR R24,R25 Exclusive OR
0000029B  ANDI R25,0x0F Logical AND with immediate
0000029C  EOR R24,R25 Exclusive OR
0000029D  LSL R24 Logical Shift Left
0000029E  ROL R25 Rotate Left Through Carry
0000029F  LSL R24 Logical Shift Left
000002A0  ROL R25 Rotate Left Through Carry
000002A1  STD Y+42,R24 Store indirect with displacement
000002A2  STD Y+43,R25 Store indirect with displacement
000002A3  LDD R24,Z+0 Load indirect with displacement
000002A4  LDD R25,Z+1 Load indirect with displacement
000002A5  STS 0x27EB,R24 Store direct to data space
000002A7  STS 0x27EC,R25 Store direct to data space
000002A9  RJMP PC+0x0055 Relative jump
  else if ( ( ( preADCACH0RES - ADCA_CH0_RES ) / 31 ) > 4 ) // temp decreases over 4 degree.
000002AA  LDS R18,0x0224 Load direct from data space
000002AC  LDS R19,0x0225 Load direct from data space
000002AE  SUB R24,R18 Subtract without carry
000002AF  SBC R25,R19 Subtract with carry
000002B0  CPI R24,0x9B Compare with immediate
000002B1  CPC R25,R1 Compare with carry
000002B2  BRCC PC+0x02 Branch if carry cleared
000002B3  RJMP PC+0x004B Relative jump
000002B4  LDI R30,0x24 Load immediate
000002B5  LDI R31,0x02 Load immediate
000002B6  LDD R24,Z+0 Load indirect with displacement
000002B7  LDD R25,Z+1 Load indirect with displacement
000002B8  LDI R16,0x1F Load immediate
000002B9  LDI R17,0x05 Load immediate
000002BA  MUL R24,R16 Multiply unsigned
000002BB  MOVW R20,R0 Copy register pair
000002BC  MUL R24,R17 Multiply unsigned
000002BD  ADD R21,R0 Add without carry
000002BE  MUL R25,R16 Multiply unsigned
000002BF  ADD R21,R0 Add without carry
000002C0  CLR R1 Clear Register
000002C1  MOVW R18,R20 Copy register pair
000002C2  LDI R26,0x43 Load immediate
000002C3  LDI R27,0x08 Load immediate
000002C4  CALL 0x000006EB Call subroutine
000002C6  SUB R20,R24 Subtract without carry
000002C7  SBC R21,R25 Subtract with carry
000002C8  LSR R21 Logical shift right
000002C9  ROR R20 Rotate right through carry
000002CA  ADD R24,R20 Add without carry
000002CB  ADC R25,R21 Add with carry
000002CC  SWAP R25 Swap nibbles
000002CD  SWAP R24 Swap nibbles
000002CE  ANDI R24,0x0F Logical AND with immediate
000002CF  EOR R24,R25 Exclusive OR
000002D0  ANDI R25,0x0F Logical AND with immediate
000002D1  EOR R24,R25 Exclusive OR
000002D2  LSL R24 Logical Shift Left
000002D3  ROL R25 Rotate Left Through Carry
000002D4  LSL R24 Logical Shift Left
000002D5  ROL R25 Rotate Left Through Carry
000002D6  LDI R28,0x40 Load immediate
000002D7  LDI R29,0x08 Load immediate
000002D8  STD Y+40,R24 Store indirect with displacement
000002D9  STD Y+41,R25 Store indirect with displacement
000002DA  LDD R24,Z+0 Load indirect with displacement
000002DB  LDD R25,Z+1 Load indirect with displacement
000002DC  MUL R24,R16 Multiply unsigned
000002DD  MOVW R20,R0 Copy register pair
000002DE  MUL R24,R17 Multiply unsigned
000002DF  ADD R21,R0 Add without carry
000002E0  MUL R25,R16 Multiply unsigned
000002E1  ADD R21,R0 Add without carry
000002E2  CLR R1 Clear Register
000002E3  MOVW R18,R20 Copy register pair
000002E4  CALL 0x000006EB Call subroutine
000002E6  SUB R20,R24 Subtract without carry
000002E7  SBC R21,R25 Subtract with carry
000002E8  LSR R21 Logical shift right
000002E9  ROR R20 Rotate right through carry
000002EA  ADD R24,R20 Add without carry
000002EB  ADC R25,R21 Add with carry
000002EC  SWAP R25 Swap nibbles
000002ED  SWAP R24 Swap nibbles
000002EE  ANDI R24,0x0F Logical AND with immediate
000002EF  EOR R24,R25 Exclusive OR
000002F0  ANDI R25,0x0F Logical AND with immediate
000002F1  EOR R24,R25 Exclusive OR
000002F2  LSL R24 Logical Shift Left
000002F3  ROL R25 Rotate Left Through Carry
000002F4  LSL R24 Logical Shift Left
000002F5  ROL R25 Rotate Left Through Carry
000002F6  STD Y+42,R24 Store indirect with displacement
000002F7  STD Y+43,R25 Store indirect with displacement
000002F8  LDD R24,Z+0 Load indirect with displacement
000002F9  LDD R25,Z+1 Load indirect with displacement
000002FA  STS 0x27EB,R24 Store direct to data space
000002FC  STS 0x27EC,R25 Store direct to data space
000002FE  POP R29 Pop register from stack
000002FF  POP R28 Pop register from stack
00000300  POP R17 Pop register from stack
00000301  POP R16 Pop register from stack
00000302  RET Subroutine return
--- C:\Users\liu\Desktop\BPN-SAS3-827HQ\BPN-SAS3-827HQ\BPN-SAS3-827HQ\Debug/.././TACHO.c
cli();
00000303  CLI Global Interrupt Disable
  TCD1.CTRLA = 0x07; //p163 pre-scaler = Clk / 1024.
00000304  LDI R30,0x40 Load immediate
00000305  LDI R31,0x09 Load immediate
00000306  LDI R24,0x07 Load immediate
00000307  STD Z+0,R24 Store indirect with displacement
  TCD1.CTRLB = 0x30; //p164: Enable channel A, B of Timer1 on port D. Set the compare and capture channel A & B to Normal mode.
00000308  LDI R24,0x30 Load immediate
00000309  STD Z+1,R24 Store indirect with displacement
  TCD1.CTRLD = 0x2c; //EVACT[2:0]: Input capture. Timer Delay bit Clear. Channel #4.
0000030A  LDI R24,0x2C Load immediate
0000030B  STD Z+3,R24 Store indirect with displacement
  TCD1.CTRLE = 0x00;//Timer / counter 1 in port D operate in default normal mode.
0000030C  STD Z+4,R1 Store indirect with displacement
  PORTD_DIRCLR = 0xc0;//+Port D pin 4 and 5 for fan tachometer input.
0000030D  LDI R24,0xC0 Load immediate
0000030E  STS 0x0662,R24 Store direct to data space
  PORTD_PIN2CTRL = 0x01;//Port D pin4 sense rising edge.
00000310  LDI R24,0x01 Load immediate
00000311  STS 0x0672,R24 Store direct to data space
  PORTD_PIN3CTRL = 0x01;//Port D pin5 sense rising edge.
00000313  STS 0x0673,R24 Store direct to data space
  EVSYS.CH4MUX = EVSYS_CHMUX_PORTD_PIN2_gc;
00000315  LDI R26,0x80 Load immediate
00000316  LDI R27,0x01 Load immediate
00000317  LDI R24,0x6A Load immediate
00000318  ADIW R26,0x04 Add immediate to word
00000319  ST X,R24 Store indirect
0000031A  SBIW R26,0x04 Subtract immediate from word
  EVSYS.CH1MUX = EVSYS_CHMUX_PORTD_PIN3_gc;
0000031B  LDI R24,0x6B Load immediate
0000031C  ADIW R26,0x01 Add immediate to word
0000031D  ST X,R24 Store indirect
  TCD1.PER = 0x7FFF; //p13: AVR1306.
0000031E  SER R24 Set Register
0000031F  LDI R25,0x7F Load immediate
00000320  STD Z+38,R24 Store indirect with displacement
00000321  STD Z+39,R25 Store indirect with displacement
  TCD1.INTCTRLA = 0x00;// enable interrupt for overflow and error.
00000322  STD Z+6,R1 Store indirect with displacement
  TCD1.INTCTRLB = 0x03; //enable interrupt channel A, B.
