Interesting tip for variables storage
13 posts / 0 new
I saw this "tip" in Atmel's C programming app note (from a long time ago)...is this still viable, widely used or never used???...never heard or thought of  using "spare" control registers until now.   Seems a bit dangerous & sneaky (and a potential for mysterious brain busting bugs).
Unused locations in the I/O Memory can be utilized for storing global variables when certain peripherals are not used. As example, If the UART is not used the UART Baud Rate Register (UBRR) is available, and if the EEPROM is not used both the EEPROM Data Register (EEDR) and the EEPROM Address Register (EEAR) will be available to store global variables.
Sounds very much like "fiddling while Rome burns".
Or, perhaps, "rearranging the deckchairs on the Titanic".
I'd have thought that if you need to scratch about for the odd byte here & there like that, then it's really time to be moving up to a bigger-RAM part - or having a major review of your RAM usage.
An alternative view is job security supporting the product - most normal people trying to introduce a new feature to the product would get pummeled by mysterious problems.  Sneaky indeed!
Why would you use that at all?
If you are in a range where 1 ticks of IN / OUT vs. LDS / STS alrfeady matters, then you want to use (inline) assembler for that part or for the whole application.
Moreover, such variables don't comply to the C standard because they are in static storage but not initialized by startup-code (except you are using own akward startup-code).
avrcandies wrote:
...from a long time ago...
Perhaps it dates from the time when assembler was the only language to write AVR code in and RAM was in short supply?
From about 2005 onwards AVRs have GPIOR0 in the SBI/CBI range so you can arrange to put your 8 most used binary flags into it. On "old iron" like mega16/mega32 there was no such luxury so I have habitually used TWAR for this purpose. It's an 8 bit read/write register, in range of SBI/CBI and, unless you use I2C, untouched.
I will say it's from the time where some AVR didn't have any RAM!
With the "new and improved" I/O memory-maps [roughly, those models having 256 bytes of I/O memory space] the valuable low memory space is so sparse that the technique isn't too attractive anymore.  GPIOR0 is the exception.  If you have to use the SRAM-mapped address to use a "spare" I/O register, only the most pathological apps needing "one more byte" might be candidates.
It has been discussed at some length over the years.
The tip come from page 14 of this Atmel document (AVR035):
http://ww1.microchip.com/downloads/en/AppNotes/doc1497.pdf
So from January 2004.
remember it's from 2004, there the chips had a lot of IO's in the lower end.
And I see that on page 15 there is an error ! in the table it say it take 4 bytes to set/clear a bit in a register! (for the top 16 it's only 2).
So like any Atmel documents there is a lot of errors!
I wonder what is the time constant, (or even half-life) of an Atmel tip ?surprise
