WILC1000 Driver in mainline Linux doesn't work ?
2 posts / 0 new
I've been trying to test the WILC1000 SDIO module with the SAMA5D3 Xplained board and the latest Linux Mainline Version (4.12.0-rc7).
I'm using also the following firmware: wilc1003_firmware.bin v14.1 from https://github.com/linux4sc/wire...
this is the result:
# modprobe wilc1000-sdio
wilc1000: module is from the staging directory, the quality is unknown, you have been warned.
wilc1000_sdio: module is from the staging directory, the quality is unknown, you have been warned.
wilc1000_sdio mmc0:0001:1: Driver Initializing success
# modprobe wilc1000
# ifconfig wlan0 up
wilc1000_sdio mmc0:0001:1: chipid (001003a0)
wilc1000_sdio mmc0:0001:1: has_thrpt_enh3 = 1...
wilc1000_sdio mmc0:0001:1 wlan0: loading firmware atmel/wilc1003_firmware.bin
random: crng init done
wilc1000_sdio mmc0:0001:1 wlan0: WLAN Iinitialization FAILED
wilc1000_sdio mmc0:0001:1 wlan0: Failed to set driver handler
wilc1000_sdio mmc0:0001:1 wlan0: [Host Interface] undefined
ifconfig: SIOCSIFFLAGS: Input/output error
I've added some printf in another version and it seems that the firmware cannot start !
I would really like any input ! Thanks!
Anthony Harivel
I add problems too to make the Wilc1000 work!
You may found some information here:
http://www.at91.com/discussions/...
It seems that the 14.1 version is not working. Try with the v14...
But Atmel do not seems to maintain this firmware any more.