00000323  LDI R24,0x03 Load immediate
00000324  STD Z+7,R24 Store indirect with displacement
  sei();
00000325  SEI Global Interrupt Enable
00000326  RET Subroutine return
00000327  PUSH R1 Push register on stack
00000328  PUSH R0 Push register on stack
00000329  IN R0,0x3F In from I/O location
0000032A  PUSH R0 Push register on stack
0000032B  CLR R1 Clear Register
0000032C  IN R0,0x38 In from I/O location
0000032D  PUSH R0 Push register on stack
0000032E  OUT 0x38,R1 Out to I/O location
0000032F  IN R0,0x39 In from I/O location
00000330  PUSH R0 Push register on stack
00000331  OUT 0x39,R1 Out to I/O location
00000332  IN R0,0x3B In from I/O location
00000333  PUSH R0 Push register on stack
00000334  OUT 0x3B,R1 Out to I/O location
00000335  PUSH R12 Push register on stack
00000336  PUSH R13 Push register on stack
00000337  PUSH R14 Push register on stack
00000338  PUSH R15 Push register on stack
00000339  PUSH R18 Push register on stack
0000033A  PUSH R19 Push register on stack
0000033B  PUSH R20 Push register on stack
0000033C  PUSH R21 Push register on stack
0000033D  PUSH R22 Push register on stack
0000033E  PUSH R23 Push register on stack
0000033F  PUSH R24 Push register on stack
00000340  PUSH R25 Push register on stack
00000341  PUSH R26 Push register on stack
00000342  PUSH R27 Push register on stack
00000343  PUSH R30 Push register on stack
00000344  PUSH R31 Push register on stack
  lastCaptureA = TCD1_CCA;
00000345  LDS R24,0x0968 Load direct from data space
00000347  LDS R25,0x0969 Load direct from data space
00000349  MOVW R12,R24 Copy register pair
0000034A  MOV R14,R1 Copy register
0000034B  MOV R15,R1 Copy register
0000034C  STS 0x27DD,R12 Store direct to data space
0000034E  STS 0x27DE,R13 Store direct to data space
00000350  STS 0x27DF,R14 Store direct to data space
00000352  STS 0x27E0,R15 Store direct to data space
  if ( !( lastCaptureA & 0x8000 ) )
00000354  TST R25 Test for Zero or Minus
00000355  BRLT PC+0x29 Branch if less than, signed
    halfPeriodCountA = TCD1_CCA - lastCaptureA;//in unit of 1 / 32768 (2 pow 16 ) s
00000356  LDS R18,0x0968 Load direct from data space
00000358  LDS R19,0x0969 Load direct from data space
0000035A  MOVW R24,R18 Copy register pair
0000035B  LDI R26,0x00 Load immediate
0000035C  LDI R27,0x00 Load immediate
0000035D  MOVW R18,R24 Copy register pair
0000035E  MOVW R20,R26 Copy register pair
0000035F  SUB R18,R12 Subtract without carry
00000360  SBC R19,R13 Subtract with carry
00000361  SBC R20,R14 Subtract with carry
00000362  SBC R21,R15 Subtract with carry
00000363  STS 0x27D1,R18 Store direct to data space
00000365  STS 0x27D2,R19 Store direct to data space
00000367  STS 0x27D3,R20 Store direct to data space
00000369  STS 0x27D4,R21 Store direct to data space
if ( halfPeriodCountA ) fanSpeedA = 60 * 16 * 1024L / halfPeriodCountA; // rotate / min.
0000036B  CP R18,R1 Compare
0000036C  CPC R19,R1 Compare with carry
0000036D  CPC R20,R1 Compare with carry
0000036E  CPC R21,R1 Compare with carry
0000036F  BREQ PC+0x0F Branch if equal
00000370  LDI R22,0x00 Load immediate
00000371  LDI R23,0x00 Load immediate
00000372  LDI R24,0x0F Load immediate
00000373  LDI R25,0x00 Load immediate
00000374  CALL 0x000006CC Call subroutine
00000376  STS 0x27E1,R18 Store direct to data space
00000378  STS 0x27E2,R19 Store direct to data space
0000037A  STS 0x27E3,R20 Store direct to data space
0000037C  STS 0x27E4,R21 Store direct to data space
  reti();
0000037E  RETI Interrupt return
0000037F  POP R31 Pop register from stack
00000380  POP R30 Pop register from stack
00000381  POP R27 Pop register from stack
00000382  POP R26 Pop register from stack
00000383  POP R25 Pop register from stack
00000384  POP R24 Pop register from stack
00000385  POP R23 Pop register from stack
00000386  POP R22 Pop register from stack
00000387  POP R21 Pop register from stack
00000388  POP R20 Pop register from stack
00000389  POP R19 Pop register from stack
0000038A  POP R18 Pop register from stack
0000038B  POP R15 Pop register from stack
0000038C  POP R14 Pop register from stack
0000038D  POP R13 Pop register from stack
0000038E  POP R12 Pop register from stack
0000038F  POP R0 Pop register from stack
00000390  OUT 0x3B,R0 Out to I/O location
00000391  POP R0 Pop register from stack
00000392  OUT 0x39,R0 Out to I/O location
00000393  POP R0 Pop register from stack
00000394  OUT 0x38,R0 Out to I/O location
00000395  POP R0 Pop register from stack
00000396  OUT 0x3F,R0 Out to I/O location
00000397  POP R0 Pop register from stack
00000398  POP R1 Pop register from stack
00000399  RETI Interrupt return
0000039A  PUSH R1 Push register on stack
0000039B  PUSH R0 Push register on stack
0000039C  IN R0,0x3F In from I/O location
0000039D  PUSH R0 Push register on stack
0000039E  CLR R1 Clear Register
0000039F  IN R0,0x38 In from I/O location
000003A0  PUSH R0 Push register on stack
000003A1  OUT 0x38,R1 Out to I/O location
000003A2  IN R0,0x39 In from I/O location
000003A3  PUSH R0 Push register on stack
000003A4  OUT 0x39,R1 Out to I/O location
000003A5  IN R0,0x3B In from I/O location
000003A6  PUSH R0 Push register on stack
000003A7  OUT 0x3B,R1 Out to I/O location
000003A8  PUSH R12 Push register on stack
000003A9  PUSH R13 Push register on stack
000003AA  PUSH R14 Push register on stack
000003AB  PUSH R15 Push register on stack
000003AC  PUSH R18 Push register on stack
000003AD  PUSH R19 Push register on stack
000003AE  PUSH R20 Push register on stack
000003AF  PUSH R21 Push register on stack
000003B0  PUSH R22 Push register on stack
000003B1  PUSH R23 Push register on stack
000003B2  PUSH R24 Push register on stack
000003B3  PUSH R25 Push register on stack
000003B4  PUSH R26 Push register on stack
000003B5  PUSH R27 Push register on stack
000003B6  PUSH R30 Push register on stack
000003B7  PUSH R31 Push register on stack
lastCaptureB = TCD1_CCB;
000003B8  LDS R24,0x096A Load direct from data space
000003BA  LDS R25,0x096B Load direct from data space
000003BC  MOVW R12,R24 Copy register pair
000003BD  MOV R14,R1 Copy register
000003BE  MOV R15,R1 Copy register
000003BF  STS 0x27E5,R12 Store direct to data space
000003C1  STS 0x27E6,R13 Store direct to data space
000003C3  STS 0x27E7,R14 Store direct to data space
000003C5  STS 0x27E8,R15 Store direct to data space
if ( !( lastCaptureB & 0x8000 ) )
000003C7  TST R25 Test for Zero or Minus
000003C8  BRLT PC+0x29 Branch if less than, signed
halfPeriodCountB = TCD1_CCB - lastCaptureB;//in unit of 1 / 32768 (2 pow 16 ) s
000003C9  LDS R18,0x096A Load direct from data space
000003CB  LDS R19,0x096B Load direct from data space
000003CD  MOVW R24,R18 Copy register pair
000003CE  LDI R26,0x00 Load immediate
000003CF  LDI R27,0x00 Load immediate
000003D0  MOVW R18,R24 Copy register pair
000003D1  MOVW R20,R26 Copy register pair
000003D2  SUB R18,R12 Subtract without carry
000003D3  SBC R19,R13 Subtract with carry
000003D4  SBC R20,R14 Subtract with carry
000003D5  SBC R21,R15 Subtract with carry
000003D6  STS 0x27D9,R18 Store direct to data space
000003D8  STS 0x27DA,R19 Store direct to data space
000003DA  STS 0x27DB,R20 Store direct to data space
000003DC  STS 0x27DC,R21 Store direct to data space
if ( halfPeriodCountB ) fanSpeedB = 60 * 16 * 1024L / halfPeriodCountB; // rotate / min.
