I have no problem using Studio 7 with elf files made with Studio 4.
But regarding backwards compatibility, would elf files made with AS7 program correctly if AS6 was the programming environment.
All sections are used in the elf file ( Flash, EEMEM, Fuses and Lock bits), and would need to ensure the chips were correctly programmed.
Anyone current doing / done this?
