at32uc3c2512 handle for eject, MSC usb (mass storage)
4 posts / 0 new
Hello ;)
I have a little problem, mass storage working good also with internal flash memory. Now i must know when user did a eject mass storage by windows system, and i don't know how. Do exists some handle from eject action in ASF ?
regards
It's not clear from your question: Is the at32uc3c2512 being the USB Host or Device ?
Also, are you using ASF? Some other USB stack?
Hi, sorry, it's USB device and i using ASF framework.
ok, i found solution, is in
    case SBC_START_STOP_UNIT:
        udi_msc_sbc_start_stop();
        break;
in file udi.msc.c line 550,
this is run when we do a click on eject in windows, i did not test in linux.
Regars :)
