AVR SPI without the ASF files
54 posts / 0 new
Hello all,
I am trying to interface a sensor with AVR controllers through SPI. AVR is new for me and when I looked into the API  it its confusing with the ASF files . It has drivers, then services ,then configuration files and then the examples given. IS it better to understand those files or start writing my own code from setting up the SPCR register ?
Forget ASF.
Read the datasheet for your processor. Lots easier that way.
SPI.h
// SPI driver header file
void spi_write(uint8_t temp);
void spi_init (void);
SPI.c with some settings for 14.7456 MHz crystal
// SPI driver
#include "spi.h"
void spi_write (uint8_t temp)
	SPDR = temp;
	while(!(SPSR & (1<<SPIF)));
//Set up SPI, MSB first, Master, mode 0, clock fck/128 115K@14.7456 MHz
//	SPCR |= (1<<SPE | 1<<MSTR | 1<<SPR1 | 1<<SPR0);
//Set up SPI, MSB first, Master, mode 0, clock fck/16 922K@14.7456 MHz
//	SPCR |= (1<<SPE | 1<<MSTR | 1<<SPR0); OK
//Set up SPI, MSB first, Master, mode 0, clock fck/8 1.843MHz@14.7456 MHz
//	SPSR |= (1<<SPI2X);
//Set up SPI, MSB first, Master, mode 0, clock fck/4 3.68MHz@14.7456 MHz
//	SPCR |= (1<<SPE | 1<<MSTR ); OK
//Set up SPI, MSB first, Master, mode 0, clock fck/2 7.3728MHz@14.7456 MHz
	SPCR |= (1<<SPE | 1<<MSTR);
	SPSR |= (1<<SPI2X);
you can simply turn the spi_write into a read/write routine by adding a line to return SPDR. Remember that in order to read the SPI you MUST send something out (garbage usually 0xFF)
Thanks a lot !! It is now clear :) is it necessary to write interrupts /ISR , for write and read operation? As the sensor is programmable, first I just want to write and read a simple data to it. Just to establish communication.
SPI is possibly the easiest thing an AVR can do. On the whole there's no point introducing the complexity of interrupts or anything like that. Just a short function to configure it then an equally simple function to send and receive a byte and that's it.
Okay. That is really a good news for me. http://www.robotshop.com/media/f... this is my data sheet.  According to it clock spped is 16 Mhz? or is this the highest setting possible ?
//Set up SPI, MSB first, Master, mode 0, clock fck/2 8Mhz@16 MHz
	SPSR |= (1<<SPI2X);
It's an Arduino so, yes, it will have a 16MHz crystal and will be running at that speed.
BTW is it really necessary to communicate at 8MHz? Can you really process data that quickly?
My code :
#define F_CPU 1000000UL
#include <util/delay.h>
#include <avr/interrupt.h>
#include "spi_master.h"
void spi_master_int (void)
	DDRB = (1<<2) | (1<<1);  //PB2=MOSI ,PB1=SCK as output
	SPCR = (1<<SPE)| (1<<MSTR) | (1<<CPHA) ; //spi enabled master mode, spi_mode 1,prescalar :fosc/4, MSB first
char spi_send (char r_data)
	SPDR = r_data;
	while(!(SPSR & (1<<SPIF) ));
	return (SPDR);
    spi_master_int();
    //while (1)
		spi_send(0x01); //power on
		spi_send(0x11); //write opcode
		spi_send(0x54);// address to be written
		spi_send(0xBA); // data to be writtten
		_delay_ms(100);
		spi_send(0x21); // read opcode
		spi_send(0x54); // from  address to be read
		char result = spi_send(0xFF); returning the read value
I simply read and write so i thought data processing is  possble. The sensor freq was 20mhz. My boards is Atmega256 ,not arduino .
Datasheet here : http://www.atmel.com/Images/Atme...
I have ICE debugger.
Is my pogram right ? bcos the JTAG debugger says:  result    Unable to evaluate the expression.
I just changed cpu to 1 Mhz, but no luck!
Defining the F_CPU does NOT change the uC clock frequency. The frequency is determined by fuses including both clock source (CKSEL bits) and initial prescale divisor (CKDIV8)  and whether the prescaler select bits have modified that initial prescale setting (CLKPS bits in CLKPR) as well as the crystal (if the fuses select it).
David
so , #define F_CPU 1000000UL can be #define F_CPU 16000000UL . Am I right ? But I do not see any values in the debugger.
Make 'result' a global (and perhaps even volatile) variable.
Stefan Ernst
I haven't seen what sensor you are trying to access mentioned... What is it?
Does it require a chip select to be accessed?
Edit: typo
David
Thanks a lot, it is executing but it says nothing other than 0x00. Just  a basic doubt, How is MISO working here. I understand that its pin value is 0,hence its input. So, I read value only from the SPDR? Is there no connections of MISO here?
