ATmega328p UART framing error does not occur!
31 posts / 0 new
There is a protocole over serial port as following:
1. no signal (idle) is High (+5V).
2. reset signal is a 60 us Low (0v) pulse.
3. data signal is : 250 kbps/8 bits/2 stop/no parity
I want to detect reset signal using Frame Error capability of MCU (ATmega328p)
250 kbps so 1 bit is 4us,
serial packet is 11 bit = 44 us
the farme format is = start-b0-b1-b2-b3-b4-b5-b6-b7-stop1-stop2
for normal data = 0-x-x-x-x-x-x-x-x-1-1
for reset pulse = 0-0-0-0-0-0-0-0-0-0-0-0-0-0-0
According page 245 of the data sheet, if 1st Stop bit of RX data is zero, FE0 (bit4) of UCSR0A register is set by MCU
But it does not occur for me!
I am just curious why Frame Error does not occur, whilst the datasheet says it occures!
Majid
Most likely because of an error in your software. E.g. did you notice you have to read UCSRA before UDR?
Stefan Ernst
here is the code:
automatic code generated by CVAVR
i changed if else as my design
// USART Receiver interrupt service routine
interrupt [USART_RXC] void usart_rx_isr(void)
char status;
char data;
status=UCSR0A;
data=UDR0;
if (status & 0x10) // framing error
bReset = 1;
ucData[ucIndex++] = data;
Majid
Instructions for properly posting source code: https://www.avrfreaks.net/comment... (also how to embed images)
    char status;
    char data;
    status=UCSR0A;
    data=UDR0;
        bReset = 1;
Majid
How are you detecting that?
i need my code ignore reset pulse, just buffer input data
for normal data it works nice, every data is correct
but can not handle reset pulse, cause Frame Error not work,
and interprete reset pulse as 2 data : 00, E0 and puts in buffer by mistake,
Majid
i use proteus to trace the code step by step , never goes to bReset = 1; bReset ramains 0 forever.
program interprete 60 us break (0V pulse) as 2 normal data :0x00 ans 0xE0
Majid
Total votes: 2
Wait! Do we actually talk about a simulated Mega328 here?
Then ask the Poteus support why the FE bit is not set.
Stefan Ernst
In your ISR you have
bReset = 1;
Is bReset declared as volatile.
hmm , yes its possible,
for now just simulating is available for me, for test on real IC i must wait a few days
Majid
Before that, does Proteus even claim to simulate framing errors?
If it does, are you sure that you have followed the instructions carefully, correctly, and completely?
#include <mega328p.h>
bit bReset;
unsigned char ucData[256];
unsigned char ucIndex, ucWriteIndex;
    char status;
    char data;
    status=UCSR0A;
    data=UDR0;
        bReset = 1;
#include <stdio.h>
void main(void)
// Crystal Oscillator division factor: 1
#pragma optsize-
CLKPR=0x80;
CLKPR=0x00;
#ifdef _OPTIMIZE_SIZE_
#pragma optsize+
#endif
// Input/Output Ports initialization
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0A output: Disconnected
// OC0B output: Disconnected
TCCR0A=0x00;
TCCR0B=0x00;
TCNT0=0x00;
OCR0A=0x00;
OCR0B=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2A output: Disconnected
// OC2B output: Disconnected
ASSR=0x00;
TCCR2A=0x00;
TCCR2B=0x00;
TCNT2=0x00;
OCR2A=0x00;
OCR2B=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// Interrupt on any change on pins PCINT0-7: Off
// Interrupt on any change on pins PCINT8-14: Off
// Interrupt on any change on pins PCINT16-23: Off
EICRA=0x00;
EIMSK=0x00;
PCICR=0x00;
// Timer/Counter 0 Interrupt(s) initialization
TIMSK0=0x00;
// Timer/Counter 1 Interrupt(s) initialization
TIMSK1=0x00;
// Timer/Counter 2 Interrupt(s) initialization
TIMSK2=0x00;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: On
// USART Transmitter: On
// USART0 Mode: Asynchronous
// USART Baud Rate: 250000
UCSR0A=0x00;
UCSR0B=0x98;
UCSR0C=0x06;
UBRR0H=0x00;
UBRR0L=0x03;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
ADCSRB=0x00;
// Global enable interrupts
#asm("sei")
    bReset = 0;
    ucIndex = 0;
    ucWriteIndex = 0;
    while (1)
        if (ucWriteIndex != ucIndex)
            putchar(ucData[ucWriteIndex++]);
        if (bReset)
            ucWriteIndex = ucIndex;
            bReset = 0;
code is auto generated by CVAVR
I added if else
it works nice for normal data
Majid
proteus claims simulating USART
I will test the real IC in a few days, share the result!
thanks everone
Majid
That wasn't the question!
The question was: does it simulate the Framing Error detection?
sternst wrote:
Wait! Do we actually talk about a simulated Mega328 here? Then ask the Poteus support why the FE bit is not set.
+1.  At least one.
Sounds like we're doing dmx512 here. There should be plenty of examples on the internet. Google arduino dmx512.
If a 60µs continuous low pulse is received as two bytes (0x00 and 0xE0), then it does not even simulate the start bit detection correctly.
Stefan Ernst
If you are simulating then how are you generating the framing error?
-deleted-
Looking at wrong datasheet/
blue_z wrote:
The framing error is supposed to be suppressed because you have a break condition.
Ehh what?!? The framing error is specifically USED to detect break conditions. From the datasheet:
The FE Flag is zero when the stop bit was correctly read as '1', and the FE Flag will be one
when the stop bit was incorrect (zero). This flag can be used for detecting out-of-sync conditions,
detecting break conditions and protocol handling.
yes I also simulating 60us break pulse,
Majid
yes, I exactly want to deploy FE to detect break,
Majid
I did the test with ATmega88 and ATmega328P
code works fine on real ICs
same code does not work on simulated models in proteus isis
seems the simulated model does not support FE of USART
Majid
What did Proteus support have to say?
I wrote them, they didnt reply yet
Majid
I got reply from support team,
they have fixed the problem and sent new dll for avr model
my project works fine with new model
problem solved !
Majid
You mean the Proteus support team?
So this was a Protues problem - nothing to do with AVR?
yes as I mentioned before , I tested on real chip.
project works fine on real chip.
nothing wrong with avr and my code.
the other possibilities were:
1. problem in AVR model on Proteus
2. user problem (me!) in using Proteus
they sent me new AVR2.DLL file , so problem established and fixed , it was Proteus model.
now my code works fıne on both simulated model on Proteus and real chip of ATmega88 and ATmega328P
Majid
Excellent.
Please provide version details for the benefit of future readers ...
awneil wrote:
Excellent.
of course, here is summary
problem : Framing Error (FE0 flag of UCSR0A register) is not working in simulated model of AVR in Proteus 8.6 SP3 program
cause : there is a bug in AVR2.dll file
solution : new version (Ver: 8.3.24150.0) of AVR2.dll file must be obtained from https://support.labcenter.com
and replaced in C:\ProgramData\Labcenter Electronics\Proteus 8 Professional\MODELS
good luck!
Majid
