AVR controlled power
9 posts / 0 new
I'm just starting off building up a AT power supply replacement (Xbox) to go into a friends car. I'm familiar with h bridges, AVR programming and car electrics but no expert. I'm throwing this out there and hoping for some constructive criticism.
At the moment I'm thinking a linear regulator (7812 + pass transistor)for 12V (~3A) rail with fastPWM controlled switching into LC low pass networks, independent for the 5volt (~10A) and 3.3volt (~5A) rails. The PWM would be fuzzy controlled though a very heavily filtered/averaged ADC. The electronics would run off a 7805 with good heatsink and the entire enclosure would be shielded and well away from the engine bay. I have some mega8s lying around so I'll use one of them.
In general Xboxes are very tolerant of thier power supplies so there is little chance of catastrauphic failure.
you know about the commercially available PC power supplies designed for use in cars with 12V as the prime power, right? I haven't looked in a while, but prices were falling.
one place to start looking is
http://www.mini-itx.com/Default.asp
Thanks, I didn't realise they had gotten so cheap... and small.
Over here (Australia) they are still asking $150+ through the usual sources.
There'd still be a bit of hacking to do though, and then there's the question of actually getting one posted here for a reasonable price. Never know...
You aren't going to like the results of running a 7812 regulator in a car. It's only specified for inputs geater than 14.5 volts which isn't supposed to happen. A typical boost transistor configuration increases that input requirement by about another volt (15.5 total).
Good point, LM1084 (low drop out version LM317) and a resistor bridge should fix that
On further consideration I think I'll go for all three voltages done as switchmode. Once I have the fuzzy tuned (which will be a pain) the rest is childs play.
This isn't a straight buck or boost design, since you want 12V out with 10V...14.4V in. But the books show plenty of circuits to do the job.
Why not just get a cheap 12v to 110vac inverter and simply plug the XBOX into that?
We use one we got at Wal-Mart to run a laptop in the car...it cost like 35$
There is no WAY in the world u can get 3A @ 12 out of 7812 unless u use a FAN or a greate heat-sink.
My consideration, simply make a Switching power supply. it needs an extra inductor, but u can find
alot of components on Analog-Deivces, ON-semi, TI,
Fairchild-semi, .....
Good luck
Nasser