BTW: You must make SS an output.
Stefan Ernst
I tried it..but nothing's changed. I have attached the sensor datasheet. Kindly look at it.
The reason for that is that nothing uses "result" after your line:
so the compiler won't create the variable (there's no point). If you want to say to the compiler " but this variable MUST exist" then the word is "volatile":
	volatile char result = spi_send(0xFF); returning the read value
Now you should be able to examine "result" in the JTAG debugger.
I am sorry that I did not mention it .I changed to volatile. It is able to evaluate but it says only zero. I want to read my wriiten value. If you just look at  pg.64, there is a flow chart for communication test,i just tried it. BTW ofcourse I changed the OPCODES accordingly. Pg 40.,there is a simple I2C test, I am trying exactly the same with same opcodes on SPI interface.
0x90  -writing
0x47 -address
0xFF -data
and so on..
EDIT:flowchart pg:74
Hello all,
my code still - does not work. During the debugging of the code, the values I send here :
	SPDR = r_data;
	return (SPDR);
that is the values passed to r_data is not put in the SPDR register. What could be the reason. ?
Never tried it (no Atmel-Studio installed), but I would guess that you never see in the debugger what was written to SPDR. It shows you what you would read from it, which is not what was written to it, but what was received last. Very likely you are barking up the wrong tree.
Stefan Ernst
so how can I debug the code? I mean there is no reply from the sensor, so what can I do in this case. Could someone suggest me anyother sensor which I can work with using SPI interface - with commands  It would be really very helpful
Very likely your software is the problem, not the sensor. You never showed us the current (the modified) code.
Is SS an output now?
Is there a proper CS handling now?
Stefan Ernst
Best debugging tool for SPI in my opinion is a DSO or Logic Analyser. Watch the wires - faults will very quickly become apparent.
(the software side of SPI (apart maybe from the CPOL/CPHA selection) is so trivial it is difficult to get that bit wrong)
((oh except for the SS thing Stefan mentions - that's the common "gotcha"))
volatile char result ;
	DDRB = 0x07 ;  //PB2=MOSI ,PB1=SCK as output ,PB0 =SS as output
	SPCR = SPCR = (1<<SPE) | (1<<MSTR) | (1<<CPHA) ; //spi enabled master mode, spi_mode 1,prescalar :fosc/16
    spi_master_int();
   while (1)
		//spi_send(0x7E);
		spi_send(0xA1);
		spi_send(0x47);
		spi_send(0xBA);
		spi_send(0x21);
		spi_send(0x47);
my spi.h file:
void spi_master_int (void);
uint8_t spi_send (uint8_t r_data);
	SPDR = r_data;
	while(!(SPSR & (0x80) ))
	return (SPDR);
These are the modified codes. And what is the difference between CS and SS ? is both not the same?
Still no CS handling whatsoever. No wonder you don't get any data from the sensor if you never select it.
SS is the pin at the master, CS at the slave (can be called differently, eg. CE, EN, SEL, ...).
Stefan Ernst
If you have connected the SS from the uC to the sensor SSN, there is no control of the SS signal in the above code.
David
It's called SSN, and is active low according to the DS.
DDRB = 0x07
According to the data sheet , if i set the directon pin as 1,it is output, that is my PORT B's last pin is SS.
PB0= 1 // SS
PB1=1  // SCK and so on.
Yes the controller is connected to the SS of the slave. What should I do to control/select it?
Page 2-17 of your data says the signal called "SSN_PG0" is active low. So you should get the AVR (driving out through its SS pin that then connects to SSN_PG0) to take that GPIO line low just before you start to communicate and then high afterwards.
It serves two purposes.
1) When not selected the device should relinquish lines it may be controlling - this allows the AVR to operate more than one SPI device if necessary.
2) The act of selecting the device (signal goes low) causes the device to reset its internal SPI shift register. So if it missed any clock pulse (or saw some glitch as an extra one) this gives it the chance to get back into line with the AVR.
I am very sorry that I have attached a different datasheet . My apologies. But the pins and config was all same.I just noted it when clawson told me the pg number. I am really sorry
This is my datasheet.
In this Pg:365,the SS pin can be configured as  input or I really I dont understand how should I control it ? As I did not use interrupt or used the SPIE register.
I feel bad for making such a trouble for the easiest interface. :(
So you are talking about one AVR talking to another AVR using SPI? yet the thread started with
Which of the two AVRs here is the "sensor" ?
NO NO ...Its between sensor (datasheet from post number: 15) and the AVR. The mistake is the datasheet of AVR was interchanged. This is trhe right one :
The SS pin is NOT controlled by the AVR SPI hardware, you have to manipulate it yourself.