000003DE  CP R18,R1 Compare
000003DF  CPC R19,R1 Compare with carry
000003E0  CPC R20,R1 Compare with carry
000003E1  CPC R21,R1 Compare with carry
000003E2  BREQ PC+0x0F Branch if equal
000003E3  LDI R22,0x00 Load immediate
000003E4  LDI R23,0x00 Load immediate
000003E5  LDI R24,0x0F Load immediate
000003E6  LDI R25,0x00 Load immediate
000003E7  CALL 0x000006CC Call subroutine
000003E9  STS 0x27D5,R18 Store direct to data space
000003EB  STS 0x27D6,R19 Store direct to data space
000003ED  STS 0x27D7,R20 Store direct to data space
000003EF  STS 0x27D8,R21 Store direct to data space
reti();
000003F1  RETI Interrupt return
000003F2  POP R31 Pop register from stack
000003F3  POP R30 Pop register from stack
000003F4  POP R27 Pop register from stack
000003F5  POP R26 Pop register from stack
000003F6  POP R25 Pop register from stack
000003F7  POP R24 Pop register from stack
000003F8  POP R23 Pop register from stack
000003F9  POP R22 Pop register from stack
000003FA  POP R21 Pop register from stack
000003FB  POP R20 Pop register from stack
000003FC  POP R19 Pop register from stack
000003FD  POP R18 Pop register from stack
000003FE  POP R15 Pop register from stack
000003FF  POP R14 Pop register from stack
00000400  POP R13 Pop register from stack
00000401  POP R12 Pop register from stack
00000402  POP R0 Pop register from stack
00000403  OUT 0x3B,R0 Out to I/O location
00000404  POP R0 Pop register from stack
00000405  OUT 0x39,R0 Out to I/O location
00000406  POP R0 Pop register from stack
00000407  OUT 0x38,R0 Out to I/O location
00000408  POP R0 Pop register from stack
00000409  OUT 0x3F,R0 Out to I/O location
0000040A  POP R0 Pop register from stack
0000040B  POP R1 Pop register from stack
0000040C  RETI Interrupt return
--- C:\Users\liu\Desktop\BPN-SAS3-827HQ\BPN-SAS3-827HQ\BPN-SAS3-827HQ\Debug/.././Temp.c
  ADCA_CTRLA = 0x05; //DMASEL[1:0]:No combined DMA request. CHSTART[3:0]:Hold on conversion. FLUSH: Pipeline Flush. ENABLE: Enable ADC.
0000040D  LDI R24,0x05 Load immediate
0000040E  STS 0x0200,R24 Store direct to data space
  ADCA_CTRLB = 0x08;//CONVMODE: Conversion Mode unsigned. FREERUN: Free Running Mode. RESOLUTION[1:0]: Conversion Result Resolution:12-bit result, right adjusted.
00000410  LDI R24,0x08 Load immediate
00000411  STS 0x0201,R24 Store direct to data space
  ADCA_REFCTRL = 0x01;//REFSEL[1:0]: Reference Selection:10/11 of bandgap (1.0V). BANDGAP: Bandgap disabled. TEMPREF: Temperature Reference Enabled.
00000413  LDI R24,0x01 Load immediate
00000414  STS 0x0202,R24 Store direct to data space
  ADCA_EVCTRL = 0x00;//SWEEP[1:0]: Only channel #0.EVSEL[2:0]: Event Channel #7. EVACT[2:0]: EVACT[2:0]: event mode: No event input.
00000416  STS 0x0203,R1 Store direct to data space
  ADCA_PRESCALER = 0x07;//PRESCALER[2:0]: DIV 512.
00000418  LDI R24,0x07 Load immediate
00000419  STS 0x0204,R24 Store direct to data space
  CCP = 0xD8; //0x9D;//0xD8; //Signature of IO protected register.
0000041B  LDI R24,0xD8 Load immediate
0000041C  OUT 0x34,R24 Out to I/O location
  ADCA_CAL = 0x0A80;
0000041D  LDI R24,0x80 Load immediate
0000041E  LDI R25,0x0A Load immediate
0000041F  STS 0x020C,R24 Store direct to data space
00000421  STS 0x020D,R25 Store direct to data space
  ADCA_CH0_CTRL = 0x80;//Start conversion, Gain factor = 1x, Internal positive input.
00000423  LDI R24,0x80 Load immediate
00000424  STS 0x0220,R24 Store direct to data space
  ADCA_CH0_MUXCTRL = 0x00;//MUX positive input: Temperature reference. MUX Negative: N / A for internal positive input.
00000426  STS 0x0221,R1 Store direct to data space
  ADCA_CH0_INTCTRL = 0x00;//Interrupt mode: N / A, Interrupt level = disabled.
00000428  STS 0x0222,R1 Store direct to data space
0000042A  LDI R30,0x24 Load immediate
0000042B  LDI R31,0x02 Load immediate
0000042C  LDD R24,Z+0 Load indirect with displacement
0000042D  LDD R25,Z+1 Load indirect with displacement
0000042E  STS 0x27EB,R24 Store direct to data space
00000430  STS 0x27EC,R25 Store direct to data space
  currentADCACH0RES = ADCA_CH0_RES;
00000432  LDD R24,Z+0 Load indirect with displacement
00000433  LDD R25,Z+1 Load indirect with displacement
00000434  STS 0x27E9,R24 Store direct to data space
00000436  STS 0x27EA,R25 Store direct to data space
00000438  RET Subroutine return
return 0;
00000439  LDI R24,0x00 Load immediate
0000043A  LDI R25,0x00 Load immediate
0000043B  RET Subroutine return
--- C:\Users\liu\Desktop\BPN-SAS3-827HQ\BPN-SAS3-827HQ\BPN-SAS3-827HQ\Debug/.././TWI_master.c
//DDR_SCL |= (1 << SCL);
//DDR_SDA |= (1 << SDA);
  PORTB.DIRSET = 0x03;
0000043C  LDI R30,0x20 Load immediate
0000043D  LDI R31,0x06 Load immediate
0000043E  LDI R24,0x03 Load immediate
0000043F  STD Z+1,R24 Store indirect with displacement
  PORTB.OUTSET = 0x03;
00000440  STD Z+5,R24 Store indirect with displacement
00000441  RET Subroutine return
//DDR_SCL &= ~(1 << SCL);
//DDR_SDA &= ~(1 << SDA);
  PORTB.DIRCLR = 0x03;
00000442  LDI R24,0x03 Load immediate
00000443  STS 0x0622,R24 Store direct to data space
00000445  RET Subroutine return
    PORTB.OUTSET = 0x01;
00000446  LDI R30,0x20 Load immediate
00000447  LDI R31,0x06 Load immediate
00000448  LDI R25,0x01 Load immediate
00000449  STD Z+5,R25 Store indirect with displacement
    PORTB.DIRSET = 0x01;
0000044A  STD Z+1,R25 Store indirect with displacement
0000044B  RJMP PC+0x0001 Relative jump
0000044C  RJMP PC+0x0001 Relative jump
    PORTB.OUTSET = 0x02;
0000044D  LDI R24,0x02 Load immediate
0000044E  STD Z+5,R24 Store indirect with displacement
    PORTB.DIRSET = 0x02;
0000044F  STD Z+1,R24 Store indirect with displacement
00000450  LDI R18,0x02 Load immediate
00000451  DEC R18 Decrement
00000452  BRNE PC-0x01 Branch if not equal
00000453  RJMP PC+0x0001 Relative jump
PORTB.OUTCLR = 0x01;
00000454  STD Z+6,R25 Store indirect with displacement
00000455  RJMP PC+0x0001 Relative jump
00000456  RJMP PC+0x0001 Relative jump
PORTB.OUTCLR = 0x02;
00000457  STD Z+6,R24 Store indirect with displacement
00000458  RJMP PC+0x0001 Relative jump
00000459  RJMP PC+0x0001 Relative jump
0000045A  LDI R24,0x01 Load immediate
0000045B  RET Subroutine return
0000045C  MOV R25,R24 Copy register
  PORTB_DIRSET = 0x01;
0000045D  LDI R24,0x01 Load immediate
0000045E  STS 0x0621,R24 Store direct to data space
00000460  LDI R24,0x08 Load immediate
if ( byte & 0x80 ) PORTB.OUTSET = 0x01; else PORTB.OUTCLR = 0x01;
00000461  LDI R30,0x20 Load immediate
00000462  LDI R31,0x06 Load immediate
00000463  LDI R19,0x01 Load immediate
00000464  LDI R18,0x02 Load immediate
00000465  TST R25 Test for Zero or Minus
00000466  BRGE PC+0x03 Branch if greater or equal, signed
00000467  STD Z+5,R19 Store indirect with displacement
00000468  RJMP PC+0x0002 Relative jump
00000469  STD Z+6,R19 Store indirect with displacement
0000046A  RJMP PC+0x0001 Relative jump
0000046B  RJMP PC+0x0001 Relative jump
0000046C  STD Z+5,R18 Store indirect with displacement
0000046D  LDI R20,0x02 Load immediate
0000046E  DEC R20 Decrement
0000046F  BRNE PC-0x01 Branch if not equal
00000470  RJMP PC+0x0001 Relative jump
PORTB.OUTCLR = 0x02; // 100KHz I2C operation is required by SMC's power supply.
