reverse engineering
20 posts / 0 new
Is it possible for someone else to "see" my code once it's been programmed onto a chip?
It all depends on how you have the fuse bits set. There are some who will tell you that they can extract code from any processor, but that is an expensive and slow process and not one that most of us need worry about. If you are the CIA or such, maybe, but not most of "normal" folks.
CIA :? ... Not really! Just visit a "copy factory" in China and you'll be amazed how fast they can "pull-out" the program from inside your (protected) AVR ! :twisted:
Real men don't use backups, they post their stuff on a public ftp server and let the rest of the world make copies.
Out of curiosity - have any idea what sort of process this entails?
Chuck Baird
http://www.cbaird.org
I heard that a laser is used to alter some bits somehow.
I read that somewhere on another forum.
I Chinese friend of mine says that China has "Copyrights"...or the Rights to Copy anything... :)
read it on the Internet so it must be true!
How much is a machine-language copy of your code really worth?
In many products the code could be reproduced just by observation, and possibly even improved upon.
There was a fellow on this forum who had done some research into it, and claimed he could easily recover the code from a locked AVR. At the time this was the older processors, AT90S2313 or similar.
Anyway I put it to the test - and mailed him a locked AVR. He e-mailed me a perfect copy of the code in the AVR.
There is a very interesting article at http://www.cl.cam.ac.uk/~sps32/m... and check out his Phd as wel.
-Colin
Hi c_oflynn :)
That article was interesting....indeed, they do use lasers to assist in the compromising of chips.
Reminded me of an article on bunnie's blog, about reseting security fuses on PICS:
http://www.bunniestudios.com/wordpress/?page_id=40
Hi dmonn :)
Great article!
I wonder how that guy got the chip out of the package?
If he sent them off and payed that 50$ each then that is really expensive.
Google around and you'll find some info, like grinding the top off the chip to get at the security bits.
"If it wasn't for bad luck I'd have no luck at all"
Personally I've always wondered why they don't coat the die in an oxidizing layer (or photosensitive layer). While the vacuum or dark room would add minimally to the cost of the device, it would add an extra physical layer of security - once opened, the die would either corrode or blacken to the point of being irretrievable.
Who knows - perhaps the secure AVRs have a system just like that?
- Dean :twisted:
EDIT: Or a coating that emits UV photons when struck by other wavelengths. Put that over the flash section and its bye-bye data if the case is opened!
Like what they use to do in Mission Impossible, tapes, pictures, even PCB's would go up in smoke after they were used.
That's what usually happens to mine when I first turn on the power :)
Gwen - didn't your parents tell you that smoking is bad - mmmkay. Drugs are bad mmkay.
If it really only costs USD50 to copy flash from a micro, that is dirt cheeeeep for a commercial project. For a US engineer, you could hardly pay for a couple of hours time, if even that.
There are times I might have "killed" for that.
I like the idea of an oxidising layer inside a chip, and the UV idea is cool too... though wonder if a uv emitting cover would convert enough UV from abient light to make it worthwhile?
Also, whatever the coating property you had, if you stripped the part in darkness (or vacuum, as necessary!) and then washed to destructive coating off, you'd be set.
How about a photocell hooked up to something that will cause an erase cysle on the flash? though that requires light and power to be applied at the same time.
The other thing you could do, is a smaller version of what they do in things like ATMs... have a cage of very fine, easily breakable wires around the processor core (perhaps printed inside the IC cavity!) and continually shoot random patterns into them, and read checksums.... though the complexity of that makes your chip a heap bigger and more expensive, and less efficient.....
I think that whatever process gets used, though, reverse engineers will find out a way to get around it. And once that's done, no code in that device would be safe, again.
