AS7 variables bug
15 posts / 0 new
A 2 bytes variable is displayed as a 4 bytes (double word) variable.
ADC_ch5:                    .byte    2          ; ADC previous ch5 readings
Also hovering the pointer over the variable name shows it a as a dword.
I see what's happening. The "value" is NOT the data in the variable but the address of it, I checked it by watching a couple more variables and it's their address rather that the data they contain
ie completely stuffed like a capsicum.
By the way this has been stuffed in various ways for at least 2.5 years! https://www.avrfreaks.net/forum/w...
And since it has been such a long time it is likely that the kids working on programming Studio have never seen what the widow should look like so here it is.
We have at least two tickets in the bug tracking system, and they are both closed with the following working procedure:
For AVR8 , nonGDB, Assembly Projects :
To view the content of the variable use "BY " , "WO " , or "DW " before the location in the watch view. This will treat it as a pointer that can be dereferenced to byte, word, or dword respectively.
E.g. instead of watching "VariableName", watch "BY VariableName".
For heaven's sake that was 2.5 years ago, I don't want a "workaround" I want a fix! PLEASE!
Also the value is WRONG, it is showing the address of the variable not it's contents. And why is everything 32 bits when I'm working with an 8 bits processor?
Ok, I re-opened TSD-464, but need some help in defining desired behaviour.
The rules are a bit confusing, and the kiddies coding this have not used assembly for the last 30-40 years.
Could you perhaps make a list of what is expected from watching an EQU, a .byte , dd dw etc ?
Some of these directives take a repeat argument. Does that turn the label into a pointer ?
I.e:
scalarvalue:  .byte 1
vectorvalue: .byte 2
In the OP, you are declaring an array of two bytes, so in a way it does makes sense to evaluate to a pointer (type=DWORD being just wrong)
If you wanted to declare a 2 byte variable you might have said  "Variable: .word 1" (Update: I've learned the assembler does not have .word or .dword )
What do you think ? Should all "BYTE n" be treated as an n-byte scalar ?
I should be in bed sleeping but anyway....
Tried to open the assembly Help file in AS7 and it doesn't seem to exist so I went back to AS4.18.
The only valid syntax for data in RAM seems to be .byte
The BYTE directive reserves memory resources in the SRAM or EEPROM
There is also DW (incorrect for RAM, tried but no difference in result) DD and DQ however they are for EEPROM or flash.
DW - Define constant word(s) in program memory and EEPROM
DD - Define constant doubleword(s) in program memory and EEPROM
DQ - Define constant quadword(s) in program memory and EEPROM
so .byte is/can be used for anything in RAM, in the above case as a 2 bytes "variable" to hold the results of the ADC5. But it can also be a pointer or just consecutive data.
I see where the confusion results for the poor "kiddies".
Perhaps the definitions for DW, DD and DQ could be extended to RAM as well and then there should not be any confusion as to the size of the variable for display purposes. The user would just need to change the definitions in the code accordingly.
I tend to agree. If it was me I'd treat it pretty much the same as "unsigned char *" in C. If you could then dereference it like putting a watch on "ADC_ch5[1]" that would be great. Even better if you could "cast" it so something like "(unsigned int *)data[5]" which would show five 2 byte entries interpreted as unsigned words etc.
I'm not near Studio right now. What happens in C if you just use:
unsigned char data[4];
then watch "data". Does it show the address the pointer is pointing to or does it dereference it and show the 4 bytes at the target?
Even with the work around to tell Studio what the data is the value is still wrong, need sleep now.
Does it need a '*' ?
WO * ADC_ch5
to dereference the pointer perhaps?
BTW, just out of interest why use .byte for a 2 byte array rather than .dw to say it is a "word"?
No * needed, the BY, WO and DW operators interpret their operand as a pointer and dereference it. The syntax is something we picked from the standard Microsoft Visual Studio.
If WO doesnt dereference its' operand I will file it as a separate bug.
See post #7 above. .byte is the only thing usable for RAM according to the assembler help but it doesn't seem to care if one uses DW or other outside their respective memory segments. I'll do a bit more testing if I get some time today.
It seems illogical to be able to use DW, DD and DQ for data in EEPROM but not allowed for RAM??
Anyway if the above definitions works for RAM and it will fix the watch bug I'm happy to modify my code with DW for 2 bytes variables.
I guess it could work this way:
.byte 1 or DB 1 single byte variable or constant
.byte 2, .byte x data array with + same as in C
.DW word variable or constant
.DD double word variable or constant
.DQ quad word variable or constant
I can kind of see the point - because Asm has no equivalent of C's _do_copy_data() you couldn't do something like:
.dseg
somevar: .dw 12345
and expect the 12345 to be there when your code starts. Yet if you use:
.eseg
somevar: .dw 12345
then, because of the .eep file you program the 12345 will be there. In RAM all you can do is reserve some space for something you are going to put there later (at run time) so I now understand why you'd use .byte and not the others in .dseg
So really we need a couple of additional keywords in the avrasm? (avrasm3.exe??)  angel
So, i just installed atmel studio 7, and they still show byte variables as dword. How to add BYTE variables to the watch view, then?
I still have avr studio 4 installed. In that version, it showed all variables as 1 byte variables. Not really true, but at least better than showing it as dword and with the memory address instead of the value.
There is no need for additional variable definitions to fix that. For example, take a look at this variable definition:
DecTics:    .BYTE 2
Unsurprisingly, it's a 2 byte variable.
Can also be used to define some memory buffer:
UsartTxBuff:    .BYTE 32
For this kind of assembler variables, i think a "correct" solution would be at least to show the number of bytes defined, as if it was a limited size memory dump. An option to view it as an n-byte signed or unsigned number wouldn't be crazy, either.
For example:
Variable Size Value
Dectics 2 (FF 6A | Unsigned 65386 | Signed -150)
UsartTxBuff 32 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20
That would do.
