ili9163 mirror image
5 posts / 0 new
I use the ili9163 128*160 lcd eventually got the code to work (the original code was for 8bit parallel interface)and my display is serial.
The sample code i use does not have small,big fonts ...so i used another sample code for a different lcd and delete the long initial setup and replace it with the ili9163 initial setup.
The lcd does intialise and clear(BLACK) the only problem is the printing is a mirror image.
I would appresiate any sugestions.
You can draw text and graphics in any direction,  invert colours, ... with any of the TFT controllers that I have used.
Attach a ZIP of your project or paste your code.   And I will tell you which Manufacturer Register to alter.
The first step is to get Portrait orientation correct.   i.e. ribbon at bottom of panel.
David
Are we allowed to know what the "problem" is?
If I light 10110101 then I get pixels in one direction. If I do it as 10101101 then is that not the "mirror image"? What am I missing?
Total votes: 2
Simple solution:  Ship a mirror with each device. ;)
[over the years, that solution has been proposed when a circuit worked when 'scoped but not otherwise...ship a 'scope with each unit. ]
[[or add a small cap roughly equivalent to the probe capacitance]]
Thanks David
Your suggestion was spot on i modified the code for ili9341 to work on ili9163, the orientation data  setup is different between the 2 controllers ,the display is now normal.
(I cancelled my order for the little mirrorsurprise) One little step forward .....into the dark mystery of the unknown C PROGRAMMING.
