Usart Registers are never written to
4 posts / 0 new
I am programming an xmega16a4u with a jtagice mkII in Atmel Studio 7.
I am currently trying to get the Usart to work, but the registers are never written to.
My code:
	PORTD.DIR |= (1 << 3);
	PORTD.DIR &= ~(1 << 2);
	USARTD0.BAUDCTRLA |= 0x03;
	USARTD0.BAUDCTRLB |= (0b1001 << 4 | 0x06);
	USARTD0.CTRLA |= USART_RXCINTLVL_LO_gc;
	USARTD0.CTRLB |= USART_TXEN_bm | USART_RXEN_bm;
	USARTD0.CTRLC |= USART_CHSIZE_8BIT_gc;
		while (!( USARTC0.STATUS & USART_DREIF_bm));
		USARTC0.DATA = 0x47;
After executing this code, BAUDCTRLA, for example, still is 0.
I am looking forward to your answers.
Note that it is not necessarily the case that a hardware register will read-back what you just wrote to it.
Are those registers supposed to read-back what you wrote to them?
Hmm...  You configure USARTD0, but in the while loop, you are checking the status of USARTC0.  What's up with that?
Are you using ASF?
Greg Muth
Portland, OR, US
Atmel Studio 7 (Version: 7.0.1652) on Windows 10
Thank you for your answer. I simply forgot to reenable the module.
