BLDC controller
12 posts / 0 new
I am designing BLDC controller taking Application note AVR444. The provided code is for IAR compiler. I use AVR GCC.
Any one ever ported it to GCC? if so please help in this regard.
Or any one can give me the hex of the code, so that i can simulate it which will be helpful for me in development.
Nandhu
Hai
somehow i managed to compile AN 444 in IAR, but i cant generate hex file.
If i select intel-standard output format i get this error
Error[e133]: The output format intel-standard cannot handle multiple address spaces. Use format variants (-y -O) to specify which address space is wanted
Can any body help me to clear this error?
Nandhu
Can you successfully edit/compile/burn/run any other simple avr program? Like make an led go on and off at a designed freq and duty cycle? If so, this proves your program development chain is working.
The multiple address spaces are flash and EEPROM. Are you initializing the EEPROM in your code?
Try reading the thread below. It has an attached text file with tips, and lots of tips posted as comments on the thread.
Porting code from IAR to Avr-GCC
Stu
Thanks to everyone
to bobgardner
i am able succeed in compilation without generation of hex. i.e. i am able to generate and simulate it in avr studio. But i can't create an hex file
to rneil
yes i am intializing eeprom.
stu_san
Thanks for pointing out the topic, which i missed while searching.
Still cant able to generate hex. I am new to IAR
Nandhu
Surely there is something in the makefile about output file type. Might be as simple as removing the comment symbol?
nandhu015, did you ever found a solution to the problem? Because I have the same problem.
To generate a hex-file put this under Options>Linker>Extra options
-Ointel-extended,(CODE)=C:\whatever\code88.hex
-Ointel-extended,(XDATA)=C:\whatever\eep88.hex
and compile
I am having the same issue, however the answer lhogberg gave did not help me any further.
I still have this error:
help?
SER
I have use your indication and the compiler work OK.
but i have a strage problem :the pwm output is 2KHZ ISTEAD OF 20KHZ LIKE IS INDICATED ON AVR444 NOTE .
CAN SAMOBODY HELP ME ? WOTH CAN I DO?
THANK YOU
vandi
Vandi.
You do realise that you are replying to a post that is 8 years old. "lhogberg" has never returned here after that post.
Ross McKenzie, Melbourne Australia
Topic locked
