Loops error
11 posts / 0 new
#define F_CPU 1200000
#include <util/delay.h>
#include <avr/interrupt.h>
int count;
ISR(INT0_vect)
    cli();
    _delay_ms(25); //Debounce Switch
    count++;
    if (count >4, count = 0) //Reset count after Mode 4
    sei();
    MCUCR |= (1<<ISC00);
    GIMSK |= (1<<INT0);
    DDRB = 0x1F;
    PORTB |= (1<<PINB5); //enable Internal Pull Up
    sei();
    int delay1 = 75;
    int delay2 = 500;
    int delay3 = 1000;
    count = 0;
        _delay_ms(500);
        while(count == 0) //Standby Mode
            PORTB = 0x00;
        while(count == 1) //Mode 1 Double Alternating Flash Fast
            PORTB = 0x01; //Turn LED 1 on
            _delay_ms(delay1);
            PORTB = 0x00; //Turn LED 1 off
            _delay_ms(delay1);
            _delay_ms(delay1);
            PORTB = 0x02; //Turn LED 2 on
            _delay_ms(delay1);
            PORTB = 0x00; //Turn LED 2 off
            _delay_ms(delay1);
            _delay_ms(delay1);
        while(count == 2) //Mode 2 Single Alternating Flash Fast
            _delay_ms(delay2);
            _delay_ms(delay2);
        while(count == 3) //Mode 3 Single Alternating Flash Slow
            PORTB = 0x01; //Turn LED 1 on //Turn LED 1 on
            _delay_ms(delay3);
            _delay_ms(delay3);
        while(count == 4) //Mode 4 Both LEDs Simultaneous
            PORTB = 0x03;
            _delay_ms(delay2);
            PORTB = 0x00;
            _delay_ms(delay2);
I get this error when compiled
any ideas or suggestions I have looked at tutorials and articles and cant see any thing wrong
It looks as if you have indented nicely. It would be clearer if you had pasted your code inside code tags.
The braces are balanced UNTIL you get to the while(count ==2) line.
Remove one right brace.
You have several other problems. You must use constant numbers with _delay_ms()
Instructions here: https://www.avrfreaks.net/wiki/ad...
The OP seems to be using Atmel Studio; IIRC, it highlights the matching brace when the cursor is on a brace - so mis-matched braces should be easy to spot ...
And, count should be declared as volatile...
:: Morten
Two.  Here's the OP's code washed through bcpp:
int count;
ISR(INT0_vect) {
  cli();
  count++;
    sei();
int main(void) {
  GIMSK |= (1<<INT0);
  DDRB = 0x1F;
  sei();
  int delay1 = 75;
  int delay2 = 500;
  int delay3 = 1000;
  count = 0;
  while(1) {
    _delay_ms(500);
    while(count == 0) {                 //Standby Mode
      PORTB = 0x00;
    while(count == 1) {                 //Mode 1 Double Alternating Flash Fast
      _delay_ms(delay1);
      _delay_ms(delay1);
      _delay_ms(delay1);
      _delay_ms(delay1);
      _delay_ms(delay1);
      _delay_ms(delay1);
while(count == 2) {                     //Mode 2 Single Alternating Flash Fast
  _delay_ms(delay2);
  _delay_ms(delay2);
while(count == 3) {                     //Mode 3 Single Alternating Flash Slow
  _delay_ms(delay3);
  _delay_ms(delay3);
while(count == 4) {                     //Mode 4 Both LEDs Simultaneous
  PORTB = 0x03;
  _delay_ms(delay2);
  PORTB = 0x00;
  _delay_ms(delay2);
The highlighted braces are superfluous.  Without them:
int count;
ISR(INT0_vect) {
  cli();
  count++;
    sei();
int main(void) {
  GIMSK |= (1<<INT0);
  DDRB = 0x1F;
  sei();
  int delay1 = 75;
  int delay2 = 500;
  int delay3 = 1000;
  count = 0;
  while(1) {
    _delay_ms(500);
      PORTB = 0x00;
      _delay_ms(delay1);
      _delay_ms(delay1);
      _delay_ms(delay1);
      _delay_ms(delay1);
      _delay_ms(delay1);
      _delay_ms(delay1);
      _delay_ms(delay2);
      _delay_ms(delay2);
      _delay_ms(delay3);
      _delay_ms(delay3);
      PORTB = 0x03;
      _delay_ms(delay2);
      PORTB = 0x00;
      _delay_ms(delay2);
As mentioned, there are other issues with your code.  Some have been mentioned, some have not.  Come back when you run into them.
sei() within an ISR() often means "slow suicide" and invariably represents poor program design.
The OP has (many) bigger fish to fry:
    sei();
count will always be  0.  The sei() will never run.
One should never use delay in an ISR(),  best to keep ISR's as fast as possible!
ISR(INT0_vect) {
  cli();
  count++;
    sei();
ki0bk wrote:
One should never use delay in an ISR()...
Y'all are into the superlatives today.  Certainly there are situations where either of those techniques might be used, but indeed unlikely in this type of program.
So let's first point OP at the datasheet on interrupt handling for the basis behind "no cli or sei in ISRs":
When an interrupt occurs, the Global Interrupt Enable I-bit is cleared and all interrupts are disabled. The user software can write logic one to the I-bit to enable nested interrupts. All enabled interrupts can then interrupt the current interrupt routine. The I-bit is automatically set when a Return from Interrupt instruction – RETI – is executed.
So there is no need for the cli, and nested interrupts aren't desired and the compiler will get the RETI in there.
Now on to my main reason for posting:
Debounce, eh?  Well, kindof/maybe.  I'd say "not".   But if the switch bounces then the interrupt flag will again be set and the interrupt re-entered -- no matter if you delay 25us or 25 seconds.  (and the sei means that the interrupts would be nested...)
Cheers guys, Had a read through this and the suggestions have all been a huge help,
