Mega328 timer 2 interrupt
12 posts / 0 new
As soon as I set the TIMSK to enable timer 2 interrupt, my program stops working, so obviously, I've overlooked something:
Setup routine:
void setup()
  pinMode(steadyPin, OUTPUT);
  pinMode(flashingAPin1, OUTPUT);
  pinMode(flashingBPin1, OUTPUT);
  pinMode(flashingAPin2, OUTPUT);
  pinMode(flashingBPin2, OUTPUT);
  pinMode(servoPin, OUTPUT);
  pinMode(detectLeftPin, INPUT_PULLUP);
  pinMode(detectMiddlePin, INPUT_PULLUP);
  pinMode(detectRightPin, INPUT_PULLUP);
  pinMode(IRLED, OUTPUT);
  pinMode(12, INPUT_PULLUP);
  pinMode(ledPin, OUTPUT);
  digitalWrite(speakerPin,LOW);
  pinMode(speakerPin, OUTPUT);
  pinMode(A0, INPUT_PULLUP);
  pinMode(A1, INPUT_PULLUP);
  pinMode(A2, INPUT_PULLUP);
  pinMode(A3, INPUT_PULLUP);
  pinMode(A4, INPUT_PULLUP);
  pinMode(A5, INPUT_PULLUP);
  pinMode(A6, INPUT_PULLUP);
  pinMode(A7, INPUT_PULLUP);
  gates.attach(servoPin);
  gates.write(GatesUp);
        // Timer 2 does 38KHz output to IR LEDs on D11
        // and Sound on D3
        TCCR2A = _BV(WGM20) | _BV(WGM21) | _BV(COM2A0) | _BV(COM2B1) ;
        TCCR2B = _BV(CS20) | _BV(WGM22) ;
        OCR2A = (F_CPU/(IRFrequency*2L)-1);
        OCR2B = 0;
       // TIMSK2 = _BV(TOIE2);
  State = StateClear ;
And my ISR:
volatile uint8_t InterruptCount = 0 ;
ISR(TIMER2_TOIE_vect)
  InterruptCount += 1 ;
(Everything that could complicate the test has been stripped).
If I don't set TIMSK2, the loop function runs normally. I thought maybe I had he wrong vector, but that looks right to me. I get the 38KHz output with the interrupt enabled or disabled.
Which timers does Arduino use for its own use then?
EDIT: OK so found this in the core Arduino files...
https://github.com/arduino/Ardui...
That seems to suggest it uses 1 and 2 for PWM?
TOIE in the vector name? I doubt that being correct.
Stefan Ernst
+1
Should be:
ISR(TIMER2_OVF_vect)
Bingo! Stefan wins the banana.
HAD to be something simplistic.
And now, with one other mistake found, my sketch works!
Detects train with IR detectors. That's why the 38KHz signal.
Flashes the lights.
Lowers the gate using the servo library. That's why I'm using Timer 2 for the sound too.
Goes DING DING DING DING while arm is down and lights are flashing.
All in 17% of the Arduino's memory, including the sound clip of the ding.
I think that you want to use
TIMER2_COMPA_vect
The overflow interrupt triggers when the timer2 count goes from 0xff to 0x00.   I believe that you want the interrupt to happen when the count reaches the compare register value.  The interval is the 1/16MHz * ( the value in the compare register) starting from zero.    The interrupt interval period is 62.5 nanoSeconds  (or 1/16,000,000) * 256 (timer 2's max count) when using TIMER2_OVF_vect because timer 2's counter is never set to a value from which it counts upwards to the overflow.
Nope. At mode 7 it triggers when the timer reaches TOP (set by OCR2A).
Stefan Ernst
Simonetta, he's using Mode 7:
I'm using mode 7.
Even if I have it wrong, it's working nicely
Arduino has 3 timers.
0 for the time base.
1 for the servo library.
2 for the 38KHz flashing IR led.
Oops, what do I use for the sound? OCRB of channel 2. It can only go 0 - 209, so I had a C# program scan the wave file, extract and scale the samples into C to copy/paste into the source. Since my interrupt happens at 76KHz, I count off 9, then 10 interrupts to fetch the next sample and put it to OCR2B.
Did the compiler not emit a warning about "misspelled vector name" ? This just shows why you should never ignore any warning until you are certain it is benign.
The Arduino IDE emits the warning, but doesn't use -Werror when building, so it proceeds to program the target.