Set SS high when not doing SPI, set low just prior to SPI read/write, set high again after read/write completes for each SPI access (although some slave devices can operate with SS always low).
David
Thanks for the clarity. But My second value doesnot go into the bus at all. . . . I am not sure if this is a good/bad
question
 void spi_select()
	DDRB = 0x06;
void spi_deselect()
 DDRB = 0x07;
//inside main - this while loop after initialising
while (1)
        spi_select();
        spi_send(0xA1);
        spi_send(0x47);
        spi_send(0xBA);
        spi_send(0x21);
        spi_send(0x47);
        spi_deselect();
This is my updated code. I made a breakpoint at result. But the program is held at the never ending loop during the transfer of the second value.
In the following code,it is held at the while(!(SPSR));
	SPDR = r_data;
	return (SPDR);
how can this be cleared?
Why hard code numbers like 0x80 here? Now we all have to scurry off to our datahseets to see which bit that is.
oops . It is while(!(SPSR &(1<<SPIF)));
Well that not occuring is usually a symptom of SS having being pulled low as an input. Are you sure you are using the designated SS pin as the chip select to the device. Whatever you do with that SS pin it CANNOT be left as a floating input or worse, an input that is externally pulled to ground. If that happens the MSTR switches to slave operation and writing SPDR does not create SCK pulses so SPIF never becomes set.
According to the datasheet,
if any,
DDRBx = 0 : PinPBX= input
DDRBx=1; pinPBx=output
According to this post,
while initialising, I have made PB0 ,the only chipselect pin present , PB0 as 1;
in the function select () : it is made to PB0=0 (DDRB = 0x06)
in the function deselct (): it is made toPB0= 1 (DDRB = 0x07)
Err, no!
DDRB = 0x06 does not make PB0=0, it makes PB0 an input.
DDRB = 0x07 does not make PB0=1, it makes PB0 an output.
PB0 has to be an output all the time. And you have to make that output low to select the sensor, and you have to make that output high to deselect.
Stefan Ernst
 void spi_select()
	PORTB &=(~ 1<< PB0);
 void spi_deselect()
	 PORTB |=(~ 1<< PB0);
Thank you all for the clear explanations and guidance. I will use this above code and let u know the results soon
  Nope...
    PORTB &= ~(1 << PB0);
// or
    PORTB |= (1 << PB0);
David
Hello all,
I made the chnages with
void spi_select()
	PORTB &= ~( 1<< PB0);
 void spi_deselect()
	 PORTB |= (1<< PB0);
The values are sent and updated . But the result register always remains zero (post 33). What could be the problem ?
From Post #33
pika wrote:
while (1)
        spi_select();
        spi_send(0xA1);
        spi_send(0x47);
        spi_send(0xBA);
        spi_send(0x21);
        spi_send(0x47);
        spi_deselect();
Just what are you sending and expecting here?
I would think:
uint8_t data = 0;
uint8_t address = 0;
uint8_t result;
// Write (and read) data to SRAM of the PCapØ1Ax-0301 (from diagram on page 6-6 of datasheet)
spi_select();
spi_send(0x88); // Reset the PCapØ1Ax-0301
spi_deselect();
while (1)
        spi_select();
        spi_send(0x90); // Write to SRAM @ address
        spi_send(address);
        spi_send(data++); // Write data and increment
        spi_deselect();
        spi_select();
        spi_send(0x10);  // Read SRAM @ address and increment to next address
        spi_send(address++);
        result = spi_send(0xFF);  // Read data
        spi_deselect();
David
    spi_master_int();
	spi_select();
	spi_send(0x88); //turn on
	spi_deselect();
	while (1)
		spi_select();
		spi_send(0x90); //wrte
		spi_send(0x47); //address
		spi_send(0xBA); //data
		spi_deselect();
		spi_select();
		spi_send(0x10); //read
		result = spi_send(0xFF); //reading back data
		spi_deselect();
This is my code . From pag 4-4 ,I am trying to do the same that is happening in i2c with SPI. I expected to get the data ' BA' to be read in the result register
I find this thread very confusing but if the SPI device that is being interfaced with is still the item in post #15 then the key section of the datasheet is:
Like Frog I wonder, therefore, what the intention of:
        spi_select();
        spi_send(0xA1);
        spi_send(0x47);
        spi_send(0xBA);
        spi_send(0x21);
        spi_send(0x47);
actually is. It would seem that anything starting 0xA1 is a "Write OTP" command. That sounds VERY DANGEROUS to me!! OTP = One Time Program. You are only going to get one chance to do that. It is hardly the very first thing you should be attempting when first trying to get the interface to work because if you screw up you may have damaged he chip irrevocably in your One Time chance of programming it.
