Atmega168 Low clock speed
3 posts / 0 new
Hi All,
Has anyone any experience of running an Atmega168 at 250KHz, any problem with the TWI, ADC, eeprom or flash writing?
Dave
"If it wasn't for bad luck I'd have no luck at all"
The ADC's performance is guaranteed if the ADC clock is anywhere between 50 kHz and 200 kHz. With a 250 kHz CPU clock, it is possible to derive two guaranteed legal ADC clocks: 125 kHz or 62.5 kHz.
EEPROM and Flash writing are always driven by the internal calibrated RC oscillator -- no matter what clock you choose to use for the CPU. If you use the the factory default calibration constant (or change the calibration but keep it within 10% of nominal), the Flash and EEPROM writing should be unaffected.
I have no first-hand experience to report about the TWI module.
Remember that this family of chips has an internal 128kHz oscillator as a clock option.
The first page of the datasheet (as with all AVRs AFAIK) says "Fully Static Operation". A few years ago on previous generations it was noted that there seemed to be problems at very low clock frequencies like a few Hz. I do not know whether this is still the case but I wouldn't think it would be a problem in practice.
Lee
