JTAG - Linux - AT90CAN128
3 posts / 0 new
I want to debug and write my programs through AVR DRAGONs JTAG to my AT90CAN128 board.
I'm using Ubuntu 16.04.
How do I get started? I have used the DRAGONs ISP with avrdude and it worked nicely.
Should I use eclipse or is there another better option?
Thanks!
Code is everything, code is life :D
Eclipse is just an IDE (or, strictly, an IDE framework) - so it won't magically do this for you.
To work with Eclipse, you would need something like OpenOCD ...
EDIT: So try googling "AVR DRAGON openocd" - a few hopeful-looking hits ...
Except that for Atmel devices the "bridge" between avr-gdb and the Atmel debugger devices is called "avarice" not "OpenOCD"