00000471  STD Z+6,R18 Store indirect with displacement
00000472  RJMP PC+0x0001 Relative jump
00000473  RJMP PC+0x0001 Relative jump
    byte <<= 1;
00000474  LSL R25 Logical Shift Left
00000475  SUBI R24,0x01 Subtract immediate
  for (bit = 0; bit < 8; bit++)
00000476  BRNE PC-0x11 Branch if not equal
  PORTB.DIRCLR = 0x01;
00000477  LDI R30,0x20 Load immediate
00000478  LDI R31,0x06 Load immediate
00000479  LDI R25,0x01 Load immediate
0000047A  STD Z+2,R25 Store indirect with displacement
0000047B  RJMP PC+0x0001 Relative jump
0000047C  RJMP PC+0x0001 Relative jump
0000047D  LDI R25,0x02 Load immediate
0000047E  STD Z+5,R25 Store indirect with displacement
  if ( PORTB.IN & 0x01 )
0000047F  LDD R25,Z+8 Load indirect with displacement
00000480  SBRS R25,0 Skip if bit in register set
00000481  RJMP PC+0x000D Relative jump
00000482  LDI R25,0x02 Load immediate
00000483  DEC R25 Decrement
00000484  BRNE PC-0x01 Branch if not equal
00000485  RJMP PC+0x0001 Relative jump
00000486  LDI R25,0x02 Load immediate
00000487  STD Z+6,R25 Store indirect with displacement
00000488  LDI R18,0x02 Load immediate
00000489  DEC R18 Decrement
0000048A  BRNE PC-0x01 Branch if not equal
0000048B  RJMP PC+0x0001 Relative jump
0000048C  STD Z+5,R25 Store indirect with displacement
    return 0; //liu20170209 if NAC than return fail.
0000048D  RET Subroutine return
0000048E  LDI R20,0x02 Load immediate
0000048F  DEC R20 Decrement
00000490  BRNE PC-0x01 Branch if not equal
00000491  RJMP PC+0x0001 Relative jump
00000492  LDI R30,0x20 Load immediate
00000493  LDI R31,0x06 Load immediate
00000494  LDI R24,0x02 Load immediate
00000495  STD Z+6,R24 Store indirect with displacement
00000496  LDI R24,0x01 Load immediate
00000497  STD Z+1,R24 Store indirect with displacement
00000498  RJMP PC+0x0001 Relative jump
00000499  RJMP PC+0x0001 Relative jump
0000049A  RET Subroutine return
0000049B  PUSH R14 Push register on stack
0000049C  PUSH R15 Push register on stack
0000049D  PUSH R16 Push register on stack
0000049E  PUSH R17 Push register on stack
0000049F  PUSH R28 Push register on stack
000004A0  PUSH R29 Push register on stack
000004A1  MOVW R14,R24 Copy register pair
000004A2  MOV R17,R22 Copy register
000004A3  MOV R28,R20 Copy register
if(!twi_start_cond()) return 0;
000004A4  CALL 0x00000446 Call subroutine
000004A6  TST R24 Test for Zero or Minus
000004A7  BREQ PC+0x22 Branch if equal
if( !i2c_write_byte( i2cSlaveAddress | 0x00 ) ) return 0;
000004A8  MOV R24,R28 Copy register
000004A9  CALL 0x0000045C Call subroutine
000004AB  TST R24 Test for Zero or Minus
000004AC  BREQ PC+0x1D Branch if equal
for(index = 0; index < bytes; index++) if ( !i2c_write_byte( indata[ index ] ) ) return 0;
000004AD  TST R17 Test for Zero or Minus
000004AE  BREQ PC+0x11 Branch if equal
000004AF  MOVW R28,R14 Copy register pair
000004B0  SUBI R17,0x01 Subtract immediate
000004B1  MOV R16,R17 Copy register
000004B2  LDI R17,0x00 Load immediate
000004B3  SUBI R16,0xFF Subtract immediate
000004B4  SBCI R17,0xFF Subtract immediate with carry
000004B5  ADD R16,R14 Add without carry
000004B6  ADC R17,R15 Add with carry
000004B7  LD R24,Y+ Load indirect and postincrement
000004B8  CALL 0x0000045C Call subroutine
000004BA  TST R24 Test for Zero or Minus
000004BB  BREQ PC+0x0E Branch if equal
000004BC  CP R28,R16 Compare
000004BD  CPC R29,R17 Compare with carry
000004BE  BRNE PC-0x07 Branch if not equal
000004BF  LDI R30,0x20 Load immediate
000004C0  LDI R31,0x06 Load immediate
000004C1  LDI R24,0x02 Load immediate
000004C2  STD Z+5,R24 Store indirect with displacement
000004C3  LDI R24,0x03 Load immediate
000004C4  DEC R24 Decrement
000004C5  BRNE PC-0x01 Branch if not equal
000004C6  NOP No operation
000004C7  LDI R24,0x01 Load immediate
000004C8  STD Z+5,R24 Store indirect with displacement
000004C9  POP R29 Pop register from stack
000004CA  POP R28 Pop register from stack
000004CB  POP R17 Pop register from stack
000004CC  POP R16 Pop register from stack
000004CD  POP R15 Pop register from stack
000004CE  POP R14 Pop register from stack
000004CF  RET Subroutine return
000004D0  PUSH R16 Push register on stack
000004D1  PUSH R17 Push register on stack
000004D2  PUSH R28 Push register on stack
000004D3  PUSH R29 Push register on stack
000004D4  MOVW R16,R24 Copy register pair
000004D5  LDI R24,0x01 Load immediate
000004D6  STS 0x0622,R24 Store direct to data space
000004D8  LDI R18,0x07 Load immediate
000004D9  LDI R19,0x00 Load immediate
  unsigned char byte = 0;
000004DA  LDI R22,0x00 Load immediate
000004DB  LDI R30,0x20 Load immediate
000004DC  LDI R31,0x06 Load immediate
000004DD  LDI R25,0x02 Load immediate
    byte|= (1 << (7- bit));
000004DE  LDI R28,0x01 Load immediate
000004DF  LDI R29,0x00 Load immediate
000004E0  STD Z+5,R25 Store indirect with displacement
000004E1  LDD R21,Z+8 Load indirect with displacement
000004E2  SBRS R21,0 Skip if bit in register set
000004E3  RJMP PC+0x0009 Relative jump
000004E4  MOVW R26,R28 Copy register pair
000004E5  MOV R0,R18 Copy register
000004E6  RJMP PC+0x0003 Relative jump
000004E7  LSL R26 Logical Shift Left
000004E8  ROL R27 Rotate Left Through Carry
000004E9  DEC R0 Decrement
000004EA  BRPL PC-0x03 Branch if plus
000004EB  OR R22,R26 Logical OR
000004EC  LDI R24,0x02 Load immediate
000004ED  DEC R24 Decrement
000004EE  BRNE PC-0x01 Branch if not equal
000004EF  RJMP PC+0x0001 Relative jump
000004F0  STD Z+6,R25 Store indirect with displacement
000004F1  LDI R24,0x02 Load immediate
000004F2  DEC R24 Decrement
000004F3  BRNE PC-0x01 Branch if not equal
000004F4  RJMP PC+0x0001 Relative jump
000004F5  SUBI R18,0x01 Subtract immediate
000004F6  SBC R19,R1 Subtract with carry
000004F7  BRCC PC-0x17 Branch if carry cleared
  rcvdata
= byte;
000004F8  MOVW R30,R16 Copy register pair
000004F9  ADD R30,R20 Add without carry
000004FA  ADC R31,R1 Add with carry
000004FB  STD Z+0,R22 Store indirect with displacement
  PORTB.OUTSET = 0x01;//Host NAC for the 9th bit in reading
000004FC  LDI R30,0x20 Load immediate
000004FD  LDI R31,0x06 Load immediate
000004FE  LDI R24,0x01 Load immediate
000004FF  STD Z+5,R24 Store indirect with displacement
00000500  STD Z+1,R24 Store indirect with displacement
00000501  LDI R25,0x02 Load immediate
00000502  STD Z+5,R25 Store indirect with displacement
00000503  LDI R18,0x02 Load immediate
00000504  DEC R18 Decrement
00000505  BRNE PC-0x01 Branch if not equal
00000506  RJMP PC+0x0001 Relative jump
