SAMA5D3x datasheet lists SYSC_WPMR, not found in datasheet
2 posts / 0 new
We are having problems with the RTC_CR register (and others) being trashed during a hard kill (input power to regulators shut off, power-supplies decay, reset goes active when the 3.3V supply reaches 3.08V).
In the SAMA5D3 Datasheet Rev. 11121E (02-Feb-16), the sentence was added for several of the RTC registers (see Table 60-2, page 1867, Issue Date 03-Feb-15):
“This register can only be written if the WPEN bit is cleared in
the System Controller Write Protection Mode Register (SYSC_WPMR)
However a search of the datasheet, of Atmel.com, etc. turns up no definition for SYSC_WPMR.  Inspection of Section 7, "System Controller" shows no register definitions.  Anyone know where this might be defined?
Thanks in advance!
Scott Willis
We are having the same problem not finding the SYSC_WPMR register described in the SAMS70 and SAME70 datasheets.  Are there any resolutions on this?
Walt
