Converting avra macros to gas macros
4 posts / 0 new
Avra first substitutes the actual argument string(s) into the %0, %1, etc strings of the macro
definition, then evaluates the resulting strings. I can't see a simple way of achieving the same thing in gas.
If I have
r0 = 0
r1 = 1
etc
.macro add16 Rd, Rs
add \Rd, \Rs
adc (\Rd+1), (\Rs+1)
.endm
and then write
add16 r0, r2
then gas objects to the expression(s).
How can I achieve the desired (\Rn+1) values in the macro expansion?
I would really like to retain the standard assembler syntax i.e avoid the need to write source code of the form add16(r0, r2) if it is at all possible.
Roger
This is my first idea on it:
.macro add16 Rd, Rs
.set .L\@, \Rd + 1
.set .L\@, \Rs + 1
add \Rd, \Rs
adc .L\@, .L\@
.endm
add16 0, 2
Fairly ugly, agreed.
Upon researching the gas documentation, I got another
hint which leads to:
.macro xpand op, arg1, arg2
\op     \arg1, \arg2
.endm
.macro add16 Rd, Rs
add \Rd, \Rs
xpand adc, "(\Rd+1)", "(\Rs+1)"
.endm
add16 0, 2
It does the right thing, but always gives two warnings:
foo.S:0: Warning: unknown escape '\R' in string; ignored
Perhaps you can convince it to not spit out these warnings. :)
In AVR gas, a number can be used already at any place where a register
argument is expected (as it is clear from the opcode and operand that
this is a register). If you need source code compatibility to the "r"
notation, put the following preprocessor macros somewhere into a
central header file:
#define r0 0
#define r1 1
#define r2 2
#define r3 3
#define r4 4
#define r5 5
#define r6 6
#define r7 7
#define r8 8
#define r9 9
#define r10 10
#define r11 11
#define r12 12
#define r13 13
#define r14 14
#define r15 15
#define r16 16
#define r17 17
#define r18 18
#define r19 19
#define r20 20
#define r21 21
#define r22 22
#define r23 23
#define r24 24
#define r25 25
#define r26 26
#define r27 27
#define r28 28
#define r29 29
#define r30 30
#define r31 31
Jörg Wunsch
Very cunning, thanks Jorg. I'll look at it further, in the morning.
Roger
That first idea is very clever - it will be years before I know gas well enough to come up with an idea like that so quickly.
To be able to write source code such as
        ld16 r2, y              (i)
        ld16 r2, y+             (ii)
        st16 -y, r2   etc       (iii)
my macro needs to determine which pointer is used, and whether it is a simple indirection (i),
or an auto-increment/decrement (ii)(iii). The avra string substitution - evaluation again makes this easy;
I have some defines which include:
        .def r0lo=r0            ;low byte of a multi-byte value in rn:r0 is r0
        .def r1lo=r1            ;low byte of a multi-byte value in rn:r1 is r1
        .def r2lo=r2            ;low byte of a multi-byte value in rn:r2 is r2
            etc
        .def r0b1=r1            ;byte1 of a multi-byte value in rn:r0 is r1
        .def r1b1=r2            ;byte1 of a multi-byte value in rn:r1 is r2
        .def r2b1=r3            ;byte1 of a multi-byte value in rn:r2 is r3
            etc
        .def r0b2=r2            ;byte2 of a multi-byte value in rn:r0 is r2
        .def r1b2=r3            ;byte2 of a multi-byte value in rn:r1 is r3
        .def r2b2=r4            ;byte2 of a multi-byte value in rn:r2 is r4
            etc
        .define aa 1
        .define x1 -1
        .define y1 -1
        .define z1 -1
        .define x2 -1
        .define y2 -1
        .define z2 -1
        .define aax1 1
        .define aay1 1
        .define aaz1 1
        .define aax 1
        .define aay 1
        .define aaz 1
so that I then write my macro as
        .MACRO ld16
        .if (aa@11-2)           ; only ld16 Rd, x (or y, or z) has a non-zero result
          ld @0lo, @1+
          ld @0hi, @1
          ld @0lo, -@1          ; restore pointer without affecting SREG
        .else                   ; now separate x+ and -x (or y, or z)
          .if (aa@12-2)         ; only ld16 Rd, x+ (or y+, or z+) has a non-zero result
            ld @0lo, @1
            ld @0hi, @1
          .else                 ; assume only remaining possibility is ld16 Rd, -x (or -y, or -z)
            ld @0hi, @1
            ld @0lo, @1
          .endif
        .endif
        .ENDMACRO
Yes, it's inefficient for the simple indirection, because it generates an additional instruction,
but I consider the benefit for general coding to outweigh that. If I wanted to, I could further seperate the pointer register into x or (y or z), and then use an (ldd @0hi, @1+1) for the second instruction. The st16 macro is essentially identical.
The code that is emitted for the three examples above is:
        ld16 r2, y  -->         ld r2lo, y+
                                ld r2hi, y+
                                ld r2lo, -y
        ld16 r2, y+  -->        ld r2lo, y+
                                ld r2hi, y+
        st16 -y, r2  -->        st -y, r2hi
                                st -y, r2lo
I find this difficult in gas.
Edit: Correction: Note that the emitted code uses the r2hi/r2lo notation, rather than the explicit r3/r2 notation that I showed originally.