00000507  STD Z+6,R25 Store indirect with displacement
00000508  RJMP PC+0x0001 Relative jump
00000509  RJMP PC+0x0001 Relative jump
0000050A  STD Z+6,R24 Store indirect with displacement
0000050B  RJMP PC+0x0001 Relative jump
0000050C  RJMP PC+0x0001 Relative jump
0000050D  STD Z+5,R25 Store indirect with displacement
0000050E  RJMP PC+0x0001 Relative jump
0000050F  RJMP PC+0x0001 Relative jump
  PORTB.OUTSET = 0x01; //Stop bit
00000510  STD Z+5,R24 Store indirect with displacement
00000511  POP R29 Pop register from stack
00000512  POP R28 Pop register from stack
00000513  POP R17 Pop register from stack
00000514  POP R16 Pop register from stack
00000515  RET Subroutine return
00000516  PUSH R15 Push register on stack
00000517  PUSH R16 Push register on stack
00000518  PUSH R17 Push register on stack
00000519  PUSH R28 Push register on stack
0000051A  PUSH R29 Push register on stack
0000051B  MOVW R16,R24 Copy register pair
0000051C  MOV R15,R22 Copy register
0000051D  MOV R28,R20 Copy register
0000051E  MOV R29,R18 Copy register
  if( !twi_start_cond() ) return 0;
0000051F  CALL 0x00000446 Call subroutine
00000521  TST R24 Test for Zero or Minus
00000522  BREQ PC+0x33 Branch if equal
  if( !i2c_write_byte( i2cSlaveAddress | 0x00 )) return 0;
00000523  MOV R24,R28 Copy register
00000524  CALL 0x0000045C Call subroutine
00000526  TST R24 Test for Zero or Minus
00000527  BREQ PC+0x2E Branch if equal
  if( !i2c_write_byte( i2cOffset )) return 0;
00000528  MOV R24,R29 Copy register
00000529  CALL 0x0000045C Call subroutine
0000052B  TST R24 Test for Zero or Minus
0000052C  BREQ PC+0x29 Branch if equal
0000052D  CALL 0x00000446 Call subroutine
0000052F  TST R24 Test for Zero or Minus
00000530  BREQ PC+0x25 Branch if equal
  if( !i2c_write_byte( i2cSlaveAddress | 0x01 )) return 0;
00000531  MOV R24,R28 Copy register
00000532  ORI R24,0x01 Logical OR with immediate
00000533  CALL 0x0000045C Call subroutine
00000535  TST R24 Test for Zero or Minus
00000536  BREQ PC+0x1F Branch if equal
    PORTB.DIRCLR = 0x02; //Temporarily turn SMCLK as input to sense PSU slave stretching.
00000537  LDI R24,0x02 Load immediate
00000538  STS 0x0622,R24 Store direct to data space
    while ( ! ( PORTB.IN & 0x02 ) );//Sense and wait for SMCLK stretching.
0000053A  LDI R30,0x20 Load immediate
0000053B  LDI R31,0x06 Load immediate
0000053C  LDD R24,Z+8 Load indirect with displacement
0000053D  SBRS R24,1 Skip if bit in register set
0000053E  RJMP PC-0x0002 Relative jump
0000053F  LDI R30,0x20 Load immediate
00000540  LDI R31,0x06 Load immediate
00000541  LDI R24,0x02 Load immediate
00000542  STD Z+5,R24 Store indirect with displacement
00000543  STD Z+1,R24 Store indirect with displacement
00000544  LDI R20,0x00 Load immediate
00000545  MOV R22,R15 Copy register
00000546  MOVW R24,R16 Copy register pair
00000547  CALL 0x000004D0 Call subroutine
00000549  TST R24 Test for Zero or Minus
0000054A  BREQ PC+0x0B Branch if equal
0000054B  LDI R30,0x20 Load immediate
0000054C  LDI R31,0x06 Load immediate
0000054D  LDI R24,0x02 Load immediate
0000054E  STD Z+5,R24 Store indirect with displacement
0000054F  LDI R24,0x03 Load immediate
00000550  DEC R24 Decrement
00000551  BRNE PC-0x01 Branch if not equal
00000552  NOP No operation
00000553  LDI R24,0x01 Load immediate
00000554  STD Z+5,R24 Store indirect with displacement
00000555  POP R29 Pop register from stack
00000556  POP R28 Pop register from stack
00000557  POP R17 Pop register from stack
00000558  POP R16 Pop register from stack
00000559  POP R15 Pop register from stack
0000055A  RET Subroutine return
--- C:\Users\liu\Desktop\BPN-SAS3-827HQ\BPN-SAS3-827HQ\BPN-SAS3-827HQ\Debug/.././TWI_slave.c
  TWIC_Slave_Buffer.bytesReceived = 0;
0000055B  LDI R30,0x1B Load immediate
0000055C  LDI R31,0x28 Load immediate
0000055D  STD Z+18,R1 Store indirect with displacement
TWIC_Slave_Buffer.bytesSent = 0;
0000055E  STD Z+19,R1 Store indirect with displacement
TWIC_Slave_Buffer.status = TWIS_STATUS_READY;
0000055F  STD Z+20,R1 Store indirect with displacement
TWIC_Slave_Buffer.result = TWIS_RESULT_UNKNOWN;
00000560  STD Z+21,R1 Store indirect with displacement
TWIC_Slave_Buffer.abort = 0;
00000561  STD Z+22,R1 Store indirect with displacement
TWID_Slave_Buffer.bytesReceived = 0;
00000562  LDI R30,0x04 Load immediate
00000563  LDI R31,0x28 Load immediate
00000564  STD Z+18,R1 Store indirect with displacement
TWID_Slave_Buffer.bytesSent = 0;
00000565  STD Z+19,R1 Store indirect with displacement
TWID_Slave_Buffer.status = TWIS_STATUS_READY;
00000566  STD Z+20,R1 Store indirect with displacement
TWID_Slave_Buffer.result = TWIS_RESULT_UNKNOWN;
00000567  STD Z+21,R1 Store indirect with displacement
TWID_Slave_Buffer.abort = 0;
00000568  STD Z+22,R1 Store indirect with displacement
TWIE_Slave_Buffer.bytesReceived = 0;
00000569  LDI R30,0xED Load immediate
0000056A  LDI R31,0x27 Load immediate
0000056B  STD Z+18,R1 Store indirect with displacement
TWIE_Slave_Buffer.bytesSent = 0;
0000056C  STD Z+19,R1 Store indirect with displacement
TWIE_Slave_Buffer.status = TWIS_STATUS_READY;
0000056D  STD Z+20,R1 Store indirect with displacement
TWIE_Slave_Buffer.result = TWIS_RESULT_UNKNOWN;
0000056E  STD Z+21,R1 Store indirect with displacement
TWIE_Slave_Buffer.abort = 0;
0000056F  STD Z+22,R1 Store indirect with displacement
TWIF_Slave_Buffer.bytesReceived = 0;
00000570  LDI R30,0x32 Load immediate
00000571  LDI R31,0x28 Load immediate
00000572  STD Z+18,R1 Store indirect with displacement
TWIF_Slave_Buffer.bytesSent = 0;
00000573  STD Z+19,R1 Store indirect with displacement
TWIF_Slave_Buffer.status = TWIS_STATUS_READY;
00000574  STD Z+20,R1 Store indirect with displacement
TWIF_Slave_Buffer.result = TWIS_RESULT_UNKNOWN;
00000575  STD Z+21,R1 Store indirect with displacement
TWIF_Slave_Buffer.abort = 0;
00000576  STD Z+22,R1 Store indirect with displacement
00000577  RET Subroutine return
  //PMSDA1/PMSCL1
  TWIC.CTRL = 0x00;
00000578  LDI R30,0x80 Load immediate
00000579  LDI R31,0x04 Load immediate
0000057A  STD Z+0,R1 Store indirect with displacement
  TWIC.SLAVE.ADDR = 0xA0
0000057B  LDI R24,0xA0 Load immediate
0000057C  STD Z+11,R24 Store indirect with displacement
  TWIC.SLAVE.ADDRMASK = 0x00;
0000057D  STD Z+13,R1 Store indirect with displacement
  TWIC.SLAVE.CTRLA = 0xf9;
0000057E  LDI R24,0xF9 Load immediate
0000057F  STD Z+8,R24 Store indirect with displacement
  TWID.CTRL = 0x00;
00000580  LDI R30,0x90 Load immediate
