source code error
7 posts / 0 new
Hi i am batteling with this software this is a small piece of software in a library.
When i compile the complete code with all the libraries there is no errors,(still finding my way around c).
When i create a new project and only use the main part and copy these two routines from the library and paste it just under the #defines i get a error ''com'' not defined.
I want to break the source code (that is scattered over several libraries)up into small pieces to understand the working of C .
How must this be structured to work outside the original library????
void ili9341_spi_send(unsigned char spi_data)//send spi data to display
SPDR=spi_data;//move data into spdr
while(!(SPSR & (1<<SPIF)));//wait till the transmission is finished
void ili9341_writecommand8(uint8_t com)//command write-------GET ERROR FROM THIS LINE------COM not defined
controlport &=~((1<<dc)|(1<<cs));//dc and cs both low to send command
_delay_us(5);//little delay
ili9341_spi_send(com);
controlport |=(1<<cs);//pull high cs
You need to #include <stdint.h> methinks.
com is probably a #define in the original library code
you would need to set this in your own code as well
(probably wiser to just #include the library rather than trying to copy the code.)
Is that the only error you get?
Most likely, as Kartman suggests, there were earlier errors - and this is just a consequence of those.
This is why it's really important that you address the first error first.
No - it's one of the function parameters.
I think Kartman's suggestion is more likely ...
EDIT
Fix quote
That sounds like trying to learn to drive by dismantling a car!
It's generally a lot easier to learn stuff by starting with basics and working up to more advanced stuff ... !
How is it possible to give a answer if you do not understand the question?
1.No error in first build with all the libraries included!!!!
2.Blink led--------DONE
3.Blink several leds---------DONE
4.Use buttons to blink leds--------DONE
5.ADC 8 bit write on alpha numeric lcd-------DONE
6.ADC 10 bit write to alpha numeric lcd ,(Hi limit --write pump off)...(Low limit --write pump on).....Mmmm...o yes DONE
I am not learning to drive just want to find out why the same carbutattor works in a BLUE truck and not in the GREEN truck (same models).
''#include <stdint.h>'' this is included in the MAIN file,i dont want to use 4 libraries just get the SPI working ,i am testing small bits of sample code to get a better understanding.
You have to include it in every file which uses things like uint8_t. Each file is compiled separately.
It isn't a library but a header file. And including it in multiple files costs you absolutely nothing.
Stefan Ernst
