Starting with AVR assembly
20 posts / 0 new
Hi all.
What is needed to create a basic assembly program in Atmel Studio 6? I have created an assembly code project but the page is blank and I don't really know what to write. What is the template for creating a new application?
I've seen suggestions like ".include m328blabla" but they seemed unnecessary since the m328p is already specified during the creation of the project. ".CSEG and .ORIG 0000" or something was something else I saw.
My biggest problem by far is just getting on with stuff, once I get the jist of them I can do it. I've programmed in assembly before, I'm not a total noob but when it comes to AVR asm I am. I've looked for good sources etc and I'm sure there are many but that's kind of the problem. I just want to hear some good advice from the mouth of a real person and you are the closest I can think of.
So shoot!
sol i sinne - brun inne
When you specify a target in the IDE, that only drives the processor definition file tree. You still have to include the tree. In C, you need to #include <avr/io.h> or something close to that. When I did assembler work back with Studio 4, I remember having to include a  processor-specific definition file. Don't know how that works, now, in assembler.
But, my point is that simply defining the target in the IDE is not sufficient. You certainly need to do that, but there is more.
Thanks for the heads up. I guess that's my first line, yay! *edit, oh, seems it was unnecessary after all in AS6
Not necessary with AS6 or 7, they hold your hand by including the .inc file when you start a project. (I always delete their include file and add my own with .nolist and .list so that I don't get a huge .lss file).
This is the STK500 demo program.
;***** STK500 LEDS and SWITCH demonstration
.nolist
;.include "8515def.inc"
.include "m32def.inc"
.list
.def Temp =r16 ; Temporary register
.def Delay =r17 ; Delay variable 1
.def Delay2 =r18 ; Delay variable 2
.dseg
test_label:	.byte 1
.cseg
;***** Initialization
RESET:
   ser   Temp
   out   DDRB,Temp      ; Set PORTB to output
;**** Test input/output
LOOP:
   out   PORTB,temp      ; Update LEDS
   sbis   PIND,0x00      ; If (Port D, pin0 == 0)
   inc   Temp         ; then count LEDS one down
   sbis   PIND,0x01      ; If (Port D, pin1 == 0)
   dec   Temp         ; then count LEDS one up
   sbis   PIND,0x02      ; If (Port D, pin2 == 0)
   ror   Temp         ; then rotate LEDS one right
   sbis   PIND,0x03      ; If (Port D, pin3 == 0)
   rol   Temp         ; then rotate LEDS one left
   sbis   PIND,0x04      ; If (Port D, pin4 == 0)
   com   Temp         ; then invert all LEDS
   sbis   PIND,0x05      ; If (Port D, pin5 == 0)
   neg   Temp         ; then invert all LEDS and add 1
   sbis   PIND,0x06      ; If (Port D, pin6 == 0)
   swap   Temp         ; then swap nibbles of LEDS
	push	temp
	lds		temp,test_label
	subi	temp,-1
	sts		test_label,temp
	pop		temp
   ;**** Now wait a while to make LED changes visible.
   DLY:
   dec   Delay
   brne   DLY
   dec   Delay2
   brne   DLY
   rjmp   LOOP         ; Repeat loop forever
Thanks to both of you. Is a branch in the end of the program a must? What happens if the AVR reaches the last line of code and it's not a branch backwards? Is it the same as a "NOP" or can the instruction memory be old garbage and therefore do nothing or something weird? So many questions...
What do you think will happen? After all you say wink
Haha okay, in my defense there are many levels of noobness blush
There is no OS to exit to. If your program runs off the "end", anything  is possible.
That endless loop is a critical part of every program I've  done, either asm or c.
With out an endless loop on the end, the cpu will continue to pick up the next instruction and do Whatever it says to do, even something you did not want it to do.
So, you need to create some kind of endless loop.   It could include a sleep command, but you still need to loop back in case it wakes up again.
One good thing is that you can run the code in the simulator and SEE what happens, even better if you have a real chip and a debugger.
So thus far;
An endless loop sooner or later in the program, just like we do when writing in C for the AVR. Gotcha.
Hm yes the simulator. I think I tried to use it but something was wrong. Does it come installed from the get go or do I need to add anything to Atmel Studion 6?
Yes for most chips. The M328 should be supported.
First decide which assembler to use:  There is one that is compatible with C (you might add parts written in C in the future) and one that's not.
If you go for the one that's not compatible with the C compiler, it's often called "Atmel assembler" or some such. And your learning experience start here: http://www.avrbeginners.net .
Why don't you guys just come out and say it?  There is Atmel assembler, and also a flavor that is part of the GCC package.  [re-word or clarify or correct as you like]
But I think you need to stop short of saying "not compatible with C".  For example, my CodeVisionAVR C apps use the Atmel assembler.  And Atmel assembler fragments are easily integrated.
Yes Lee. I was only trying to keep my answer simple, since the OP is clearly a beginner.
Side fun: when I was starting to type "answer" and had come to "an" the tablet keyboard software suggested "ankle" and "anxiety".. :-)
I lost my flow a bit when the simulator didn't work. Maybe I should download AS7 and hope it works there. Which assembler is used in AS?
You get a choice of 2 assemblers in AS7. One is the same Atmel Asm2 as found in AS4 and one is GNU as which is the assembler for the C and C++ compilers.
Gee, it would be nice if someone had mentioned that earlier in the thread.
I'm using a phone, didn't read the preceding - just responding to the most recent comment.