00000581  LDI R31,0x04 Load immediate
00000582  STD Z+0,R1 Store indirect with displacement
  TWID.SLAVE.ADDR = 0xB0;
00000583  LDI R25,0xB0 Load immediate
00000584  STD Z+11,R25 Store indirect with displacement
  TWID.SLAVE.ADDRMASK = 0x00;
00000585  STD Z+13,R1 Store indirect with displacement
  TWID.SLAVE.CTRLA = 0xf9;
00000586  STD Z+8,R24 Store indirect with displacement
  TWIE.CTRL = 0x00;
00000587  LDI R30,0xA0 Load immediate
00000588  LDI R31,0x04 Load immediate
00000589  STD Z+0,R1 Store indirect with displacement
  TWIE.SLAVE.ADDR = 0x74;
0000058A  LDI R25,0x74 Load immediate
0000058B  STD Z+11,R25 Store indirect with displacement
  TWIE.SLAVE.ADDRMASK = 0x00;
0000058C  STD Z+13,R1 Store indirect with displacement
  TWIE.SLAVE.CTRLA = 0xf9;
0000058D  STD Z+8,R24 Store indirect with displacement
  TWIF.CTRL = 0x00;
0000058E  LDI R30,0xB0 Load immediate
0000058F  LDI R31,0x04 Load immediate
00000590  STD Z+0,R1 Store indirect with displacement
  TWIF.SLAVE.ADDR = 0x76;
00000591  LDI R25,0x76 Load immediate
00000592  STD Z+11,R25 Store indirect with displacement
  TWIF.SLAVE.ADDRMASK = 0x00;
00000593  STD Z+13,R1 Store indirect with displacement
  TWIF.SLAVE.CTRLA = 0xf9;
00000594  STD Z+8,R24 Store indirect with displacement
00000595  RET Subroutine return
00000596  PUSH R1 Push register on stack
00000597  PUSH R0 Push register on stack
00000598  IN R0,0x3F In from I/O location
00000599  PUSH R0 Push register on stack
0000059A  CLR R1 Clear Register
0000059B  IN R0,0x38 In from I/O location
0000059C  PUSH R0 Push register on stack
0000059D  OUT 0x38,R1 Out to I/O location
0000059E  IN R0,0x39 In from I/O location
0000059F  PUSH R0 Push register on stack
000005A0  OUT 0x39,R1 Out to I/O location
000005A1  IN R0,0x3B In from I/O location
000005A2  PUSH R0 Push register on stack
000005A3  OUT 0x3B,R1 Out to I/O location
000005A4  PUSH R18 Push register on stack
000005A5  PUSH R24 Push register on stack
000005A6  PUSH R25 Push register on stack
000005A7  PUSH R26 Push register on stack
000005A8  PUSH R27 Push register on stack
000005A9  PUSH R30 Push register on stack
000005AA  PUSH R31 Push register on stack
  if (TWIC.SLAVE.STATUS & TWI_SLAVE_BUSERR_bm)
000005AB  LDS R24,0x048A Load direct from data space
000005AD  SBRS R24,2 Skip if bit in register set
000005AE  RJMP PC+0x0009 Relative jump
000005AF  LDI R30,0x1B Load immediate
000005B0  LDI R31,0x28 Load immediate
000005B1  STD Z+18,R1 Store indirect with displacement
000005B2  STD Z+19,R1 Store indirect with displacement
000005B3  STD Z+20,R1 Store indirect with displacement
TWIC_Slave_Buffer.result = TWIS_RESULT_BUS_ERROR;
000005B4  LDI R24,0x04 Load immediate
000005B5  STD Z+21,R24 Store indirect with displacement
000005B6  RJMP PC+0x00D3 Relative jump
  else if (TWIC.SLAVE.STATUS & TWI_SLAVE_COLL_bm)
000005B7  LDS R24,0x048A Load direct from data space
000005B9  SBRS R24,3 Skip if bit in register set
000005BA  RJMP PC+0x0009 Relative jump
000005BB  LDI R30,0x1B Load immediate
000005BC  LDI R31,0x28 Load immediate
000005BD  STD Z+18,R1 Store indirect with displacement
000005BE  STD Z+19,R1 Store indirect with displacement
000005BF  STD Z+20,R1 Store indirect with displacement
    TWIC_Slave_Buffer.result = TWIS_RESULT_TRANSMIT_COLLISION;
000005C0  LDI R24,0x03 Load immediate
000005C1  STD Z+21,R24 Store indirect with displacement
000005C2  RJMP PC+0x00C7 Relative jump
  else if ((TWIC.SLAVE.STATUS & TWI_SLAVE_APIF_bm) && (TWIC.SLAVE.STATUS & TWI_SLAVE_AP_bm))
000005C3  LDS R24,0x048A Load direct from data space
000005C5  SBRS R24,6 Skip if bit in register set
000005C6  RJMP PC+0x0027 Relative jump
000005C7  LDS R24,0x048A Load direct from data space
000005C9  SBRS R24,0 Skip if bit in register set
000005CA  RJMP PC+0x0023 Relative jump
000005CB  LDS R24,0x2831 Load direct from data space
000005CD  TST R24 Test for Zero or Minus
000005CE  BREQ PC+0x0B Branch if equal
000005CF  LDI R24,0x02 Load immediate
000005D0  STS 0x0489,R24 Store direct to data space
000005D2  LDI R30,0x1B Load immediate
000005D3  LDI R31,0x28 Load immediate
000005D4  LDI R24,0x06 Load immediate
000005D5  STD Z+21,R24 Store indirect with displacement
000005D6  STD Z+20,R1 Store indirect with displacement
000005D7  STD Z+22,R1 Store indirect with displacement
000005D8  RJMP PC+0x00B1 Relative jump
000005D9  LDI R30,0x1B Load immediate
000005DA  LDI R31,0x28 Load immediate
000005DB  LDI R24,0x01 Load immediate
000005DC  STD Z+20,R24 Store indirect with displacement
000005DD  STD Z+21,R1 Store indirect with displacement
      TWIC.SLAVE.CTRLA &= ~TWI_SLAVE_PIEN_bm;
000005DE  LDI R26,0x80 Load immediate
000005DF  LDI R27,0x04 Load immediate
000005E0  ADIW R26,0x08 Add immediate to word
000005E1  LD R24,X Load indirect
000005E2  SBIW R26,0x08 Subtract immediate from word
000005E3  ANDI R24,0xFB Logical AND with immediate
000005E4  ADIW R26,0x08 Add immediate to word
000005E5  ST X,R24 Store indirect
000005E6  SBIW R26,0x08 Subtract immediate from word
000005E7  STD Z+18,R1 Store indirect with displacement
000005E8  STD Z+19,R1 Store indirect with displacement
      TWIC.SLAVE.CTRLB = TWI_SLAVE_CMD_RESPONSE_gc;
000005E9  LDI R24,0x03 Load immediate
000005EA  ADIW R26,0x09 Add immediate to word
000005EB  ST X,R24 Store indirect
000005EC  RJMP PC+0x009D Relative jump
  else if (TWIC.SLAVE.STATUS & TWI_SLAVE_APIF_bm)
000005ED  LDS R24,0x048A Load direct from data space
000005EF  SBRS R24,6 Skip if bit in register set
000005F0  RJMP PC+0x000E Relative jump
000005F1  LDI R30,0x80 Load immediate
000005F2  LDI R31,0x04 Load immediate
000005F3  LDD R24,Z+8 Load indirect with displacement
000005F4  ANDI R24,0xFB Logical AND with immediate
000005F5  STD Z+8,R24 Store indirect with displacement
  TWIC.SLAVE.STATUS |= TWI_SLAVE_APIF_bm;
000005F6  LDD R24,Z+10 Load indirect with displacement
000005F7  ORI R24,0x40 Logical OR with immediate
000005F8  STD Z+10,R24 Store indirect with displacement
TWIC_Slave_Buffer.bytesReceived = 0; //Clear ISR data buffer
000005F9  LDI R30,0x1B Load immediate
000005FA  LDI R31,0x28 Load immediate
000005FB  STD Z+18,R1 Store indirect with displacement
000005FC  STD Z+20,R1 Store indirect with displacement
000005FD  RJMP PC+0x008C Relative jump
  else if (TWIC.SLAVE.STATUS & TWI_SLAVE_DIF_bm)
000005FE  LDS R24,0x048A Load direct from data space
00000600  TST R24 Test for Zero or Minus
00000601  BRLT PC+0x02 Branch if less than, signed
00000602  RJMP PC+0x0082 Relative jump