If it were me I think I'd be looking around the table in section 5.1 of the data to see if the device has any unmistakably identifiable data pattern in any of its registers then use a 0x10 (read RAM) command to see if you can read that and verify that what comes back is the expected bit pattern - then you know the SPI works.
pika wrote:
    spi_master_int();
	spi_select();
	spi_deselect();
	while (1)
		spi_select();
		spi_deselect();
		spi_select();
		spi_deselect();
Thanks a lot for your time and pointing out the points.So fine,it is clear . I think I will have to deal with the hardware first.  This is the program (that I have quoted )I have written. Let us assume, the chip is not damaged.
If the chip is normal,is my expectation of ' reading the  value (BA) in result register' right?
For now, I am not doing any measurements but just trying to do what is in pg 4-4 via SPI. Am I procedding the right way?
How do you have the IIC_EN pin on the PCapØ1Ax-0301 configured?
(High for I2C, Low for SPI.)
In post #8 you set SCLK and MOSI as output.
I have not re-read entire thread, but do you set SS as output?
How about posting complete code as currently implemented.
Also, for others looking at this thread, the PCapØ1Ax-0301 cannot share the SPI interface with other slaves as it does not place MISO in a high impedance state (see datasheet page 7-4).
Edit: Since you are not doing anything with result, it may be optimized away...but the value should be in SPDR after the transfer if using the debugger.
David
void spi_select()
	PORTB &= ~ (1<< PORTB0);
void spi_deselect()
	PORTB |= (1<< PORTB0);
    spi_master_int();
	spi_select();
	spi_send(0x88);
	spi_deselect();
	while (1)
		spi_select();
		spi_send(0x90);
		spi_send(0x47);
		spi_send(0xBA);
		spi_deselect();
		spi_select();
		spi_send(0x10);
		spi_send(0x47);
		spi_deselect();
//this spi_master.h
void spi_select (void);
void spi_deselect(void);
	SPDR = r_data;
	return (SPDR);
This is my full present code. IIC_EN pin is connected to the ground. I am using the debugger,but I did not get any change in the value. As I added SPDR,result and r_data in the watch section. Each time the different datas are passed on it (each send invoked) and the r_data value changes,but no change in the SPDR and result. They are always 0x00.
EDIT : I want to make sure that there is no problem with the software /n programming part.
Look at SPDR in the SFR IO view not as a watch.
The best way to "debug" something like SPI is with a DSO or Logic Analyzer.
I was able to see the change in SPIF register  from 0x80 to 0x00.  But I cannot see change is the SPDR register.
Unfortunately I do not have a DSO.
pika wrote:
If the chip is normal,is my expectation of ' reading the value (BA) in result register' right? For now, I am not doing any measurements but just trying to do what is in pg 4-4 via SPI. Am I procedding the right way?
To achieve this ,is my program and approach proper ?
EDIT:
And if the 'result 'in my program is optimised. Then how will I be able to read the results if I am starting to do the measurements. In Pg 75 and 76 there are steps about reading the results. It is writing the opcodes and then reading the value, which is almsot the same as I do here. indecision
The same sensor I tried writing and reading back with arduino ,and it worked. But with AVR, I do not know to handle it still. frown
Well the good news is that Arduino *is* an AVR so what worked there will work "standalone" too. Other good news is that nothing in Arduino is "hidden" you can study the source code of all of it so you can see what every bit of the "working" solution is doing anyway.
I mean I worked with Arduino DUE. Not really a different source code from that I wrote above. I just had to change them accotding to the Arduino IDE standard. It would have been better,if printf was easily accesible in Atmel Studio 7
Err it is:
So a minimal AVR program to use something like printf() might be:
#define BAUD 9600
#include <stdio.h>
#include <util/setbaud.h> // uses BAUD and F_CPU as input, outputs UBRR_VALUE
void uart_init(void) {
	UBRR = UBRR_VALUE;
	UCSRB = (1 << TXEN);
int	uart_putchar(char c, FILE *stream) {
	loop_until_bit_is_set(UCSRA, UDRE);
	UDR = c;
	return 0;
FILE uart_str = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE);
int main(void) {
        uart_init();
	stdout =  &uart_str;
	while(1) {
		printf("Hello world\n");
The only "trick" in any of that is the FDEV_SETUP_STREAM and the connection to stdout. But as soon as you have made a connection between stdout and a uart_putchar() routine then all the usual stdio.h output routines are connected and ready to use.
The reason it's done like this is that the output could just as easily have been an LCD with LCD_init() and an LCD_putchar() instead. It's up to you what output device you'd like to use.
The same technology also allows for a uart_getchar() and then connecting that to stdin after which all the things like scanf() could be used too.
oops. I wanted to print the 'result ' from my post #47 . Because, I could not get to understand if I have receieved the value that is supposed to be read. The ASF and drivers aree too confusing for such a simple operation, so I tried to do SPI on my own.