    if (TWIC.SLAVE.STATUS & TWI_SLAVE_DIR_bm)
00000603  LDS R24,0x048A Load direct from data space
00000605  SBRS R24,1 Skip if bit in register set
00000606  RJMP PC+0x0048 Relative jump
00000607  LDI R24,0x00 Load immediate
00000608  LDI R25,0x00 Load immediate
 TWIC_Slave_Buffer.sendData[ i ] = superMicroI2CFRU2[ TWIC_Slave_Buffer.receivedData[ 00 ] + i ];
00000609  LDI R26,0x1B Load immediate
0000060A  LDI R27,0x28 Load immediate
0000060B  ADIW R26,0x02 Add immediate to word
0000060C  LD R18,X Load indirect
0000060D  SBIW R26,0x02 Subtract immediate from word
0000060E  MOVW R30,R24 Copy register pair
0000060F  SUBI R30,0xFE Subtract immediate
00000610  SBCI R31,0xDF Subtract immediate with carry
00000611  ADD R30,R18 Add without carry
00000612  ADC R31,R1 Add with carry
00000613  LDD R18,Z+0 Load indirect with displacement
00000614  MOVW R30,R24 Copy register pair
00000615  SUBI R30,0xE5 Subtract immediate
00000616  SBCI R31,0xD7 Subtract immediate with carry
00000617  STD Z+10,R18 Store indirect with displacement
00000618  ADIW R24,0x01 Add immediate to word
for ( unsigned char i = 0; i < 8; i++ )
00000619  CPI R24,0x08 Compare with immediate
0000061A  CPC R25,R1 Compare with carry
0000061B  BRNE PC-0x10 Branch if not equal
      if ( ( TWIC_Slave_Buffer.bytesSent > 0 ) && ( TWIC.SLAVE.STATUS & TWI_SLAVE_RXACK_bm ) )
0000061C  LDS R24,0x282E Load direct from data space
0000061E  TST R24 Test for Zero or Minus
0000061F  BREQ PC+0x0E Branch if equal
00000620  LDS R24,0x048A Load direct from data space
00000622  SBRS R24,4 Skip if bit in register set
00000623  RJMP PC+0x000A Relative jump
00000624  LDI R24,0x02 Load immediate
00000625  STS 0x0489,R24 Store direct to data space
00000627  LDI R30,0x1B Load immediate
00000628  LDI R31,0x28 Load immediate
00000629  LDI R24,0x01 Load immediate
0000062A  STD Z+21,R24 Store indirect with displacement
0000062B  STD Z+20,R1 Store indirect with displacement
0000062C  RJMP PC+0x005D Relative jump
0000062D  LDS R24,0x282E Load direct from data space
0000062F  CPI R24,0x08 Compare with immediate
00000630  BRCC PC+0x16 Branch if carry cleared
          TWIC.SLAVE.DATA = TWIC_Slave_Buffer.sendData[TWIC_Slave_Buffer.bytesSent];
00000631  LDI R26,0x1B Load immediate
00000632  LDI R27,0x28 Load immediate
00000633  ADIW R26,0x13 Add immediate to word
00000634  LD R30,X Load indirect
00000635  SBIW R26,0x13 Subtract immediate from word
00000636  LDI R31,0x00 Load immediate
00000637  SUBI R30,0xE5 Subtract immediate
00000638  SBCI R31,0xD7 Subtract immediate with carry
00000639  LDD R24,Z+10 Load indirect with displacement
0000063A  LDI R30,0x80 Load immediate
0000063B  LDI R31,0x04 Load immediate
0000063C  STD Z+12,R24 Store indirect with displacement
          TWIC_Slave_Buffer.bytesSent++;
0000063D  ADIW R26,0x13 Add immediate to word
0000063E  LD R24,X Load indirect
0000063F  SBIW R26,0x13 Subtract immediate from word
00000640  SUBI R24,0xFF Subtract immediate
00000641  ADIW R26,0x13 Add immediate to word
00000642  ST X,R24 Store indirect
00000643  LDI R24,0x03 Load immediate
00000644  STD Z+9,R24 Store indirect with displacement
00000645  RJMP PC+0x0044 Relative jump
          TWIC.SLAVE.CTRLB = TWI_SLAVE_CMD_COMPTRANS_gc;
00000646  LDI R24,0x02 Load immediate
00000647  STS 0x0489,R24 Store direct to data space
          TWIC_Slave_Buffer.result = TWIS_RESULT_BUFFER_OVERFLOW;
00000649  LDI R30,0x1B Load immediate
0000064A  LDI R31,0x28 Load immediate
0000064B  STD Z+21,R24 Store indirect with displacement
0000064C  STD Z+20,R1 Store indirect with displacement
0000064D  RJMP PC+0x003C Relative jump
 TWIC.SLAVE.CTRLA |= TWI_SLAVE_PIEN_bm;
0000064E  LDI R30,0x80 Load immediate
0000064F  LDI R31,0x04 Load immediate
00000650  LDD R24,Z+8 Load indirect with displacement
00000651  ORI R24,0x04 Logical OR with immediate
00000652  STD Z+8,R24 Store indirect with displacement
      if (TWIC_Slave_Buffer.bytesReceived < TWIS_RECEIVE_BUFFER_SIZE)
00000653  LDS R24,0x282D Load direct from data space
00000655  CPI R24,0x08 Compare with immediate
00000656  BRCC PC+0x25 Branch if carry cleared
        TWIC_Slave_Buffer.receivedData[TWIC_Slave_Buffer.bytesReceived] = TWIC.SLAVE.DATA;
00000657  LDI R26,0x1B Load immediate
00000658  LDI R27,0x28 Load immediate
00000659  ADIW R26,0x12 Add immediate to word
0000065A  LD R30,X Load indirect
0000065B  SBIW R26,0x12 Subtract immediate from word
0000065C  LDI R31,0x00 Load immediate
0000065D  LDS R24,0x048C Load direct from data space
0000065F  SUBI R30,0xE5 Subtract immediate
00000660  SBCI R31,0xD7 Subtract immediate with carry
00000661  STD Z+2,R24 Store indirect with displacement
        TWIC_Slave_Buffer.bytesReceived++;
00000662  ADIW R26,0x12 Add immediate to word
00000663  LD R24,X Load indirect
00000664  SBIW R26,0x12 Subtract immediate from word
00000665  SUBI R24,0xFF Subtract immediate
00000666  ADIW R26,0x12 Add immediate to word
00000667  ST X,R24 Store indirect
00000668  SBIW R26,0x12 Subtract immediate from word
        if (TWIC_Slave_Buffer.abort)
00000669  ADIW R26,0x16 Add immediate to word
0000066A  LD R24,X Load indirect
0000066B  SBIW R26,0x16 Subtract immediate from word
0000066C  TST R24 Test for Zero or Minus
0000066D  BREQ PC+0x0A Branch if equal
0000066E  LDI R24,0x02 Load immediate
0000066F  STS 0x0489,R24 Store direct to data space
          TWIC_Slave_Buffer.result = TWIS_RESULT_ABORTED;
00000671  MOVW R30,R26 Copy register pair
00000672  LDI R24,0x06 Load immediate
00000673  STD Z+21,R24 Store indirect with displacement
00000674  STD Z+20,R1 Store indirect with displacement
          TWIC_Slave_Buffer.abort = 0x00;
00000675  STD Z+22,R1 Store indirect with displacement
00000676  RJMP PC+0x0013 Relative jump
00000677  LDI R24,0x03 Load immediate
00000678  STS 0x0489,R24 Store direct to data space
0000067A  RJMP PC+0x000F Relative jump
TWIC.SLAVE.CTRLB = TWI_SLAVE_ACKACT_bm | TWI_SLAVE_CMD_COMPTRANS_gc;
0000067B  LDI R24,0x06 Load immediate
0000067C  STS 0x0489,R24 Store direct to data space
0000067E  LDI R30,0x1B Load immediate
0000067F  LDI R31,0x28 Load immediate
00000680  LDI R24,0x02 Load immediate
00000681  STD Z+21,R24 Store indirect with displacement
00000682  STD Z+20,R1 Store indirect with displacement
00000683  RJMP PC+0x0006 Relative jump
    TWIC_Slave_Buffer.result = TWIS_RESULT_FAIL;
00000684  LDI R30,0x1B Load immediate
00000685  LDI R31,0x28 Load immediate
00000686  LDI R24,0x05 Load immediate
00000687  STD Z+21,R24 Store indirect with displacement
00000688  STD Z+20,R1 Store indirect with displacement
  reti();
00000689  RETI Interrupt return
0000068A  POP R31 Pop register from stack
0000068B  POP R30 Pop register from stack
0000068C  POP R27 Pop register from stack
0000068D  POP R26 Pop register from stack
0000068E  POP R25 Pop register from stack
0000068F  POP R24 Pop register from stack
00000690  POP R18 Pop register from stack
00000691  POP R0 Pop register from stack
00000692  OUT 0x3B,R0 Out to I/O location
00000693  POP R0 Pop register from stack
00000694  OUT 0x39,R0 Out to I/O location
00000695  POP R0 Pop register from stack
00000696  OUT 0x38,R0 Out to I/O location
00000697  POP R0 Pop register from stack
00000698  OUT 0x3F,R0 Out to I/O location
00000699  POP R0 Pop register from stack
0000069A  POP R1 Pop register from stack
0000069B  RETI Interrupt return
0000069C  PUSH R1 Push register on stack
0000069D  PUSH R0 Push register on stack
0000069E  IN R0,0x3F In from I/O location
0000069F  PUSH R0 Push register on stack
000006A0  CLR R1 Clear Register
000006A1  IN R0,0x38 In from I/O location
000006A2  PUSH R0 Push register on stack
000006A3  OUT 0x38,R1 Out to I/O location
  reti();
000006A4  RETI Interrupt return
000006A5  POP R0 Pop register from stack
000006A6  OUT 0x38,R0 Out to I/O location
000006A7  POP R0 Pop register from stack
000006A8  OUT 0x3F,R0 Out to I/O location
000006A9  POP R0 Pop register from stack
000006AA  POP R1 Pop register from stack
000006AB  RETI Interrupt return
000006AC  PUSH R1 Push register on stack
000006AD  PUSH R0 Push register on stack
000006AE  IN R0,0x3F In from I/O location
000006AF  PUSH R0 Push register on stack
000006B0  CLR R1 Clear Register
000006B1  IN R0,0x38 In from I/O location
000006B2  PUSH R0 Push register on stack
000006B3  OUT 0x38,R1 Out to I/O location
  reti();
000006B4  RETI Interrupt return
000006B5  POP R0 Pop register from stack
000006B6  OUT 0x38,R0 Out to I/O location
000006B7  POP R0 Pop register from stack
000006B8  OUT 0x3F,R0 Out to I/O location
000006B9  POP R0 Pop register from stack
000006BA  POP R1 Pop register from stack
000006BB  RETI Interrupt return
000006BC  PUSH R1 Push register on stack
000006BD  PUSH R0 Push register on stack
000006BE  IN R0,0x3F In from I/O location
000006BF  PUSH R0 Push register on stack
000006C0  CLR R1 Clear Register
000006C1  IN R0,0x38 In from I/O location
000006C2  PUSH R0 Push register on stack
000006C3  OUT 0x38,R1 Out to I/O location
  reti();
000006C4  RETI Interrupt return
000006C5  POP R0 Pop register from stack
000006C6  OUT 0x38,R0 Out to I/O location
000006C7  POP R0 Pop register from stack
000006C8  OUT 0x3F,R0 Out to I/O location
000006C9  POP R0 Pop register from stack
000006CA  POP R1 Pop register from stack
000006CB  RETI Interrupt return
--- No source file -------------------------------------------------------------
000006CC  MOV R0,R21 Copy register
000006CD  BST R25,7 Bit store from register to T
000006CE  BRTC PC+0x04 Branch if T flag cleared
000006CF  COM R0 One's complement
000006D0  CALL 0x000006E3 Call subroutine
000006D2  SBRC R21,7 Skip if bit in register cleared
000006D3  RCALL PC+0x0008 Relative call subroutine
000006D4  CALL 0x000006FA Call subroutine
000006D6  SBRC R0,7 Skip if bit in register cleared
000006D7  RCALL PC+0x0004 Relative call subroutine
000006D8  BRTC PC+0x0A Branch if T flag cleared
000006D9  JMP 0x000006E3 Jump
000006DB  COM R21 One's complement
000006DC  COM R20 One's complement
000006DD  COM R19 One's complement
000006DE  NEG R18 Two's complement
000006DF  SBCI R19,0xFF Subtract immediate with carry
000006E0  SBCI R20,0xFF Subtract immediate with carry
000006E1  SBCI R21,0xFF Subtract immediate with carry
000006E2  RET Subroutine return
000006E3  COM R25 One's complement
000006E4  COM R24 One's complement
000006E5  COM R23 One's complement
000006E6  NEG R22 Two's complement
000006E7  SBCI R23,0xFF Subtract immediate with carry
000006E8  SBCI R24,0xFF Subtract immediate with carry
000006E9  SBCI R25,0xFF Subtract immediate with carry
000006EA  RET Subroutine return
000006EB  MUL R26,R18 Multiply unsigned
000006EC  MOVW R22,R0 Copy register pair
000006ED  MUL R27,R19 Multiply unsigned
000006EE  MOVW R24,R0 Copy register pair
000006EF  MUL R26,R19 Multiply unsigned
000006F0  ADD R23,R0 Add without carry
000006F1  ADC R24,R1 Add with carry
000006F2  CLR R1 Clear Register
000006F3  ADC R25,R1 Add with carry
000006F4  MUL R27,R18 Multiply unsigned
000006F5  ADD R23,R0 Add without carry
000006F6  ADC R24,R1 Add with carry
000006F7  CLR R1 Clear Register
000006F8  ADC R25,R1 Add with carry
000006F9  RET Subroutine return
000006FA  LDI R26,0x21 Load immediate
000006FB  MOV R1,R26 Copy register
000006FC  SUB R26,R26 Subtract without carry
000006FD  SUB R27,R27 Subtract without carry
000006FE  MOVW R30,R26 Copy register pair
000006FF  RJMP PC+0x000E Relative jump
00000700  ROL R26 Rotate Left Through Carry
00000701  ROL R27 Rotate Left Through Carry
00000702  ROL R30 Rotate Left Through Carry
00000703  ROL R31 Rotate Left Through Carry
00000704  CP R26,R18 Compare
00000705  CPC R27,R19 Compare with carry
00000706  CPC R30,R20 Compare with carry
00000707  CPC R31,R21 Compare with carry
00000708  BRCS PC+0x05 Branch if carry set
00000709  SUB R26,R18 Subtract without carry
0000070A  SBC R27,R19 Subtract with carry
0000070B  SBC R30,R20 Subtract with carry
0000070C  SBC R31,R21 Subtract with carry
0000070D  ROL R22 Rotate Left Through Carry
0000070E  ROL R23 Rotate Left Through Carry
0000070F  ROL R24 Rotate Left Through Carry
00000710  ROL R25 Rotate Left Through Carry
00000711  DEC R1 Decrement
00000712  BRNE PC-0x12 Branch if not equal
00000713  COM R22 One's complement
00000714  COM R23 One's complement
00000715  COM R24 One's complement
00000716  COM R25 One's complement
00000717  MOVW R18,R22 Copy register pair
00000718  MOVW R20,R24 Copy register pair
00000719  MOVW R22,R26 Copy register pair
0000071A  MOVW R24,R30 Copy register pair
0000071B  RET Subroutine return
0000071C  CLI Global Interrupt Disable
0000071D  RJMP PC-0x0000 Relative jump
Sir/Madam,
The Atmel ICE periodically signals the RESET to Atxmega128A1U. See attached snapshots.
The RESET signal silenced after removing Atmel ICE.
What, in the code, is triggering the Atmel ICE to generated RESET signal to Atxmega128A1U ?
Sincerely,
Liu Wang
The issue has been fixed.
Thank you all for the comments.
Sincerely,
Liu Wang
